Results 1 to 22 of 22
Thread: 1st H20 ProjeKt - Antec P180 -
    Apr 2010
    Lightbulb 1st H20 ProjeKt - Antec P180 -
    I decided to move to water cooling after deciding to WC a couple GTX 480's. So I have little modding experience, and no WCing experiencing, but I think I did my homework well enough to piece together a decent couple of loops.
    Im going to let the pictures do most of the talking on this one, but I felt that my Antec P180 was ready for a makeover.. There is a certain satisfaction you get when an outdated case becomes viable again.
    So the challenge I had was to not use any rotary fittings and planning how was I going to fit 2x120.3 rads, and 1 120.2 rads in this case and still have effective airflow.. It only took me a couple of minutes to decide that I had no problem looking at the rad's outside the case.. and thus the work had begun.
    I will be updating the original post with pictures on a regular basis until all is completed.
    In The Beginning...
    Jigsaw + Dremel + Dreaming
    Have not put rubber in for the grill yet, just getting a feel.
    Some of the guts, and overall theme
    So do you notice I had to mounted the LC horizontally as I found the block to be resting on the caps which EVGA placed right next to the CPU socket when mounted vertically. If this creates a temperature problem I will be switching out the block.
    So during the dissembling of the reference cooler on 1 of the GTX480's a screw got stripped so bad I had to revert to a dremel and eventually a drill to get the screw out of the card and heat sink.. "No GTX 480's, or heatsinks were harmed in this process." ".
    Pump used for CPU/NB/SB/Vreg loop
    Pump for the GPU's
    First flush of the MCR320
    First flush of the TFC X360
    First flush of the MCR220
    Odd Modz
    This will make more sense later into the build - basically it's my my MCP355 will rest in the drive bay.
    The paint is safe for Arcrylics, I just could not justify the extra cash for the Black/Metal BP T's, I think these will work fine, 4 were painted, only 3 shown, these are the T's I will convert to elbows and will be using for my GPU blocks.
    They came out perfect... Except I wont be using them and I have some BP Black metal T's on the way as I did not want to stand the risk of the Acrylics cracking over time which I have seen they can
    The Metal T's came in today, I was stoked when I saw the package.
    The start of some custom air boxes/shrouds
    And.. They're Done!! - Finally I can start system assembly!
    CPU Loop is finished - the rest coming soon.
    Received the rest of my parts today 5/4/10
    Added my T line.. I might change this around depending on how well it functions
    Never mind the dust, I still have to blow this system out
    Thanks again for the comments guys, next is cable management
    So I have been holding out on this idea until I had it almost finish. Basically I am using removable plates so I can make any logo I want. I designed this H2O plate and had a friend laser cut the plate for me. I plan to make a [H] one, and may get more creative.. So I am holding it on with velcro. The images are an idea of how it will look. I got some plexi which I painted white on one side and left clear on the other. I plan to have 4 green LED's shining into it to create a green glow. The resivoirs are also going to be glowing green. The images here are only a piece of white film with some gren LED's behind it to give it the effect I wanted. Also, no cable management has been performed yet.
    Almost finished but still have to make it more tidy.
    Sorry no temps yet, still havn't powered the board up yet.. currently waiting on Performance PC's to send me my res for the GPU loop. I have about an hour a day to spend on this due to the "not spending enough time" with the girl.. (grrr) I did manage to get some of the cable management done though.
    Jun 2008
    Sweden
    whoa! , the HX1000w nearly doesn´t fit in the p180
    but you said no rotary fittings? but you are using rotary on the cpu block? :S
    i7 980X | EVGA X58 Classified | 6 GB Corsair Dominator GT 2GHZ | 3-Way SLI GTX580| 2.5 TB Hdd | Corsair Obsidian 800D| Corsair AX1200W | Custom WC
    Obsidian 800D Thread
    AKA Arne-Mohammed and X-Force
    sorry for bad English, I´m from Sweden
    Apr 2010
    hell yea! im actually curious as to how well the two GTX480's work with a water cooling loop keep us posted!
    Apr 2010
    Quote Originally Posted by Ogge_swe View Post
    I had original purchased a few rotary fittings, but after reading about the leaking potential I decided to ditch the idea. What you are seeing on my cpu block is a combination of 45/angle, and 3/4OD compression fittings.
    Apr 2010
    Boston, MA
    Did you spray paint the case or was it powder coated?
    Silverstone TJ07, Asus P6X58D Premium, i7 920, 3x2GB Corsair DDR3 1600 C7, 2x WD velociraptors 150GB RAID0,
    Hitachi 500GB SATA, EVGA GTX280 Ocd, Thermaltake Toughpower 750W; ViewSonic VX2835W 27.5" LCD.
    Blocks: EK Supreme HF, EK NB/SB 5, EK Asus X58 Mosfet Kit
    Rad: Swiftech MCR-420
    Pump: Swiftech MCP-355
    Res: XSPC Dual pump Bay (for future GPU expansion)
    Tube: Primochill PrimoFlex PRO LRT 7/16"; 5/8"
    Fittings: 1/2" BP, EK
    Fans: 7 120mm Coolermasters push/pull on Rad
    Fan Cont: Kaze server
    Apr 2010
    It was spray painted, and came out pretty crappy up close, all the parts you will actually be looking at came out fine though. The first can of spray paint went on terribly and left a lot of powder/type particles, so I sanded it quickly and applied another coat with a different brand, then used an acrylic/clear coat.
    Apr 2010
    Added some pictures of the window mod. Boy what a tough time I had putting that biatch in... I hadn't realized the hole was a tad to small and I tried for literally hours, eventual cut the whole bigger and with the aid of a bunch of Windex I managed to get er' done. Also added progress pictures of the fan shrouds taking shape.
    Aug 2006
    Tokyo, Seattle
    Quote Originally Posted by DoggRoger View Post
    What leaking potential?
    Apr 2010
    to help get a good finish on spray painting i heard it helps to put the cans in hot water for a few minutes as this thins out the paint molecules and produces and even fine spray. duno though its problaby to late now
    Aug 2007
    Sweden
    It's gonna be tight! Nice job so far =)
    Loonym...You are missed.
    The element of one
    Breathe me in
    Breathe me in
    I disbelieve in separation. I close my eyes to see you.
    This is for you, everything I am. This is for you, take it from me.
    I, I disbelieve separation. I close my eyes
    there's no escaping me
    In your heart in your soul. I perceive rejuvenation
    Breathe me in. I am forever. Deep within I am eternal.
    I will return to you. I am with you always. I will never turn away from you.
    Apr 2010
    Quote Originally Posted by makavelijm View Post
    Good to know, I will try that in the future.
    Quote Originally Posted by Antioch View Post
    I know.. that's how I really want to feel, but after searching around the forums for "rotary leaking" I got an uneasy feeling about the whole thing..
    http://www.xtremesystems.org/forums/...hlight=leaking
    Thanks for the comp, it's probably the most "Xtreme" PC build I'll ever do.
    Apr 2010
    Woot, finished the 6 airboxes, updated with pics. Will have a full day of assembly tomorrow.
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    watch out for the bitspower crystal T they crack, thats why they are so cheap compared to the metal ones. on my 1st build for myself (also in a p180) the crystal t i had for a T-line cracked affter 2 weeks with no signs on ill effects or cracks when i gave up on checking affter a week. then affter turning my pc off one day my floor and the bottom of my case was flooded were the computer was
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Apr 2010
    Damn, not good news but I believe you I was a bit shaky after handling them.. guess i'll put an order in for the metal ones, thanks for the heads up.
    Jul 2007
    SF bay area, CA
    here is how it ended up
    it cracked more when i took the barbs out but it leaked at hand tight so i did a little over an eighth of a turn and it didnt leak but then there is the result. it has a huge crack down the seam then as that split the other cracks came in.
    Apr 2010
    Yup, thanks again for the heads up, I have some all metal T's heading my way. Too bad I painted the crystals otherwise I would return them.
    Oct 2009
    Nice joob
  18. #18
    Apr 2010
    Thanks man. CPU/mobo loop is finished and pics updated, still have to tighten and leak test. Im waiting on a few more parts to arrive before I can finish the GPU loop. I should have named the thread title Behemoth because the this thing is huge, it reminds me of a transformer, but I'm liking it.
  19. #19
    Apr 2010
    So, just about done, I found that my rig draws 890watts from the wall without OC'ing the GPU's so I have a Silverstone ST1500 on the way, once it comes and I get it installed that will be the final straw.. This is the jist of the finished product.. the H2O is not finished yet.. I just put some UV Green up for the time being to demonstrate what I am trying to achieve.
    Also I found 1 of my SlipStream is not spinning on my MCR320 so once I get my ST1500 I'l mess around with it.. but the GPU temps idle at around 38-39C,(ambient 26C) and hit 60C after an hour of furmark, I highly doubt that plugging in the Slipstream will drop the temps. My 920@4010mhz/1.39v idles at 42C/66-67C under load.
    I have a lot more testing to do.. the temps above where like real quick pluggin it in and checking.. Im going to play with the fan settings and noise ratio to find a sweet spot.. I personally am pretty happy that my GPU's won't break 60C Curious to see how much higher it will go when I OC the GPU's.. will keep it updated.
  20. #20
    Nov 2009
    Netherlands
    The radiator on the back looks like it's defying gravity !
  21. #21
    May 2009
    Waikato, New Zealand
    That is an insane amount of radiator for a P180!
  22. #22
    Apr 2010
    Quote Originally Posted by Alexandr0s View Post
    It's leaning because I used rubber grommets for vibration noise reduction and I need to re-tighten the nuts within the case holding it on, but it's quite sturdy.
    Quote Originally Posted by V0id View Post
    I don't know if it is.. many other systems I see have more radiator surface area, but it has been serving my purpose well, we'll see what clocks I can run my cards at once my new PSU arrives.
