Results 1 to 25 of 53
Thread: EK-5970 vs stock cooler tests
Threaded View
    Dec 2009
    washington
    Thumbs up EK-5970 vs stock cooler tests *update*
    alright finally I got today the EK-5970 nickel water block
    so I decide to dedicate some time to show guy's what is the performance gain
    compare to stock cooler
    here it is look gorgeous, now put this sucker in
    all thermal pads on place ,lets put some diamond grease and install it
    done, not too hard .exempt for the plastic spacers you to stick them to the block before stick the block
    alright is ready ,look awesome took now lets tested to the limit
    first on vista 64 ,
    stock clocks and vots okay now OC al the way
    better but no what I was expecting ,lets try win 7 64
    uff much better , now crank all the way
    damn is smoking
    **update**
    well it been a few days and no problem ,from a gtx295 water cooled and OC to this is a havens to earth different
    the ability to run anything at max is priceless ,thanks to klyser I reached higher oc in i7 ,above in the new score for warhead and under the vantage 3dmark06 score for the guys who ask for it, even when some say there are rigged
    personalty I tough that EK blocks were for show up
    but I was wrong the perfomace in temps is solid
    from 64c idle 86c load OC to 26c IDLE 45c oc
    beside the fps increase the game run smother no slow downs or dose
    out of place images that look like pic cut in two misaligned
    no mater what OC I try it won't crash no more
    before I have to reboot 100+ times doing OC tests
    it somebody want me to try something else let me know
    i7 920 DO@4.520ghz H2O /HD 5970 1000mhz H20
    asus rampage gene II/ CM Storm Sniper case
    ultra x3 1000w/ corsair XMP3@1720mhz 8-8-8-24
    seagate barracuda 750/ corsair 128p ssd
    windows 7 pro 64
    Sniper mod completed so happy
