I got my asus 5850 from newegg today and for some reason the default clocks are set at 850/1200 according to gpuz and afterburner. They are supposed to be 725/1000 correct? Is it a bug with the two programs?
Q6600@3.6GHZ (L726A849)
Thermalright Ultra 120 Extreme (lapped) MX-2 paste
Abit IP35 Pro
2x1GB Ballistix 6400
Asus 5850
WD 250GB Sata II
Pioneer 16x DVDRW
OCZ Gamextreme 600w
725/1000, yeah. Really odd, these are the clocks of 5870...
i just bought the asus 5850 a month ago, and mine were the 725/1000
lucky you
does your still drop down to 175mhz when your at your desktop?
The Blood Of 1000 Angels: AMD Phenom II X3 720 @ 3.8GHz with 4th Core Unlocked| DFI DK 790GX-M2RS|2X2GB G.Skill DDR2-1066 PK (F2-8500CL5D-4GBPK)| 2x Seagate 320GB 7200.12 In RAID-0| XFX 5850 XXX@ 1000/1200| CM Cosmos 1000| Samsung T240 1920x1200 CPU Cooling:IandH Stealthres 175| Swiftech 355 w/ XSPC Top| XSPC RS240|EK 5850 Copper and Acetal|XSPC RS360|Swiftech GTZ
CCC says 850/1200 as does gpuz. Here is a screen shot
Bios version is ver012.011.000.006.034494 which is a 5870 bios I believe. Looks like Newegg may have sold me a card that someone returned.
Abit IP35 Pro
Asus 5850
WD 250GB Sata II
Pioneer 16x DVDRW
OCZ Gamextreme 600w
No the card was sold as new which it obviously should not have been. I am just worried that if I ever had to return it for warranty issues they would not take it because of the modified bios.
Abit IP35 Pro
Asus 5850
WD 250GB Sata II
Pioneer 16x DVDRW
OCZ Gamextreme 600w
if you are worried then flash it to the original asus 5850 bios or return it to newegg explaining the situation and they will most likely give you another card
Run 3dmark06/vantage/furmark and look for artifacts.
If it is artifact free and temps are 80 or less then it's a keeper.
Or you could flash back to the original bios.
Got to the original manufacturer's site and see if the card has been registered already too.
If it has - return it.
i7-2600k L041C108 4.8ghz 1.32v PLL offVenomous-X Push/Pull http://www.xtremesystems.org/forums/...postcount=1063
Asus P8P67 Vanilla
Samsung 30nm MV-3V4G3D/US 2x4GB @ 9-10-10-28 1T DDR3 2133 1.6v http://www.techpowerup.com/forums/sh...d.php?t=159320
Diamond HD 7970
WD 600GB Velociraptor
Corsair TX750W
CM 690 II Advanced
Q822A549 E8500 @ 4.5ghz air TRUE@ http://www.xtremesystems.org/forums/...d.php?t=203762
G.Skill F3-12800CL6D-4GBXH @ 7-10-8-27 1T DDR3 2133 1.6v http://www.xtremesystems.org/forums/...d.php?t=266839
If everything is working fine then just be happyRun furmark or other stress program and see if it passes
see what 3d volts are, 5850 is 1.0875v old 5870 is 1.162 and new 5870 bios is 1.174. My card does 875/1200 on 1.0875v
Mpower Max | 4770k | H100 | 16gb Sammy 30nm 1866 | GTX780 SC | Xonar Essence Stx | BIC DV62si | ATH AD700 | 550d | AX850 | VG24QE | 840pro 256gb | 640black | 2tb | CherryReds | m60 | Func1030 |
HEAT
I had it at 1.2v and 900/1200 today and after 6 min furmark temps were 71c with the fan at 80%.
Abit IP35 Pro
Asus 5850
WD 250GB Sata II
Pioneer 16x DVDRW
OCZ Gamextreme 600w
using 5870 volts mine is good for 925/1300
HEAT
sounds like you got a 5870 by accident hell keep it its a $80+ free upgrade you would be dumb to return it!
Funny ,, Maybe they just flashed it on accident at the factory..
5850/5870 use the same Bios practically,, MHZ clocks and Only shaders will be different if the VGAboard has same ram and voltage specs...
I have my 5750's set @ 850/1200.....
Returned three that wouldnt run at stock..Im so happy...
Just run it![]()
To Do:
A. Run vantage 2 times on the 850 clocks and record the score, then run vantage 2 times on 725 and record the score. This will tell you if the clocks are actually 850 or if its a software malfunction.
B. SAVE THE CARD BIOS.
C. Set the default clocks to normal in ATI CCC. (IF YOU WANT TO)
I'm quite sure this is one of those "Overclocked" Edition chips that was accidentally packaged in a regular box.
You should be very happy if that is the case. Use it at 850 until it drops. Why? Because it came with those clocks -> Plausible Deniability.
Perkam
