X6 1035T @ 200x15.5, 8GB Memory @ 1600MHz, Post 1 Of 2
A quick test at mostly stock settings to get a feel for the board. As the screenshots show I am able to manually lock in the Turbo multipliers in the BIOS. I'm not sure if this is because of the chip or the board/BIOS is allowing it. I have asked for clarification and will post the info when I receive it.
ASUS 4A89TD Pro, 0502 BIOS
Phenom II X6 1035T
4x2GB OCZ Platinum AMD Edition (OCZ3P1600LVAM4GK) PC3-12800 1600MHz 7-7-7-24
200x15.5, Memory @ 1600MHz 7-7-7-24
OCZ 100GB Vertex LE100
SAPPHIRE 4870x2, 4870 Trifire
OCZ Z Series 850W
click for larger image
Code:
Configure System Performance Settings
Target CPU Frequency:. 3100MHz
Target DRAM Frequency: 1600MHz
CPU Level Up......................[Auto]
OC Tuner Utility
AI Overclock Tuner ..................[Auto]
CPU Ratio............................[15.5]
CPB Control..........................[Disabled]
DRAM Frequency.......................[1600MHz]
CPU/NB Frequency.....................[Auto]
HT Link Speed........................[Auto]
> DRAM Timing Configuration
> DRAM Driving Configuration
************* Please key in numbers directly! *************
CPU & NB Voltage Mode................[Offset]
CPU Offset Voltage.................1.284 [Auto]
CPU/NB Offset Sign.................[+]
CPU/NB Offset Voltage..............1.225 [0.075000]
CPU VDDA Voltage.....................2.496 [Auto]
DRAM Voltage.........................1.643 [1.65000]
HT Voltage...........................1.196 [Auto]
NB Voltage...........................1.096 [Auto]
NB 1.8V Voltage......................1.800 [Auto]
SB Voltage...........................1.100 [Auto]
CPU Load-Line Calibration............[Auto]
CPU/NB Load-Line Calibration.........[Auto]
CPU Spread Spectrum..................[Disabled]
PCIE Spread Spectrum.................[Disabled]
DRAM CAS# Latency....................7 [7 CLK]
DRAM RAS# to CAS# Delay..............7 [7 CLK]
DRAM RAS# PRE Time...................7 [7 CLK]
DRAM RAS# ACT Time..................24 [24 CLK]
DRAM READ to PRE Time................6 [Auto]
DRAM Row Cycle Time.................31 [31 CLK]
DRAM WRITE Recovery Time............12 [Auto]
DRAM RAS# to RAS# Delay..............6 [Auto]
DRAM READ To WRITE Delay.............6 [Auto]
DRAM WRITE To READ Delay(DD).........2 [Auto]
DRAM WRITE To READ Delay(SD).........6 [Auto]
DRAM WRITE To WRITE Timing...........4 [Auto]
DRAM READ To READ Timing.............4 [Auto]
DRAM REF Cycle Time................110 [Auto]
DRAM Refresh Rate..................7.8 [Auto]
DRAM Command Rate...................1T [1T]
DCTO Information:
CKE drive strength..................2X [Auto]
CS/ODT drive strength.............1.5X [Auto]
ADDR/CMD drive strength.............2X [Auto]
MEMCLK drive strength.............1.5X [Auto]
Data drive strength..............1.25X [Auto]
DQS drive strength...............1.25X [Auto]
Processor ODT...................60ohms [Auto]
DCTO Information:
CPU Configuration
AGESA Version 3.7.0.0
AMD Phenom(tm) II X6 1037T Processor
Revision: E0
Cache L1: 768KB
Cache L2: 3072KB
Cache L3: 6MB
Speed : 3100MHz
uCode Patch Level: 0x10000BF
Microcode Updation..................[Enabled]
Secure Virtual Machine Mode.........[Enabled]
Cool'n'Quite........................[Enabled]
C1E Support.........................[Enabled]
ASUS Core Unlocker..................[Disabled]
CPU Core Activation.................[Auto]
DRAM Controller Configuration
Channel Interleaving................[Auto]
MemClk Tristate C3/ATLVID...........[Disabled]
Memory Hole Remapping...............[Enabled]
DCT Unganged Mode...................[Always]
Power Down Enable...................[Disabled]
