Results 1 to 18 of 18
Thread: Retail 980X with Gigabyte board plus...
Threaded View
    Apr 2008
    Hong Kong
    It seems it is my first new thread here.
    Got a retail i7 980X for 2 days, with some overclock tested on a non retail board.
    I brought it because it has a impressive low voltage compare with other LGA1366 CPUs I never seen before.
    My config
    Intel core i7 980x
    Gigabyte GA-X58AUDxxxx
    Kingston 2000CL8
    Antec TPQ-1200OC
    OCZ Vertex Turbo
    Cooling: water (D-Tekv2 + blackice GTS360 single pass + D5)
    First, lowest uncore test (seems some board not adjustable)
    seems my config can only run DDR3 1600 with x13 uncore
    3000MHz uncore is lowest for DDR3 2000
    Then some basic bench
    4.4G wprime 32M, 1024M
    4.8G wprime 32M
    With a 5G CPU-z validation,
    I know someone can did it with higher result on water too before
