Results 1 to 25 of 64
Thread: Gigabyte 5870 SOC
Threaded View
    World Champion - IRONMODS
    Sep 2007
    Northern Japan
    Gigabyte 5870 SOC
    Please use the following mods at your own risk. Nobody here is responsible for damages done!
    Credit to BenchZowner for the mods here....thanks Bill
    Simple FB mod: ( corrected!)
    Measure the resistance between the circled resistor and a ground and connect a VR ( trimmer ) 20 times the resistance measured.
    VID mod:
    Check the VRD11 codes for the On Semiconductor ADP4100 from the PDF - http://ceemic.pri.ee/hardware/datasheets/ADP4100.pdf [ nice library Ceemic ]
    And move the resistors to the proper locations ( logic high (1) or logic low (0) ).
    Logic high = front side of the card
    Logic low = rear side of the card
    photos:
    VID Low ( 0 ) - rear side
    VID High ( 1 ) - front side
    You have 7 resistors, you have to place 1 resistor for each VID bit ( VID0, VID1, VID2, VID3, VID4, VID5, VID6, VID7 ) to High ( 1 ) or Low ( 0 ) depending on the voltage you want to apply ( according to the ADP4100 datasheet ).
    If you leave a spot open ( not connected via a resistor ) on both Low & High it will be considered as Low ( 0 ) by the PWM controller.
    OCP Mod:
    You can mod the card ( add a LED ) to monitor OCP, or use an oscilloscope
    If OCP/OVP kick in your GPU's voltage should be 0.3x after it crashes or hangs.
    Application - 5870 SOC Tuner beta:
    http://www.benchzone.com/Downloads/T...70socTuner.rar
    WORKS FINE FOR E.S. cards
    FOR RETAIL CARDS GPU Core Voltage ( Vgpu ) DOES NOT work
    The other voltages ( Vmem, Vpcie, Vddci ) WORK FINE WITH BOTH retail and E.S. cards.
    Quote Originally Posted by Massman
    My definition of 'efficient' is 'it does not suck monkeyballs'. Yes, I set bars low.
    [CENTER]The post counter is not an intelligence meter!
    MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
    Heat Team IRONMODS
