Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: ASUS M4A89PRO/USB3 testing with locked multi x2 550
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Had some free time to play with this board a little amongst my busy schedule of late. Just getting a feel for it, I'm sure the results could be improved upon seeing as I was run and gunning and just exploring the board.
    ASUS M4A89GTD PRO/USB3
    AMD Phenom II x2 550 C3 ( untested chip till now )
    Corsair 1866 c7
    pc p@c 1200 turbocool
    Single GIGABYTE Radeon 5970
    Ancient mach 1 predating the dinosaurs
    I was extremely lazy with this one, just jacked the multi one notch from my 06 run and let it rip.
    Not bad for a "dual core chip"
    05 looks real good on this board
    Tossed in a quick PI run, its rather obvious that this chip can do 5+ for a valid on this board based on it's 1m abilities so I didn't bother with a valid.
    1m effeciency seems to be off albeit this OS is untuned I don't believe that to be the cause.
    heatware chew*
    I've got no strings to hold me down.
    To make me fret, or make me frown.
    I had strings but now I'm free.
    There are no strings on me
    Jun 2005
    NYC
    nice bro way to push it
    nice 05 lol
    Amd Nvidia/Ati -3dmark06 scorebord revisted
    asus L1N64-ws or /b depending on bios chip
    4x1gig 8500 gkill bpk
    2x opteron 8224 @ 3.8ghz
    http://www.xtremesystems.org/forums/...&postcount=236
    vga= 8800gt
    winxp pro
    custom chiller -31 water
    2x dtek fuzions
    bix3-with x3panaflo hi output
    antec 850 quattro
    heat under msimax abitmax and dfimax
    Aug 2007
    Greece
    You got a winner right there I tell you Brian, crazy CPU dude. Can't wait for you to cool it down
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Got some more free time so here we go.
    Lets start off where we stopped.......that sub 14 1m that got away due to the fact i was tired as hell last night.
    Of course saying a chip will do 5+ and showing it will do it are 2 totally seperate things, lets make it more complicated by adding 2 more cores to the equasion..
    I just ripped a bunch of other benches no tweaking/tuning, just feeling out the boards performance and the cpu.
    This chip has some serious identity crisis, it just loves being a quad.
    heatware chew*
    I am Xtreme
    Feb 2003
    Netherlands
    Hmmm, 890 chipset looks good for 3D. Thanks for showing man.
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Quote Originally Posted by Zeus View Post
    Might want to rephrase that to this particular board looks good for 3d, been scanning similar results and there is a huge delta and I preety much know why but need to test it personally to be sure.
    From what data I have here it's beating all my 790 boards.
    Tossed my SSD in to test the performance of the SB sata controller.
    heatware chew*
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Testing ram clocking on a new bios boasting ram compatibility , eliminated cold from the equasion to see how it fares under more "normal" conditions.
    No subzero air cooling or high end heatsinks needed here.
    Excuse the bench station, it's been hectic lately.
    Was to lazy to install the socket bracket again so I just plopped the cooler on the chip.
    I'm tired, time for a little shut eye.
    heatware chew*
    I am Xtreme
    Feb 2003
    Netherlands
    Quote Originally Posted by chew* View Post
    Hmm, that makes it even more interesting.
    Since it's an Asus board i have high hopes for the upcoming Crosshair IV, both Formula an Extreme.
    The Crosshair III seemed pretty strong in 3D as well.
    Anxious to hear your reasoning behind this, my first hunch would be internal latency between CPU-PCI-e lanes.
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    From my data the crosshair III got served by this board as well, but like I said I need to do a real compare myself. If i can find the time I may do a all things equal compare on a rather large variety of boards all at the same speeds.
    heatware chew*
    Nov 2009
    Brazil
    On newegg now has to sell??
    I2I3 Overcloking Team
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Quote Originally Posted by Hunt3r_Br View Post
    http://www.newegg.com/Product/Produc...82E16813131631
    heatware chew*
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    IGP benching time
    System on "REAL air" and still to lazy to clamp the heatsink down.
    Apparently this is my fastest single GPU submission to hwbot in 3d01
    OOPSed this screenshot but gpu speeds were kept the same through all benches. CPU speed netted nothing in this bench, I scored the same total at around 4.0 gig
    heatware chew*
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Quick test with micron D9 GTS for compatibility, still stock cooler/cooling.
    heatware chew*
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    wow this thread is amazing
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Finally getting a little more organized here. Air station back up and running and cleaned up for the most part.
    Tossed on a better cpu cooler with a moderate fan for some heavier air testing.
    Threw together a system that some of the more budget minded users would use to see what kind of results can be acchieved.
    AMD Phenom II 550 locked multi C3
    ASUS M4A89GTDPRO/USB3
    ASUS EAH5770
    OCZ BE 2x2g 1600 7-7-7
    PC P&C 750 silencer
    Megahalems something or other heatsink
    Should have some results in a little while.
    Edit prime 95 results done. A bit of voltage to spare but 4 gig is good enough for a dual core
    4.5 is easy.
    heatware chew*
    Xtreme Guru
    Jan 2005
    waukegan
    it's in x4 mode in this pic right?
    mobo: strix b350f
    gpu: rx580 1366/2000
    cpu: ryzen 1700 @ 3.8ghz
    ram: 32 gb gskill 2400 @ 3000
    psu: coarsair 1kw
    hdd's: samsung 500gb ssd 1tb & 3tb hdd
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Quote Originally Posted by i found nemo View Post
    yep
    heatware chew*
  18. #18
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Some 3d on air with a 5770.
    Don't think this particular model is meant to OC as good as the TOP's so I just ran a mild OC.
    heatware chew*
  19. #19
    Dec 2004
    Malaysia
    4.5 is easy.
    omg... that's awesome oc w/ a locked chip... 4.0GHz w/ that kinda voltage is
    is that a retail chip sir? if so mind to share the week?
    | AMD Ryzen 5 76000 w/ EVGA CLC 360 | ROG STRIX B650E-I GAMING WIFI | FF4D532G5600HC32DC01 | Radeon™ RX 6950 XT GAMING OC 16G | XB323QK |
    | 512GB NM760 + Crucial P3 2TB + ST2000LM015 + ST2000LX001 |
    | Creative Stage V2/HE400SE | Xonar U7 MKII | Focus GX-850 | D31 Mesh Screen Black | MK-730-GKCL1 + MM711 + MP510 |
  20. #20
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Week 0931
    Some 2 X 4850 results.
    Vantage seems to have an issue.
    Possibly have found a bug, need to work on it more tommorow. Not sure if its driver or board related yet, could be just mismatched non ref cards.
    Cards both do well over 800/1150 individually but lock any higher than 700 core in crossfire with 9.12 with and without hotfix.
    heatware chew*
  21. #21
    Dec 2004
    Malaysia
    thx for d info sir...
    sorry for off topic:
    one thing i noticed about swappin cards on x-fire mobo, d bandwidth thingy tends to get screwed up when i unplug & plug (could be d case of positions swapped) my 3850s from d board. it (primary slot) can be perfectly fine (x16 @ pci-e 2.0) but x4 @ pci-e 2.0/pci-e d other time. to resolve this i need to reseat d cards and/or reinstall catalyst...
    any advice on this issue?
  22. #22
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Quote Originally Posted by ah_khoo View Post
    Sounds like a board/bios issue. The board is supposed to switch IIRC when it sees the second card.
    heatware chew*
  23. #23
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Tested a couple more chips to verify unlocking.
    555 was untested prior.
    Just tossed voltage and ran chip up real quick.
    heatware chew*
  24. #24
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Swapped to a 555BE now, mainly to test ram compatibility as I see alot of reports from users stating the IMC is NOT capable of 1800 ram speeds.
    Doesn't seem to be a cpu problem with micron d9 on this board with a 555BE , elpida testing next.
    heatware chew*
  25. #25
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Corsair Elpida testing @ 1800 done with 555BE. As you can see even when not running 100% optimal settings or a tuned windows they have quite the lead over micron d9.
    One thing to note is with this board and tall heatspreaders on ram due to there spaced dimm configuration causes heatsink interference. Luckily for me I have long since compensated for this and purchased a heatsink that allows for various orientations however you may want to keep this in mind.
    heatware chew*
