Results 1 to 25 of 222
Thread: GPU OCing Help Thread
Threaded View
    Xtreme Cruncher
    Dec 2008
    Texas
    GPU OCing Help Thread - Need new numbers to update
    Ok, so this is going to be continually under construction, but i decided we needed a GPU OCing help thread (as the title suggests) to compile as much knowledge as we can about how to get the most out of our cards. So here it goes, please feel free to add/make suggestions to this:
    Notes Before Starting:
    For GPUGrid, shaders have the largest impact on points. Core makes no difference. Dedicated crunchers can actually drop the core freq. to keep temps down. Doing so may impact gaming performance though. Effects of memory speeds have not been determined, but are slight at best.
    Although graphics cards (105C) tend to be rated higher than CPUs (with some exceptions - 70C), we recommend bumping up the fan speed also. These chips were designed for high temps, but not to hold those temps 24/7. (IMO - Temps below 80C are acceptable, but opinions vary)
    As long as Temps are kept in check, hardware longevity should not be an issue.
    GPUGrid Stable OCs:
    (please give these a week to let your RAC settle and make sure it is stable. Also, please note 24/7 or not)
    I believe all 200 series should work at 685/1477/1160 and most should work at 702/1512/1188
    Numbers after card are PPD Stock/Strong Overclock
    GT 240:15.7k/20.1k
    550/1340/1700- WhiteFireDragon
    .......... OS: Win 7.......... Brand: Galaxy.......... Cooling: Stock fan @ 40% .......... Voltage: Stock .......... Temp: 58C
    405/1595/1701- WhiteFireDragon
    .......... OS: Win XP.......... Brand: EVGA.......... Cooling: Stock fan @ 85% .......... Voltage: Stock .......... Temp: 67C
    GTS 250:??k/??k
    GTX 260(216):??k/34k
    626/1350/1053 - Otis11
    .......... OS: Win 7.......... Brand: EVGA .......... Cooling: Stock fan@40% .......... Voltage: Stock .......... Temp: ???
    666/1436/1107 - Otis11
    576/1512/999- CaptMorgan
    .......... OS: ????.......... Brand: EVGA .......... Cooling: ??? .......... Voltage: Stock .......... Temp: ???
    702/1512/1188 - Otis11
    .......... OS: Win 7.......... Brand: EVGA .......... Cooling: Stock fan@40% .......... Voltage: Stock .......... Temp: 62C
    GTX 275:34.7k/42.0k
    648/1458/1188- WhiteFireDragon
    .......... OS: Win 7.......... Brand: EVGA.......... Cooling: Stock fan @ 40% .......... Voltage: Stock .......... Temp: 71C
    705/1566/1220 - HuffPCair
    .......... OS: ????.......... Brand: BFG.......... Cooling: Stock fan@75% .......... Voltage: Stock .......... Temp: 68C
    633/1620/1134 - mreuter80
    .......... OS: ????.......... Brand: EVGA .......... Cooling: Stock fan@50% .......... Voltage: Stock .......... Temp: 60-70
    468/1620/1134- WhiteFireDragon
    .......... OS: Win XP.......... Brand: EVGA.......... Cooling: Stock fan @ 80% .......... Voltage: Stock .......... Temp: 69C
    485/1656/1152 - Kryja
    ..........OS : Win XP32.......... Brand: BFG.......... Cooling: Stock fan @ 65% .......... Voltage: Stock .......... Temp: 70
    576/1656/1188 - SMTB1963
    ..........OS : ???.......... Brand: ???.......... Cooling: ??? .......... Voltage: ???.......... Temp: 70
    GTX 280:??k/??k
    GTX 285:??k/??k
    651/1532/1244 - CaptMorgan
    .......... Brand: EVGA .......... Cooling: Stock fan@70% .......... Voltage: Stock .......... Temp: 61
    GTX 295:??k/??k
    701/1577/1233 - Mabyboi
    .......... Brand: EVGA.......... Cooling: Swiftech Epsilon waterblock.......... Voltage: Stock .......... Temp: 42
    717/1600/1233 - Mabyboi
    .......... Brand: EVGA.......... Cooling: Swiftech Epsilon waterblock.......... Voltage: Stock .......... Temp: ???
    725/1600/1300 - Mabyboi
    Scale for G200b: (to assist in OCing step by step)
    1242-1271=1242
    1272-1315=1296
    1316-1342=1332
    1343-1364=1350
    1365-1385=1368
    1386-1423=1404
    1424-1451=1440
    1452-1467=1458
    1468-1494=1476
    1495-1532=1512
    1533-1559=1548
    1560-1576=1566
    1577-1603=1584
    1604-1641=1620
    1642-1668=1656
    1669-1685=1674
    1686-1712=1692
    1713-1750=1728
    1751-1772=1764
    1773-1791=1782
    1792-1817=1800
    1818-1854=1836
    1855-1880=1872
    1881-1899=1890
    1900-1925=1908
    1926-????=1944
    - Thanks SnowCrash
    GTX 460:30k/??k
    800/1600/1800 - PoppaGeek.......... 30k
    .......... OS: Vista 64.......... Brand: MSI 1gig DDR.......... Cooling: Stock fan @ 59% .......... Voltage: Stock .......... Temp: 48C (25.5C room)
    828/1656/1566 - SMTB1963 .......... 34-36K ppd
    .......... OS: ???.......... Brand: ???.......... Cooling: ??? .......... Voltage: ???.......... Temp: 60
    GTX 465:??k/??k
    GTX 470:??k/??k
    GTX 480:??k/??k
    ???/1712/????- SnowCrash.......... Stable
    .......... Brand: ????.......... Cooling: Stock.......... Voltage: 1138mv.......... Temp: ???
    GTX 560:??k/??k
    GTX 570:??k/??k
    842/1684/1652- SMTB1963 .......... Stable
    .......... Brand: ???.......... Cooling: ???.......... Voltage: ???.......... Temp: 65
    GTX 580:??k/??k
    Tools:
    Voltage Tuner Thread - Thanks Ikiller123
    EVGA Precision
    RivaTuner
    CUDA mem test - Thanks PG
    24 hour prime stable? Please, I'm 24/7/365 WCG stable!
    So you can do Furmark, Can you Grid???
