Results 1 to 14 of 14
Thread: GTX285 running at PCI-E 2.0 16x @ x4 help needed.
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Question GTX285 running at PCI-E 2.0 16x @ x4 help needed.
    Guys i have a problem and i would like some help to fix an issue with a GTX285. Ok here goes the story , this is a BFG OCX GTX285 1GB Rev.1 , i bought this card the first day they came out so its already quite old. The card its volt moded via vid bridges pins and i have conected them via solder to get 1.3v. its been like that for over a year now. This card was completely dead after a long LN2 session months ago, but i was going thru my big pile of dead hardware and i thought of re-testing the card before going to the trashcan, i cleaned all the sticky armaflex on the back and front of the card as much as i could , i removed the clear coat of nail polish that i applied to the card too as well as all the vaseline on the card. The card was looking like brand new after been hooked to a TeK 9 gpu pot for 5~6 months , i clean it up really good . I use MX2 on the core and the same pading that came from factory for the memory , installed the stock cooler and place the card on an old Asus P5B Deluxe P965 Mobo and voila , Bingo , woow the card post it right away and came back from the death , boot into windows and i installed latest whql drivers 197.13 rebbot and awsome the card its working flawlesly im happy until i opened GPU-Z and oh sh*t the card its running at pci-e 16 @ 1x , i reset it the card , uninstalled and reinstalled drivers again , i boot in windows and now the card its running at pci-e 16 @ 4x ,i said to myself well its a software problem and here i went flashing the card with an evga FTW Bios wich runs aboslutly great on this card , flash was done succesfully. re-tried the card again with new Bios and guess what the card still running at pci-e 16 4x. I tested in another mobo eVGA 790i Ultra and yep you guessed it right the freaking card its running at pci-e 16 @ 4x. I have troubleshoot until not available but i cannot get the card to run at the full pci-e 16 @ 16x. Please help this poor soul out , im getting frustrated because the card runs flawlessly in games and overclocks like crazy and stable for benchies even on stock cooler , but the results are very low because the card its been bottleneck by the pci-e 16 running all the time at pci-e 16 @ 4x , any ideas , help , guidance will be trully appreciated , i would like to fix this card to use it in my 24/7 gaming rig. Thanks in advanced.
    Regards: Chispy
    By chispy at 2010-04-02
    Sep 2009
    InDiA.x GhY
    Buddy clean ur pci-e slot of mobo with ear-bud with little isotope & let it dry ... check again if it works @ x16
    Clean the pci-e pins of ur GFX card with rubber .....
    Mar 2008
    Pennsylvania
    The only thing I can think of is try cleaning the PCI Express connector. I would think rubbing alcohol would work nicely.
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Thanks for the feedback guys , cleaned already both the pci-e slots on both mobos with alcohol and the card pci-e pins with rubber and with alcohol , still running at x4 . appreciated the help.
    Mar 2010
    nicaragua
    spray with contacs cleaner ur pcie slot , let it dry . or leave ur mobo with out de battery few hours
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Smile
    Quote Originally Posted by IvanG View Post
    Thanks for the tips , appreciated.
    Buen Dia
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Thank you guys for trying to help , i appretiated much. I have fixed the card , it was an easy fix. Heres how i did it:
    By chispy at 2010-04-04
    By chispy, shot with FinePix A340 at 2010-04-04
    Xtreme Cruncher
    May 2008
    Guatemala
    Loool, you should look up for some anger management courses dude xD, altough I did the same with a mobo some days ago, it feels great.
    AMD FX 8350 @ 4.4Ghz
    Corsair H60
    Gigabyte GA-990FXA-UD3 AM3+
    8GB Mushkin Blackline @ 1800Mhz
    Sapphire Radeon HD 7950 3GB
    Crucial C300 SSD - Bootdrive
    2 x 640GB Samsung - 1.2TB RAID 0
    800GB Western Digital Green SATAII
    Corsair TX 750
    Coolermaster HAF932 - Modded by Blackstare
    Jul 2008
    Portugal
    It did say "PLAY HARD" on the card...
    ASUS Sabertooth P67B3· nVidia GTX580 1536MB PhysX · Intel Core i7 2600K 4.5GHz · Corsair TX850W · Creative X-Fi Titanium Fatal1ty
    8GB GSKill Sniper PC3-16000 7-8-7 · OCZ Agility3 SSD 240GB + Intel 320 SSD 160GB + Samsung F3 2TB + WD 640AAKS 640GB · Corsair 650D · DELL U2711 27"
    Xtreme Cruncher
    Dec 2008
    The Netherlands
    Such a waste. Although the performance at 4x isn't top notch, I'm sure it would be an upgrade for quite a few people on a tight budget. I'm not one of them, but there are many people who don't have enough money to spend in a GPU upgrade. You could have made someone extremely happy, or maybe even made some money on it if you wanted to.
    Mar 2010
    nicaragua
    now when ur new VC arrives and this pci still showing at 4x , what woukd you do or feel? will hit yourself with that hammer ???? OMG
    Jun 2008
    Well that was stupid.
    OVERCLOCKAHOLICS
    Jul 2010
    Hawaii
    WOW, I've been contemplating doing the same exact thing but to my motherboard.
    Slot 1 is running at x1 vs x16 with one card and x1/x8 with 2 cards in vs x8/x8. Can't even go into crossfire due to the x1 issue.
    Here is the tread: Crossfire Stopped Working
    Oct 2004
    Crazypc.ro
    And i only have a 4mb s3 virge
Tags for this Thread
