Okay I have more or less decided to go for a 5870.
Which one though? Asus, XFX (875Mhz model), Sapphire or the Vapor X from Sapphire?
Asus Maximus Extreme
Intel Quad 2 Core Q9550 (+Noctua Fan. Temp at 22c)OC'ed 3.4Ghz
Corsair TWIN3X4096-1600C7DHXIN
Radeon Sapphire HD4850 (+Zalman Fan and Heatsinks)
Corsair HX1000
Cooler Master HAF932
Seagate Barracuda 1TB
Western Digital Velocelraptor 150GB 10000rpm
I do not trust XFX anymore personally. I suspect they are subbing out cheapo parts in ATI's reference design. I had to RMA mine because the DVI outputs died it also had some minor green artifacting in 2d, and the replacement card they sent me had one dead DVI port out of the box. I'm on my 3rd card now which is working fine. In their defense, XFX customer support has been good to deal with, they always promptly took care of the RMAs and cross shipped the cards and sent me fedex labels for their mistake of sending me a broken card.
MSI cards for $399 on the egg right now, thats what I would buy. Asus is also $399 which would be my 2nd. Either of those can be easily adjusted to run at 875mhz out of the box with no issues.
Get whatever you like the price and the warranty most of IMO.
ASUS come with Voltage tweek ( unlocked bios )
BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
Corsair HX1000
Corsair HX1000
ASUS cards have an unlocked BIOS. There is also one available made by MSI you can download.
Unlocked BIOS means that the Ati CCC overclock limits are pushed way beyond 1GHz instead of 900MHz, so you can overclock your card to the limit.
You can also do the same and go beyond 900MHz with the 'locked' BIOS, but you can say goodbye to power saving features then.
Since all cards are the same (in hardware) you can flash any BIOS you like.
Asus or MSI are "unlocked" bios allow you to change the Vcore of the card. The unlocked bios's of other cards do not allow you to change the Vcore. Any card can be flashed to MSI or Asus bios but there is always a risk of a flashing going wrong and bricking the card.
For such a minor OC to 875mhz I would doubt you would even need to raise the voltage (not sure on this, I havn't tried.) But if you ever want to OC more or mess around with the voltages why not buy an unlocked card by default for the same $?
Oh yeah... and good point Zalbard, the default bios's only clock up to 900mhz, Asus goes to 1200mhz and msi 1400mhz or somthing? I think the highest a 5870 with good cooling will OC is in the 1100-1150mhz (i'm not to sure but there is a really long 5870 oc'ing thread here.)
Corsair HX1000
[QUOTE=trn;4211952]Asus or MSI are "unlocked" bios allow you to change the Vcore of the card. The unlocked bios's of other cards do not allow you to change the Vcore. Any card can be flashed to MSI or Asus bios but there is always a risk of a flashing going wrong and bricking the card.
Ahhh I see I can play more with the GPU's voltage! Can't do this in CCC and ATI tray tools seems limited in the voltage area.
Corsair HX1000
Corsair HX1000
I think you're confused. Let me try and clarify.
I'd suggest using MSI Afterburner for overclocking since it lets you control GPU vCore.
It will respect the limit set by CCC (which is BIOS dependant).
However, you can enable 'unofficial overclocking' in AB and go beyond the CCC limit. The issue is, you will lose the power saving features of your card.
Corsair HX1000
Corsair HX1000
After alot of thinking I will more than likely go for the Sapphire 5870 Vapor X.
Thr cooling is better and both idle and load temps. Highest temps OC'ed @ 986 /1250 under load were around 64c!!!
Doesn't make as much noise either
AS far as OC goes, it seems it can be pushed up to around 1Ghz anyway, but not quite as far as with the Asus voltage tweak. It's a little more expensive but I feel it may be worth it.
Thoughts?
Corsair HX1000
Yeah, it might be a good idea, depends on the price ofc.
You won't be disappointed with either version.
