Hi!
Can you give me some feedback if a solution such as this would be interesting for you?
We can make it that two or three blocks are connected with parallel or serial flow.
Let me know what you think.
Hi!
Originally Posted by creidiki
HELL YES.
The availability of connectors like these was one of the major reasons I was looking at alternatives like AC or XSPC blocks, despite the lack of nickel-plated blocks or expensive shipping options.
Rig specs
CPU: i7 5960X Mobo: Asus X99 Deluxe RAM: 4x4GB G.Skill DDR4-2400 CAS-15 VGA: 2x eVGA GTX680 Superclock PSU: Corsair AX1200
Foundational Falsehoods of Creationism
quad maybe ? but only few people use quad![]()
920 @3.5ghz 1.06V
EVGA 762
Corsair Dominator GT 2000
Manli GTX460 SLI
several HDD
corsair ax1200
Definitely looks nice Eddy
Any plans on having an acrylic version or white acetal one with LED holes?...
Also "triple"![]()
[ 3770K @ 4.2 : H100i : ASRock Z77E-ITX : GTX560 Ti : 16GB DDR3 1800 : +4TB : Bitfenix Prodigy : 2x Dell S2340M : Filco Majestouch-2 [Cherry Brown] : BX8a Deluxe]
AC definitely has the best looking link.
Not a bad effort Eddy, it does look a little clumsy though, or should I say bulky?. . .oh, and only 1 "p" in "triple".
Circles SucQ!
Honest opinion?
It looks REALLY REALLY nice!
But it does look too bulky. I think it would take up the space next to the expansion slots where normally you can put a pump or a res.
And it's not something I would necessary buy, I'd prefer to use SLI fittings.
Is the outside piece necessary? How about just with the smaller connecting pieces between the blocks?
YES!
Make a cover for the crossfire/SLI cable/ribbon too![]()
TBH this is a niche of a niche market. The more options the better though!
Current: AMD Threadripper 1950X @ 4.2GHz / EK Supremacy/ 360 EK Rad, EK-DBAY D5 PWM, 32GB G.Skill 3000MHz DDR4, AMD Vega 64 Wave, Samsung nVME SSDs
Prior Build: Core i7 7700K @ 4.9GHz / Apogee XT/120.2 Magicool rad, 16GB G.Skill 3000MHz DDR4, AMD Saphire rx580 8GB, Samsung 850 Pro SSD
Intel 4.5GHz LinX Stable Club
First of all I had to look to minimize flow resistance and to make it work with our current block design.
That is why it might look bulky.
We sould mimimize bulky look with modifying edges a little. Let me try...
Transparent picture so you can see the path better.
Something in this direction?
Muuuuch better. I really like that. But I think it would be more stylish with just the EK logo. No text.
Specs:
HW: Lian Li PC-A71F | i7 920 | P6T Deluxe | HD5870 | 6GB OCZ Platinum 2000mhz | AX850W | Asus Xonar D2X 7.1 | Intel X25-M 80GB SSD | WD 2TB Caviar Green
WC: EK-FC5870 | EK Supreme HF | Swiftech MCP655 with EK top | ThermoChill PA120.2 | ThermoChill PA120.3 | EK Multioption 250
Other: Scythe Gentle Typhoon fans | Aqua Computer Aquaero | Bitspower Comp. Fittings
yes, yes, yes, the added height of this will be perfect for my new build, with a horizontal MOBO.!! get rid of one P in triple and don't put serial on it, makes me think of Al Gore.![]()
Email/web browsing PC
MM Ascension case, 24/7 settings
Classified, 980x @ 4,525Mhz, HT on 1.39V
(3) ATI 5870's@ 1062Mhz
G skill perfect storm RAM s 6gb, 2,176 Mhz CAS 8
(4) intel x25m RAID 0
CPU loop, EK supreme HF, EK mobo block, 500MM bitspower res, 2 DDC 3.25's on XSPC top, 2 XSPC RX 360's, 1 XSPC RX 480, GPU loop, EK water blocks, with nickel backs, 2 swiftech mcr 320's, 500MM bitspower res, ddc 3.25, XSPC top all with 1850 RPM gentle typhoons
plus many other rigs.
Update...
yes, now what about quad and dual versions??
I don't see that being very easy to install, let alone if i had to pull one of the video cards out for some reason.
MM H2gO - Win 7 Pro
2 PA120.2 Thermochill
MCP355 w/XSPC res top
i5-2500k @ 5.0ghz w/Heatkiller 3.0
Corsair HX850 - M IV Gene-z
GTX 480 w/DD 480 ni/cu
It's no worse than removing a WC'd graphics card already is.
Rig specs
I love it. I'm another who may be insterested in quad but I understand that will be a very limited market.
I will take that as a yes? lol
+1 to what everyone else said.
I almost went with HK blocks for my 5870s instead of the EKs for the simple reason they have a multi-GPU link unit like this.
Latest rev looks great. Are you still planning on doing a serial and parallel version, only one or the other?
Props Eddy![]()
If it holds the card pretty securely, pulling all 3 cards out in one batch would be sweet. Other fitting methods let them twist when you pull 2-3 cards out as one unit.
Eddie, you could put a temp probe spot somewhere since it's got a lot of room? Ohh whack, NM, you could put a temp fitting in one of the capped fittings holes.
Anyhoo, might get some buyers. Looks like some machining costs, but the material costs are pretty cheap.
All stock for now, no need for more, but it's gonna be soon methinks.
Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
SLI GTX470 EVGA
EK HF nickle blue top CPU block (free from Eddie)
Koolance 470 waterblocks
One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
Banchetto Tech Station
120 GB SSD, and a few other drives.
1000W UltraX3 PSU, 900 watt (1500VA UPS
23.999" Acer GD235hz and 24" Acer H243H
What would be cool is if the top was clear or came in a color like the Classified blocks. It would also be nice if this worked with current models, but I am not sure how hard that would be since the spacing of the in/out ports are probably different and therefore this would be limited to a specific design such as the HD5000 series or the fermi series when it hits the market (if ever).
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
Sweet. At some point I will be upgrading my GTX295 to either dual HD5870's or Fermi, just depends on performance and this would be an awesome addition instead of using the typical CF/SLI connectors.
Desk Build
W/C System
