Hey guys,
Just got my lightning today and it also clocks like crap! cant actually get past 940 on the gpu no matter what voltage or tweaker setting i use?!
i assume the card applys the voltake threw afterburner (1.5.1) because with voltage monitoring enabled i can see voltage bumping up. dont have a multi meter to test if voltage is really applyed.
What about the hint with the spacers?? seemd to work for some people?? or should i rather flash a newer bios on the card??
Was really hoping to get good 1000 on the gpu with smooth voltages. my old 5870 from XFX couldnt get past 975 unless i used extreme voltage. but then again temperature was holding me back.
Could really use some help!
Edit: im also having sort of an odd flickering on the display when i apply any other clock speeds then the default ones???
Edit 2: Tried to flash Massmanns (hwbot) bios. still no luck! card wont clock better at ALL!!! cant be true that those cards are such blenders?? only hope for me right now seem to be the spacers. can anyone in here give me an advice on how to do that?? never unmounted any of my graphics cards fans. How thick should the spacers aprox. be?? wich (thick/rather thin type of paste) & how much thermal paste should i apply when remounting the fan? In case i wanna send the card back within the first 7 days would it be a prob if i unmounted & reapplied the fan?
Edit 3: Ok after trying to flash different bioses (hwbot & the one from techpowerup) several times still no improvement. another strange thing is that when looking at the bios strings after flashing with atiflash they always have the same version numbers?? i mean either all bioses im flashing are actually the same (including the one that was on the card already) or atiflash is simply not applying the flash?? For the flickering issue i have now realized that it immediatly starts when i alter gpu clock & have a program running full screen that doesnt have a lot of gpu usage. for example the cpu & phys x tests from ventage. when running them the cards voltage falls back to 2d clocks resulting in odd flickering.
the chip on my lightning does 940@default (1,164) but everything above 940 is impossible to get stable. no matter which voltage i apply or bios i use. i assume something is holding the card back from performing the way it could but cant figure out what it is. msi hotline support is also wack. they cant even send me a beta bios. starting 2 go nuts here..
Any suggestions???
), Juan J. Guerrero
) it'll be fine.
!! Before temps went over 89 degrees while fans were doing 100%)
