Results 1 to 23 of 23
Thread: G38 Bios for Bloodrage and sas firmware
    Jul 2008
    ok some more bios
    http://www.ex3clan.com/foxconn/Foxco...1-8A1F1G38.zip
    1. Update CPU micro-code for Server and Desk Top Gulftown CPU, stepping B1 CPUID:206C2h Patch ID 0Ch.
    2. Update CPU micro-code for Nehalem-EX CPU stepping D0 CPUID:206E6h Patch ID 05h.
    1. Modify "B2B CAS Delay" item value from "Auto,3T to 31T" to "Auto,1T to 31T",
    Set to Auto the value equal to 0T.
    so that is all of B2b open for you and intel spec was only from 3t
    for 0t use auto
    sas firmware latest we have got
    http://www.ex3clan.com/foxconn/Foxco...mware/6320.zip
    this may now fix the problem for one person but
    well have fun
    Apr 2004
    Thx a bunch you Rox!!!
    Nov 2008
    Heart of Europe
    Whoa.. time to check 0T.
    i7 930 D0 - 4,2 GHz + Megashadow
    3x4GB Crucial 1600MHz CL8
    Foxconn Bloodrage rev. 1.1 - P09
    MSI HAWK N760
    Crucial M500 240GB SSD
    SeaGate ES.2 1TB + 1TB External SeaGate
    Corsair HX 850W (its GOLD man!)
    ASUS STX + Sennheiser HD 555 (tape mod)
    Old-new camera so some new pics will be there.. My Flickr My 500px.com My Tumblr
    Jan 2009
    Poland
    SAS how to install the firmware?
    Jul 2008
    copy the files to a dos boot device and run X58A01.bat
    Like a bios or anyother firmware you have to do in dos
    thanks
    Jan 2009
    Poland
    Quote Originally Posted by Lord Trident View Post
    thanks
    I installed the firmware for the SAS Blodrage and now I have an error.
    MARVELL 88SE63xx/64xx Adapter - bios version 3.1.0.2400
    ERROR: Bios data error!
    What do I do now?
    Jul 2008
    when you get the error as your screen shoot does not show
    Jan 2009
    Poland
    How do you get this error all the stops.
    Please give me the old firmware.
    Jul 2008
    no............
    you did not say please
    http://www.ex3clan.com/foxconn/Foxco.../old%20sas.zip
    Jan 2009
    Poland
    I said please.
    I installed the old firmware. It works fine.
    My adapter is probably the 6440.
    The new firmware does not include the 6440 file.
    Please correct.
    Jul 2008
    can you please recheck the chip on your board
    it should say 88SE6320-TFJ2
    as that the only chip i know of if it not that then i got problem lol
    thanks
    Jan 2009
    Poland
    thanks
    My czipset:
    Jul 2008
    yep that the 6320 and not 6440
    i will check again to see why you had a problem
    Jan 2009
    Poland
    Old firmware work ok!!
    Maybe there is a bug in the new firmware? I wonder if someone already installed it? Sorry for my English.
    Feb 2010
    How does one disable B2B if you can't find a stable setting? Does Auto=0, 0=off?? From what I can tell prior to this B2B is disabled in the BIOS entirely? I ried CPU-Tweaker to see if I could test some B2B settings in windows before flashing to this BIOS but it does not seem to work with the Bloodrage.
    Nov 2008
    Heart of Europe
    You cant disable that, its like if you want disable CL setting.
    B2B at 6+ should be like 100% stable for most systems.. (at least 6 is apparently default on mine as I get exactly same results from P09 and G36 set to B2B 6).
    Well, and you have two BIOS chips, soo use second and flash it to P10 or P09 if you need to?
    MSI HAWK N760
    Apr 2005
    Got this running bios running on my gti ok.
    I have my ram running @DDR3 2000
    What is everyone finding the most stable setting is for the B2B CAS Delay at the moment? For me at the moment its a toss up between 4 and 6 at the moment. Just trying to find the right one. Have to say it does effect stability if on the wrong settings it seems!
    Would be really interested in know what other have set it to.
    * Foxconn Bloodrage GTi *
    * Intel i7 920 DO @ 4.2Ghz*
    * Custom 120.2 Watercooled *
    * Patriot Viper II 6GB *
    * ATI XFX 5970 BE *
    * Lian Li PC-A71B *
    * Corsair HX 850W *
    * OCZ Vertex 120GB *
  18. #18
    Nov 2008
    Heart of Europe
    Sure its meant to affect stability. But also affect performace, as usually when one tinker with BIOS.
    MSI HAWK N760
  19. #19
    May 2009
    GERMANY
    G38 works really fine, needing 20mV less VTT for same clock Thanx Lord Trident!!!!
    DESKTOP:
    Lian Li V1020B/ ..::FOXCONN BLOODRAGE::..
    Core I7 920 D0 @ 21x200 / Corsair 6GB DDR3-1600 / 2x Zotac GTX580 3 GB @SL! / 1x Crucial C300 256 GB / 2x Seagate momentus XT / 1x WD 2000 GB / Enermax Platimax 1200W / Win 7 64
    Wakü: Watercool Heatkiller 3.0 / MO-RA 4x180 LT / Watercool Heatkiller GPU-X³ Laing DDC-1Plus @ Aquaero
    LAPTOP:
    Clevo (Guru) M860TU 15,4"@1680x1050 / intel Q x9200 ES 2,4 GHz / nVidia 260m GTX / 4GB DDR3-1066
  20. #20
    Apr 2005
    Quote Originally Posted by mocker View Post
    What B2B setting you using?
    * ATI XFX 5970 BE *
    * Lian Li PC-A71B *
    * Corsair HX 850W *
  21. #21
    May 2009
    GERMANY
    still 6, but testing now, btw i can reduce VTT even 30mV
    DESKTOP:
    LAPTOP:
  22. #22
    Feb 2010
    I'm using B2B of 3 with no problem, the strange thing is it works on 6 fine but 4 will fail almost instantly (Can't even load Windows)
  23. #23
    Aug 2010
    Quote Originally Posted by lysyn123 View Post
    Please correct.
    I did some tests recently with my new raid setup - 2xWD6000HLHX. With stock Marvell SAS firmware v3.1.0.16 it was complete failure. You cannot save created raid volume in bios interface of SAS controller and if you create it from within Marvell software in Windows - after restarting there is no raid volume at all! In this thread I found your negative results with firmware v3.1.0.24. So I searched and found on the Asus forum one different firmware - v3.1.0.23. After quick boot in MS-DOS and easy flash from command line ("mvf 0827.bin") now I have a fully functional SAS with a couple of WD6000HLHX. During the flashing process it says "6440", but it's not correct - the chip is exactly 6320.
    PS. Attached v3.1.0.23 SAS firmware.
    Attached Files Attached Files
    ASRock 990FX Extreme4|AMD FX-8320 w/water|OCZ3RPR1866C9LV4GK|XFX HD5850|WD6000HLHX|PC P&C Silencer 910W
    Foxconn BloodRAGE X58|Intel Core i7 920|G.Skill F3-16000CL9T-6GBTD|XFX HD5770|WD6000HLHX|PC P&C Silencer 750W
