Results 1 to 3 of 3
Thread: Socket 1366 pinout
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    Socket 1366 pinout
    I'll settle for just about any info but what I really want is a pic or diagram indicating which pins on a 1366 MB socket are ground and which are power.
    because of the parrallel paths multi pin approach to the design I want to be able to identify those cheap MBs sold with damaged pins that may be useable if 1 or 2 ground pins or power pins were missing by their location.
    Yes I know I'm a cheapskate but does anyone know of a place to get this info...I can't even think of the right search...
    My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.
    79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
    Wuf
    Jul 2007
    Finland/Tampere
    Here:
    List of pads:
    http://download.intel.com/design/pro...hts/320834.pdf
    Tho they've put wrong picture there is no pin map.
    You can find lga1366 pin diagrams here:
    http://download.intel.com/design/pro...nex/320837.pdf
    I'd recommend, print that pin map/diagram, and pin lists and take colored pens, i think you'll quess the rest
    You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
    [22:53:09] [@Jaco-XS] i'm gonna overclock this damn box!
    Ze gear:
    Main rig: W3520 + 12GB ddr3 + Gigabyte X58A-UD3R rev2.0! + HD7970 + HD6350 DMS59 + HX520 + 2x X25-E 32gig R0 + Bunch of HDDs.
    ESXI: Dell C6100 XS23-TY3 Node - 1x L5630 + 24GB ECC REG + Brocade 1020 10GbE
    ZFS Server: Supermicro 826E1 + Supermicro X8DAH+-F + 1x L5630 + 24GB ECC REG + 10x 3TB HDDs + Brocade 1020 10GbE
    Lappy!: Lenovo Thinkpad W500: T9600 + 8GB + FireGL v5700 + 128GB Samsung 830 + 320GB 2.5" in ze dvd slot + 1920x1200 @ 15.4"
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    Thank you. The idea should, if nothing else, give me an idea of what to definitely avoid
