Well, i took the plunge and decided to cook my card.
This is a continuation from my original thread I think my 280 GTX is blowing up
To sum it up, the card either pink screened or showed nothing, crashing the PC every time a 3D application was run.
E.g. You could boot into Windows 7 Safe mode, but you couldn't Windows 7 normally.. Due to Aero.
Anyway, lets begin with the pictures:
1. The Victim
2. Taking off the sticker
3. Removing the Screws
4. Remove the back
5.Remove the heatsink
6. Clean it up
7. Place the card on the baking tray
8. In the oven it goes.. 200C for 10 mins.
9. Oh ****, something appears to be very wrong here..
10. GPU has fallen out, and another bit appears to have dropped off.
11. Hmm, this bit appears to have come off one side too.
12. The empty GPU socket
OK, so.. i think i know where i went wrong.. Placing the card in the oven the wrong way dammit.
The card has been placed back in the oven, in an attempt to resit the GPU and the other bits which came off...
Well, it appears successful, everything re-soldered itself back into position.
But total, including the first attempt the gfx card has been in the oven for around 30 minutes.
