Results 1 to 7 of 7
Thread: i5-6xx + 8GB = low bclk?
    Mar 2008
    Minnesota
    I've got an i5-660 that I'm messing around with to see how high it can go for 24/7 usage under water.
    So far I had quite a bit of an issue trying to get a BIOS that worked on the Gigabyte P55-UD3R. Now I've got one that works (more or less, still somewhat funky) but when using 8GB I get a bclk wall around 165 (4.3Ghz).
    Oddly, it doesn't matter how fast the RAM is running, absolutely no issue running DDR3-2000 with 8GB but even if I scale down the memory (as low as 900Mhz) the bclk won't go any higher.
    With 4GB I have no issues at even 240 bclk, though there are a few "bclk holes" like the old Nforce 4 FSB holes. 200 is perfectly stable, 205-209 won't boot, 210 is rock stable, etc.
    Do you think switching boards (either EVGA P55 SLI or Maximus III Formula) would help or is it purely an IMC limitation on the i5-660?
    The only reason I wanted to try a 660 was to get 4.7-5.0 24/7 stable with 8GB (required for a game that I play, at least, how I play it) for better gaming over my 4.2Ghz i5-750.
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
    Xtreme Mentor
    Dec 2007
    Glad to see some testing on a p55 board. I would like to try one of these chips, I have a p55 and don't want to have to buy a new board.
    Mar 2008
    Minnesota
    Quote Originally Posted by OC Nub View Post
    They are great fun with 4GB or less
    Frustrating with 8GB
    Funny to see 17C idle and 24C full load on way-overkill (for a 32nm dual) water cooling and cool ambient
    -100C Club Member
    Feb 2004
    australia
    Quote Originally Posted by tool_462 View Post
    what are you setting the volts to in bios, also ram timmings have you played around with?
    Also what bios are you using?
    Mar 2008
    Minnesota
    Quote Originally Posted by kayl View Post
    Tried basically everything as far as voltages go, up to 1.55vcore and comparable on other voltages (I'm at work so can't check my notes.) Nothing changes whatsoever.
    RAM timings, anywhere from the 8-8-8-20 I run at for 24/7 with the i5-750 to 11-11-11-40 or so, still the same brick wall for bclk.
    BIOS = F5a as provided by hicookie in this thread: http://www.xtremesystems.org/forums/...d.php?t=243143
    Latest BIOS available on Gigabyte's site is F4
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    i have DRAM ratio issues but BCLK wall is around 220
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
    Mar 2008
    Minnesota
    Quote Originally Posted by PatRaceTin View Post
    You only have 2GB installed though, even with 4GB I don't have BCLK issues, just with 8GB which I need in my main rig.
