Results 1 to 8 of 8
Thread: i5-661 Clarkdale OC
    May 2008
    Seoul, Korea
    i5-661 Clarkdale OC
    Hello.
    My i5-661 OC test
    BIOS settings and Prime 95 test are as follows.
    MSI P55 TEST PC testing platform
    CPU: Intel Core i5 661 Clarkdale
    Mainboard: MSI P55-GD65
    RAM: G.SKILL DDR3 4G PC3-12800 RIPJAWS 2x2G
    VGA: ATI HD 4350
    HDD: WD SATA2 500G
    Power: Enermax Revolution85+ ERV1250EGT
    Cooler: GT WATER
    OS: Microsoft Windows 7 Utimate K 64bit
    BIOS : 1.6B3
    Beta BIOS Link
    http://namegt.tistory.com/attachment...2E45528283.zip
    NAMEGT- Xtremesystems
    http://www.playwares.com
    May 2008
    Seoul, Korea
    MSI P55-GD65 / i5 661 Clarkdale OVERCLOCK @ 4937MHz OC
    SETUP
    May 2008
    Seoul, Korea
    i5-661 BCLK TEST
    ▲ bclk 200 = vtt 1.3v
    ▲ bclk 210 = vtt 1.35v
    ▲ bclk 220 = vtt 1.4v
    ▲ bclk 230 = vtt 1.5v
    Da Goose
    Oct 2005
    Chicago
    OMG...
    i7-860 Farm with nVidia GPU's
    May 2008
    Seoul, Korea
    197 x 25 = 4925MHz
    ▲ i5-661 @ 4937MHz / MSI P55-GD65
    DDR3 @ 1974MHz 9-9-9-24 1T
    1M Super PI
    32M Super PI
    EVEREST Memory Benchmark
    Prime95 Large 4 hours Test Pass
    http://valid.canardpc.com/show_oc.php?id=909965
    Oct 2006
    Korea
    Almost 5Ghz for 24/7 use? omg...;
    Well done.
    Apr 2008
    Thessaloniki, GR
    Quote Originally Posted by serangel78 View Post
    Well done.
    Using 1.52 vCore for 24/7 ? I think this is a lot for a 32nm, isn't it ?
    Mar 2008
    Minnesota
    Quote Originally Posted by Dr.Paneas View Post
    Could be, time will tell.
    People are generally more scared of vcore than they need to be though, we'll see what the random made up arbitrary "max voltage" for 24/7 will be on 32nm soon I'm sure
    If they handle voltage like 45nm does without degrading or being damaged, they will be fine
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
