Results 1 to 5 of 5
Thread: i7 980X shows 4 cores instead of 6 cores
    Apr 2010
    Hi all, i've updated the newest bios but my 980X still show only 4 cores , any advice?
    CPU: 2x Xeon 5680 @ 4.30 GHZ
    RAM: 12GB Corsair Dominator GT
    Mobo: EVGA SR2
    VGA: 3-way SLi GTX580
    LCD: Dell U3011 + Dell Ultrasharp 3007WHP-FC
    PSU: Corsair 1200AX + Corsair 1000HX
    Cooling: Custom WC
    Jan 2008
    Chicago, IL USA
    If using Win 7
    This seems like a somewhat common problem in Windows 7, the solution I've seen most often successful is:
    1) Start > Msconfig
    2) Boot Tab > Advanced Options
    3) Manually Select 12 processors and reboot.
    [IMG]
    Apr 2010
    Yes, you are right. Thanks very much man
    Mobo: EVGA SR2
    Cooling: Custom WC
    Apr 2010
    Clearwater, Fl
    And just an FYI some people have said they don't have anything more then 4 cores as on option in the drop down box so Unchecking the number of processors box normally fixes the core issue after reboot.
    New Rig in Development
    Current Rig: i7 950 (HK 3.0 CU Block) : ASUS WS (Koolance Blocks) : eVGA 295 GTX CO-OP (Swiftech Full card Block) : 6GB Corsair Dominator XMP memory : Highpoint 4320 raid card : 4x 128Gb SuperTalent MasterDrive SX's (Raid 0) - OS : 2x 300GB WD Raptors (Raid 0) - Caching Drive : D5 pump with Bitpower top running to 360 rad for CPU & MB : MCP355 with XPSC Res Top to 120mm rad for GPU
    Mar 2007
    Or number of processors---All
    I would have replied sooner but the compression explosion device in my motion traction system needed to be replenished with distillation fractionation of fossilisation extraction....
    (a SoddemFX original)
    Classified 760A1 (49)
    980X
    CMG4GX3M2A2000C8 12g
    EVGA GTX 295
    Syncmaster 305t
    XM25-MG2 160 X2 Raid 0
    300G Raptors X2 Raid1
    Galaxy 1000w
    Win 7 Ultimate
    800D 120.3 & 120.2 HeatKiller, Bitspower and MIPS
