Results 1 to 12 of 12
Thread: Review - Danamics LMX
    Jun 2005
    Portugal
    It seems that the Review is finally ready and have some great results to show you
    Test Platform:
    Fonte: Chieftec CFT-750W-CS
    Board: Asus Rampage Extreme II
    CPU: Intel Core i7 975 EE
    Memorias: G.Skill Ripjaws CL9 2000Mhz
    Grafica: Sapphire 5970
    Pasta Térmica: Prolimatech PK-1 Thermal Compound
    Cooling systems that were tested and compared with Danamics.
    Air Cooling:
    Stock Cooler I7 EE,
    Prolimatech MegaShadow (SilenX 2000rpm 120mm)
    Water Cooling:
    Bomba: Swiftech Laing MCP355
    Radiador: TFC Feser Quad Radiator 480
    Bloco: Swiftech Apogee GTZ
    Tubo: 3/8
    Reservatório:AlphaCool Cape Coolplex 50
    Feser One Black
    4x Coolermaster 120mm
    Danamics LMX specification
    Product name Danamics LMX
    Heat-sink material Nickel-plated aluminium
    Tubing material Nickel-plated copper
    Housing material Plastic
    RoHS Compliant Yes
    Dimensions (LxHxD) 158.2 x 170.5 x 90mm (heat sink only)
    Motherboard clearance height 30mm
    Weight 1180g (heat sink only)
    Processors supported All AMD(TM) processors for Socket AM2/AM2+/AM3
    All Intel® processors for Socket 775/1156/1366
    Ambient operating temperature range 0°C to 45°C
    Liquid Metal type: Sodium Potassium (NaK)
    Electromagnetic pump specification
    Power consumption Less than 1W
    Magnet type Neodymium Block Magnet
    Gauss Rating, 0.05m, xyz axis 12 Gauss (0.0012 Tesla)
    Fan-compatibility 120mm fan with 25mm thickness
    Fan specification
    Dimensions (LxHxD) 120 x 120 x 25mm
    Speed 2000 rpm
    Airflow 75.7 CFM
    Noise Level, 1m, x y z axes - average 21.8dBa
    Noise Level, 1m, z axis 28.6dBa
    Operating Voltage 6.0 - 14.0V
    Current draw 0.30A
    Power consumption 3.6W
    Bearings FDB, Fluid Dynamics Bearings
    PowerBooster
    The electromagnetic pump in the cooler requires power in order to circulate the liquid. For powering the pump, Danamics offers the PowerBooster, which converts power from the systems power supply to the electromagnetic pump. The PowerBooster is prepared for mounting in a 3.5 inch disk drivebay, however the unit requires two drivebay slots due to its height.
    PowerBooster specification
    Dimensions (LxHxD) 146 x 52 x 101mm
    Weight 600g
    Power connection Standard IDE-hard drive connector
    Power input 12V DC ±1V
    Current output 30A ±2A
    Operating temperature range 0°C to 45°C
    Then pass the pictures of this bead.
    The details of the package is something fantastic, it seems that we buy a new car
    Detailed manual and assembly instructions for all Sockets
    One of the details of which I liked most were the clips fit the fans that unlike other coolers such as Noctua Prolimatech and are horrible with that wire, the fans in Danamics glide smoothly across the cooler and then trapped in place by a small yellow clips easy placement and removal
    PowerBooster
    Weight 600g
    And here's the part that makes the miracles happen, responsible for movement within the Liquid Metal Cooler.
    That's right folks the Cooler looks great is not it?
    But it's still bigger than it looks
    Look in there beside the MegaShadow
    I was truly in love with this boy, and performances such as go to see are amazing.
    Come to testing then:
    The tests were made in previously filed coolers and frequencies:
    3300 Stock
    3900 1.3Vcore
    4500 1.4Vcore
    4750 1.4Vcore
    Concl:
    As you can see we have a cooler to a size of another level.
    Temperatures excellent ability to meet Mhz's spectacular.
    Ok Ok, the price, yes and carotid, but the quality is paid and nothing else.
    The Top of the Tops in Air temperatures have walked right by the temperatures of water and note that the water system is a system of top 480 with radiator, pump, high performance and a very good block.
    Here is an excellent alternative to the WaterCooling.
    A thank you will Danamics and Nissen and availability throughout.
    I Am "PcCoolado With pride with Much Love !!!
    I am Xtreme
    Mar 2007
    Kavala , Greece
    Nice review and very good results for the cooler. Do you know if this model is better than the new Danamincs LMX Superleggera?
    Intel Core i7 930 @ 4.1 GHz (196x21 - 1.28v)
    Corsair H50 (2x Noctua NF-P12 in Push/Pull)
    Asus P6T Deluxe/OC Palm Edition
    Asus 4870x2 (Stock)
    3GB G.Skill DDR3 PC3-12800
    3x Seagate Savvio 15K 36GB in Raid 0 on Perc 5/i
    2x Samsung Spinpoint HD501LJ in Raid 0
    2x Western Digital WD6400AAKS
    Creative SB X-Fi Elite Pro series / Logitech Z-5500 THX
    Razer Lycosa Mirror Edition / Razer Lachesis
    Coolermaster HAF 932
    Enermax Revolution 85+ 1250W PSU
    HP LP2475w
    Jun 2005
    Portugal
    i was told by the danamacis guy that the performance was the same...
    Apr 2008
    Australia
    its good to see them getting it right this time around.
    Thanks for the review
    [SIGPIC][/SIGPIC]
    Jul 2009
    have you tried using it passively yet?
    I read a review on it running passive and it could cool an i7
    link
    i7 920 @ 4GHz 1.25v
    GTX 470 @ 859MHz 1062mv
    Nov 2008
    Heart of Europe
    Its still air cooler, running it passive is not good idea, unless you run stock fq and volts.. (Megashadow can cool that, tested.. but you need bit of airflow in case, so its not 100% passive).
    It work as pump, cooling loop and radiator in one nice package.. Would be interesting to see that with 2000 RPM high pressure fans.
    Is it possible to mount thicker fans on that?
    i7 930 D0 - 4,2 GHz + Megashadow
    3x4GB Crucial 1600MHz CL8
    Foxconn Bloodrage rev. 1.1 - P09
    MSI HAWK N760
    Crucial M500 240GB SSD
    SeaGate ES.2 1TB + 1TB External SeaGate
    Corsair HX 850W (its GOLD man!)
    ASUS STX + Sennheiser HD 555 (tape mod)
    Old-new camera so some new pics will be there.. My Flickr My 500px.com My Tumblr
    Jul 2009
    Quote Originally Posted by Mescalamba View Post
    well in my link they run 4000rpm Delta's on it so I'd say yes, although they're only 1C better than 2000rpm SilenX
    i7 920 @ 4GHz 1.25v
    Jul 2009
    Less than a couple of degrees better than a Megashadow but three times more expensive? How can you recommend that? Not to mention the Noctua NH-D14 will walk all over this for half the price.
    I mean its alright to be thankful for getting one sample but its no cool to over-praise the thing.
    Jan 2007
    thanks for posting the review,was hoping to see one here at the forums.
    about the cooler my couple of points:
    - too expensive
    - only a couple degrees better than a good high end cooler such as the MS/Vx
    - i dont get the message why it should be covered in plastic entirely
    - has an additional part(lm pump)which needs additional care(cabling,electricity,can stop working at some point eventually)
    - sounds so cool Liquid Metal like in the Terminator,pure SF
    "Generally speaking, CMOS power consumption is the result of charging and discharging gate capacitors. The charge required to fully charge the gate grows with the voltage; charge times frequency is current. Voltage times current is power. So, as you raise the voltage, the current consumption grows linearly, and the power consumption quadratically, at a fixed frequency. Once you reach the frequency limit of the chip without raising the voltage, further frequency increases are normally proportional to voltage. In other words, once you have to start raising the voltage, power consumption tends to rise with the cube of frequency."
    1st
    CPU - 2600K(4.4ghz)/Mobo - AsusEvo/RAM - 8GB1866mhz/Cooler - VX/Gfx - Radeon 6950/PSU - EnermaxModu87+700W
    2nd
    TRUltra-120Xtreme /// EnermaxModu82+(625w) /// abitIP35pro/// YorkfieldQ9650-->3906mhz(1.28V) /// 640AAKS & samsung F1 1T &samsung F1640gb&F1 RAID 1T /// 4gigs of RAM-->520mhz /// radeon 4850(700mhz)-->TRHR-03 GT
    3rd
    Windsor4200(11x246-->2706mhz-->1.52v) : Zalman9500 : M2N32-SLI Deluxe : 2GB ddr2 SuperTalent-->451mhz : seagate 7200.10 320GB :7900GT(530/700) : Tagan530w
    I am Xtreme
    Dec 2008
    France
    Just as good as VX, which is pretty impressive!
    Thanks for posting!
    Donate to XS forums
    I am Xtreme
    Dec 2008
    France
    Thanks for posting!
    Donate to XS forums
    Apr 2005
    Porto, Portugal
    Quote Originally Posted by Helloworld_98 View Post
    link
    Nonestly we did not tested it passivly, cause the review was to compare with other coolers in the market, and, none of them has the LMS that Danamics has, so it would be impossible to do so
