Results 1 to 25 of 301
Thread: DimasTech Bench Tables V2.5
Threaded View
    Sep 2002
    Italy
    Hello Guys, after long time, we're about to lounch the new V2.5, this version have all the features of the V2.0, together with the Easy V2.5 we will be launching also the Hard V2.5, completely matching the Easy V2.5 new table.
    Here Below the Final Revision of Table Easy V2.5, this is the Standard Version, no customization, all the accessory like USB cable, FlexFan or other things are adding parts
    Bench Table Easy V2.5 Specifications
    -Single Model available, this model will cover all the old V2 versions
    -Tipical U bend shape, 90 degrees round corner
    -down tray now have a sledge and the fasteners are thumbscrews
    -positioning of the support for optical and Hd on Slot, not just on holes
    -lateral customization with the name of the product "DimasTech V2.5"
    -Compatibility with all the radiators on market(hwlabs, thermochill, tfc, ecc...ecc...)
    -no more bolts and hand tools to use, also the bolts are thumbscrews now
    -no more hand tools on all the benchtable
    -4 hard disk support, 3,5"
    -3 optical drive , 5,25"
    -new slot for cable passing
    -custom cut on the back saying "MADE IN ITALY"
    -motherboards Mini ATX compatibilty / motherboards XL-ATX / E-ATX and Micro-ATX
    -rubber feet M4 thread for Hand screwing
    -3 standard colors always available without painting waiting (black glossy, metal grey and milk white)
    -custom color on booking
    -full compatibility with new Bench Table Hard V2.5
    -4 back holes for water cooling tube passing or for waterccoling fittings
    -new Power On and Reset Button "P" and "R" with red and black shrink cables
    -USB front Port for Single Pen Drive, very usefull for saving screenshots and no boring about find the Rear USB ports (USB Cable is an Accessory)
    -Male - Female spacers, no more need of screw for the motherboard Spacers
    -FlexFan supports available as accessory, chromium and black powder coating, it fits on all of the Bench tables done from the begin (v1.4) to the last V2.5 (more news on this accessories in next week)
    -XL-ATX vga support available as accessory (10 slots)
    Hardware Assembled Air Cooling, Only USB CABLE accessory
    Bench Table Easy V2.5 Manual ENGLISH/AMERICAN
    Developing Pics, preseries and parts not assembled, packaging sample and FlexFan first try
    Bench Table Easy V2.5 Develop Pics
Tags for this Thread
