Results 1 to 25 of 47
Thread: Team Finland Warmup + Livestream results (AMD Black OPS) Macci, Sampsa, SF3D
Threaded View
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Hi all!
    I had a warm up session for our livestream event, which will be tonight:
    http://www.amdblackops.com/
    It will start at 20.00 local time (GMT +2) / 11AM
    Central time.
    My 1010BPMW seems to be nice CPU. Only problem was terrible IMC "cold bug" when pot was full of LN2. It was giving memory errors, if I tried to open 3DM06 for example.
    Then again, basic CPU tests were OK like Wprime, Vantage and superpi 1M.
    I hope this is still a bios issue and hopefully it will be fixed asap.
    My new CPU pot (SF3D OC Inflection point) works perfectly with Phenom II X6 as well. During those long CPU tests I saw the temperature to raise up to -180.3C° and wors temp was -179.6C° during 1024M.
    On idle, the temperature was -184.2C° almost all the time. Not too bad
    Setup:
    AMD Phenom II X6 - 1010BPMW
    ASUS Crosshair IV Formula
    Kingston HyperX 2133 CL8 memory
    Antec 1200W OC PSU
    Sapphire VaporX 5870 VGA
    SF3D Inflection point CPU pot
    Win Vista 32-bit with all crap inside
    30K with AMD CPU
    Wprime 1024M:
    Wprime 32M:
    Superpi 1M (Vista):
    CPU-Z:
    http://valid.canardpc.com/show_oc.php?id=1162645
    Max CPU-Z screenshot:
    More results will follow in tonights show with Macci and Sampsa
    See you all online!
    You are as good as your samples are!
