ATI 5570 Volt Mod 1100mhz vgpu 1200memm
Hi guys its been a while since ive been on XS but i thought id share this Venture with you for those of you who have 5570's
Right to start with i built and braised my own tiny water cooler for this graphics card and used little ram heatsinks on the memm the temps are around 30c at 1100mhz core 1200mhz memm
im not sure what value the variable resistors were but that didnt matter anyway as i multimetered the value of resistance on the default resistors next to the FP chips that control voltage some 5570's use up6101's mine had FP3xxx's they are the same chips same pinouts
then i set my resistors to the same values then used msi to test and then slowly drop the resistance levels then rerun benchtests
Ok so lets begin with some pics
So thats the gpu vmod
now for the memm
Thats the memm mod both are tested and working i must admit i didnt know where to measure the voltages of either the memm or the gpu but by using common sense and setting my variable resistors to the same as gpu and memm resistors already on the board i was able to keep tweaking until i got the memm stable at 1200 and the core at 1100 this card now yeilds some nice results for a cheap card it packs some punch.
I Hope this helps someone else Vmod there 5570 as i couldnt find anything on the 5570 on google or online so i took a chance and researched a little and it paid of
Ps if someone could point me as to where i can measure the voltage for this card id be gratefull cheers
- You may not post replies
- You may not edit your posts
Forum Rules
