Results 1 to 12 of 12
Thread: Toys for testing are fun...
    I am Xtreme-ly Unemployed
    Nov 2005
    Palmdale, CA USA
    Well, I've finally gotten the most recent iteration of my CPU waterblock test system together... fun stuff. Photos, a few details, and a somewhat incoherent video tour are below.
    Sleep deprived video tour: http://www.youtube.com/watch?v=8OwoygkGKNs
    I plan on using the system to run through and test most of the blocks in that drawer, with my goal being to put together a reasonably comprehensive library of CPU block performance data (ranging from old blocks like the WhiteWater to the latest stuff on the market) all gleaned from the same test system and, therefore, directly comparable (also somewhat more relevant, due to the presence of a soldered IHS). I'm not going to go too far into the details right now since I'm pretty tired and will likely botch any sort of explanation of what I've been up to for the past five years... lol
    With that said, here's what's on that table covered in stuff:
    - Omega FL-1504A-B flowmeter
    - Sper Scientific 840081 manometer
    - Extech EA15 data logging thermometer
    - Volt-modded Asus P5K Deluxe
    - Instrumented Intel E6400 (details on the process can be found in an early test run that I did with some heatsinks back in 2008 here...I've learned even more since then and have some new tricks up my sleeve)
    - Iwaki RD-30 pump
    - HW Labs BlackIce GTX480 radiator
    - (8) Delta EFB1212HHF fans
    ...and some other junk you probably don't care about.
    Anyway, this is still going to be the first time I've released this sort of waterblock data to the public... I'll be whipping up my usual battery of pressure drop curves, deltaT (and, perhaps, thermal resistance) curves, as well as maybe gauging overall performance as a function of thermal resistance vs. pressure drop...or something like that.
    Time for sleep....
    I'm doing science and I'm still alive...
    Xtreme Mentor
    Oct 2007
    USA
    So very cool. The table must go from Cali to NMexico. Looking forward to your input. Should be enlightening and fun. Make sure a PT pen is in each pic for that warm fuzzy feeling.
    Miss you guys................
    All stock for now, no need for more, but it's gonna be soon methinks.
    Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
    SLI GTX470 EVGA
    EK HF nickle blue top CPU block (free from Eddie)
    Koolance 470 waterblocks
    One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
    Banchetto Tech Station
    120 GB SSD, and a few other drives.
    1000W UltraX3 PSU, 900 watt (1500VA UPS
    23.999" Acer GD235hz and 24" Acer H243H
    Dec 2007
    Iowa, U.S.A.
    Ok....you have me jealous now, for having the time to do that sort of testing, and for being able to play with those toys. Nice stuff!
    Quote Originally Posted by armeniandave View Post
    It takes a lot of work to make something look simple!
    Understatement of the year!!!!
    Jun 2009
    San Diego, CA
    It's too clean, much too clean.
    If you don't like what I have to say, please feel free to ignore it. I do!
    Core i7 920 (D0) @ 4.0Ghz, P6T Deluxe V2 (0901), 12GB Corsair CM3X2G1600C7 @ 1600 7.7.7.20 2T, ATCS 840, Antec TPQ 850, Radeon 4850, TMS-200 + TMS-EB200, EK Supreme HF, EK-D5 dual top, 2x MCP-655-B, MCR-420, 7X Skythe D1225C12B5AP-15, Durelene tubing. Obviously not a gamer as you can tell by the low end video card.
    Feb 2009
    Carson City, NV
    I don't see nearly enough discarded pizza boxes lying around propping up furniture. You must be doing it wrong
    i7 2600k, 8GB 1866Mhz DDR3, GTX560 Ti, Gigabyte Z68XP-UD4, CM Cosmos 1000 Case, and some green crap everywhere.
    Quote Originally Posted by Alexandr0s View Post
    So you're saying I could use my own pee as coolant?
    Nov 2005
    Palmdale, CA USA
    Quote Originally Posted by Groveling_Wyrm View Post
    I have more time for it now than ever before, but I'm pretty sure you wouldn't be jealous of the circumstances.
    Anyway, this setup sure beats the hell outta the first two or three generations of my test system
    Unoriginal Macho Energy
    Dec 2002
    It's about time Can't wait to see some data!
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
    Moderator
    Aug 2007
    Back and forth between Florida and Maine
    Looking forward to seeing your results. Thanks for sharing.
    I am Xtreme
    Feb 2007
    Quote Originally Posted by Petra View Post
    whatever the circumstances, I hope all is well and that you excel in your endeavors as you really deserve it (based on all that you have given to our community).
    "Thing is, I no longer consider you a member but, rather a parasite...one that should be expunged."
    Mar 2009
    Great stuff !
    BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
    Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
    Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
    Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
    Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
    KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
    Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
    Nov 2005
    Palmdale, CA USA
    Quote Originally Posted by nikhsub1 View Post
    Well, first I have to take an educated guess as to which of these is going to be the worst performer and use that block to determine what my test heat load is going to be:
    From left to right:
    - Koolance CPU-330
    - AquaXtreme WhiteWater LE
    - DD TDX
    - DD RBX
    - Silverprop Cyclone Evolution SE
    - Original Swiftech Apogee
    - Swiftech MCW6002
    - AquaXtreme MP-1 CPU
    - Swiftech Storm G4 (Rev.1)
    - Swiftech Storm G4 (Rev.2)
    - AquaXtreme MP-05 SP LE
    - Swiftech Apogee GT
    - XSPC Delta v3
    - D-Tek FuZion v1 (stock)
    - Enzotech Sapphire (Final--not the early, thick-based one that they sent me for evaluation prior to launch)
    - Swiftech Apogee GTX
    - D-Tek FuZion v1 (w/mods... nozzles, washer, etc.)
    - D-Tek FuZion v2
    - EK Supreme
    - Swiftech Apogee GTZ (not pictured)
    I have a couple other blocks that I'm not going to bother testing and I'm still on the fence about the Koolance CPU-330. The trick here is going to be balancing my desired level of comprehensiveness with usefulness... because the worst block that I choose to test is likely going to be my limiting factor as far as heat is concerned. Obviously, the higher the heat load I test at, the larger the data spread is going to be, and the better the overall accuracy (since it'll help push the differences between blocks out of the margin of error).
    I could break things into two heat load categories so that I can gather the best data possible for the more modern blocks... but I'd prefer to keep things as directly comparable as possible (then again, if I do a final comparison chart using estimated thermal resistance, it may be okay... hmm).
    At some point, I'm also going to have to beg for/borrow the latest blocks for testing (Heatkillers, new Koolance stuff, Apogee XT, etc.)...
    Quote Originally Posted by DarthBeavis View Post
    Thanks, I really do appreciate that
    Xtreme Cruncher
    Sep 2005
    Bay Area, CA
    Seems like some one is having a lot of fun...
