Page 1 of 4 1234 LastLast
Results 1 to 25 of 86
Thread: opencl ray tracing!
    Xtreme Cruncher
    May 2009
    Bloomfield
    opencl ray tracing!
    http://davibu.interfree.it/opencl/sm...mallptGPU.html
    download the .tgz at the bottom of the page and extract.
    note: this is not cinebench, the render will never finish!
    you dont have to do 5,000 passes.
    sample/sec: 1,123K
    Xtreme Mentor
    Sep 2007
    Ohio
    Thanks for the post!
    Looks good... Searching for an extractor app now.
    This worked:
    http://download.cnet.com/IZArc/3000-...ml?tag=lst-0-1
    Looks like the app uses 1 GPU, and at least 4 cores on a CPU...
    Asus Maximus SE X38 / Lapped Q6600 G0 @ 3.8GHz (L726B397 stock VID=1.224) / 7 Ultimate x64 /EVGA GTX 295 C=650 S=1512 M=1188 (Graphics)/ EVGA GTX 280 C=756 S=1512 M=1296 (PhysX)/ G.SKILL 8GB (4 x 2GB) SDRAM DDR2 1000 (PC2 8000) / Gateway FPD2485W (1920 x 1200 res) / Toughpower 1,000-Watt modular PSU / SilverStone TJ-09 BW / (2) 150 GB Raptor's RAID-0 / (1) Western Digital Caviar 750 GB / LG GGC-H20L (CD, DVD, HD-DVD, and BlueRay Drive) / WaterKegIII Xtreme / D-TEK FuZion CPU, EVGA Hydro Copper 16 GPU, and EK NB S-MAX Acetal Waterblocks / Enzotech Forged Copper CNB-S1L (South Bridge heat sink)
    Jul 2008
    US
    4890 seems to do well in this one.
    Attached Images Attached Images
    My Rig :
    Core i5 4570S - ASUS Z87I-DELUXE - 16GB Mushkin Blackline DDR3-2400 - 256GB Plextor M5 Pro Xtreme
    Xtreme Mentor
    Sep 2007
    Ohio
    Indeed!!
    And this one: http://www.xtremesystems.org/forums/...d.php?t=241794
    I think ATI is rocking on OpenCL right now...
    Could you verify that you are also just using 1 GPU, with GPU-z?
    Jul 2008
    US
    Quote Originally Posted by Talonman View Post
    Indeed!!
    Actually, I only have one. I forgot to update my sig when I sold the second one :-)
    --Matt
    My Rig :
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    I can't get this thing to run right... it's all fuzzy and runs really slow. I extracted with winrar and ran the app.
    Xtreme Mentor
    Sep 2007
    Ohio
    It does start out fuzzy...
    It is still rendering getting better with each pass.
    This is after letting it run about 10 minutes:
    Quote Originally Posted by mattkosem View Post
    --Matt
    Wow...
    Thanks!
    I hope it supports multi-GPU's soon.
    I could use the extra speed.
    For trivia, the 1/2 of my air cooled 295 that is working, heated up to 64C max. (Room currently 72.1F)
    Even though my GPU's utilization was 99%, it's temp never got excessive.
    I think for what it's doing, the app runs rather cool.
    Jul 2008
    US
    Wow...
    Thanks!
    I hit 36c at the end with a room temp of 23c. I'm under water though.
    --Matt
    My Rig :
    Xtreme Mentor
    Sep 2007
    Ohio
    http://www.evga.com/forums/tm.aspx?m=91863
    We are currently exploring the idea that ATI is running OpenCL apps much faster, but the Nvidia boys seem to have higher CPU utilization in more app than 1.
    If it helping us, or hurting us, I can't say, but would love to know...
    How does your CPU utilization look?
    Note that my Q6600@3.81GHz is at 26% utilization in post #2.
    Jul 2008
    US
    I see 0%.
    --Matt
    My Rig :
    Xtreme Mentor
    Sep 2007
    Ohio
    Thanks again Matt...
    So where is an expert when you need one?
    Could that CPU work be hurting our performance, and better suited for the GPU?
    I think our OpenCL driver could be miss-routing work, or maybe some funky global memory accessing, also causing higher CPU utilization?
    I really have no idea.
    Nvidia doesn't support OpenCL on the CPU, only the GPU.
    Oct 2005
    U.K.
    yeah, according to gpu-z and ccc, my 2nd gpu is doing nothing. also not seeing any load on the cpu as it runs
    i950 (3035B684)
    Gigabyte EX58A-UD3R
    3x4GB G.Skill PC3-12800 7-8-7-24
    HIS Radeon HD 6970 2GB & Dell 3007WFP-HC
    Asus Xonar DX
    128GB C300, Velociraptor & Sammy F3's
    Corsair AX850W
    Windows 7 Ultimate x64 SP1
    Xtreme Mentor
    Sep 2007
    Ohio
    Thanks for the post.
    Aug 2008
    4870 @ 512mb, 790mhz.
    Jun 2005
    Bulgaria, Varna
    >> Q9450 @ 3608MHz
    >> CPU utilization: ~0%
    Code:
    OpenCL Platform 0: Advanced Micro Devices, Inc.
    OpenCL Device 0: Type = TYPE_GPU
    OpenCL Device 0: Name = Cypress
    OpenCL Device 0: Compute units = 20
    OpenCL Device 0: Max. work group size = 256
    Reading file 'rendering_kernel.cl' (size 2997 bytes)
    OpenCL Device 0: kernel work group size = 256
    Banned
    Sep 2009
    Face Clinic, Harley Street
    Xtreme Mentor
    Sep 2007
    Ohio
    I was board... and I'm a list guy.
    DosDuoNo ---------- GTX 260 --- Sample/sec --- 1093.2K
    Chumbucket843 ---- GTX 260 --- Sample/sec --- 1123.2K
    Talonman --------- 1/2 a 295 --- Sample/sec --- 1159.2K
    NovoRei ------------ 4870 ------ Sample/sec --- 5616.1K
    PyrO ----------- 1/2 a 4870X2 -- Sample/sec --- 5796.2K
    mattkosem --------- 4890 ------ Sample/sec --- 6751.6K
    fellix bg ------------ 5870 ------ Sample/sec -- 13719.6K
  18. #18
    Aug 2007
    Aarhus, Denmark
    AMD Ryzen 9 5900X
    ASRock Radeon RX 7900 XTX Phantom Gaming OC
    Asus ROG Strix B550-F Gaming Motherboard
    Corsair RM1000x SHIFT PSU
    32 GB DDR4 @3800 MHz CL16 (4 x 8 GB)
    1x WD Black SN850 1 TB
    1 x Samsung 960 250 GB
    2 x Samsung 860 1 TB
    1x Segate 16 TB HDD
    Dell G3223Q 4K UHD Monitor
    Running Windows 11 Pro x64 Version 23H2 build 22631.2506
    Smartphone : Samsung Galaxy S22 Ultra
  19. #19
    Xtreme Mentor
    Sep 2007
    Ohio
    Another outstanding ATI Score...
    Toysoldier ---------- 5870 ------ Sample/sec -- 13719.6K
    FYI - The programmer is looking to fix us Nvidia guys up:
    http://forum.beyond3d.com/showthread.php?t=55913
    "Hi, I'm David, the author of SmallptGPU. I think I can clarify few points:
    - About the poor performances on Nvidia, I have developed SmallptGPU on an ATI HD4870. Both ATI and NVIDIA OpenCL drivers are in a early stage of the development and have their fair amount of problems/bugs/etc. I have avoided problematic paths on ATI because is my card while I have never tested SmallptGPU on NVIDIA. I assume I'm doing something that the NVIDIA OpenCL driver doesn't like at all. The high CPU usage is a good hint of this problem.
    - The sources are available on the web site, so if anyone has a fix for NVIDA cards, I will be happy to apply it.
    - SmallptGPU uses the first GPU device available (there is a command line option to run on CPU device). About all the load should be on GPU, CPU is nearly unused. It is not able to use multiple devices at the same time so any SLI/CrossFire configuration will be used only at 50% of its capabilities.
    - 5870 is horrible fast ... I' trying to not buy one "
  20. #20
    I am Xtreme
    Oct 2004
    U.S.A.
    a single 5970
    Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
    LSI series raid controller
    SSDs: Crucial C300 256GB
    Standard drives: Seagate ST32000641AS & WD 1TB black
    OSes: Linux and Windows x64
  21. #21
    Xtreme Mentor
    Sep 2007
    Ohio
    Sweet!
    DosDuoNo ---------- GTX 260 --- Sample/sec --- 1,093.2K
    Chumbucket843 ---- GTX 260 --- Sample/sec --- 1,123.2K
    Talonman --------- 1/2 a 295 --- Sample/sec --- 1,159.2K
    NovoRei ------------ 4870 ------ Sample/sec --- 5,616.1K
    PyrO ----------- 1/2 a 4870X2 -- Sample/sec --- 5,796.2K
    mattkosem --------- 4890 ------ Sample/sec --- 6,751.6K
    safan80 ------------ 5970 ------ Sample/sec -- 11,012.8K
    fellix bg ------------ 5870 ------ Sample/sec -- 13,719.6K
    Toysoldier ---------- 5870 ------ Sample/sec -- 13,719.6K
  22. #22
    Jul 2008
    US
    I'd like to update my score.
    --Matt
    My Rig :
  23. #23
    Xtreme Mentor
    Sep 2007
    Ohio
    I don't know if we are officially recording them...
    But glad to!
    mattkosem --------- 4890 ------ Sample/sec --- 7,520.9K
  24. #24
    Oct 2005
    U.K.
    i'f you're going to have the scores in a list, i think it might be best to have clock speeds listed too
    i950 (3035B684)
    Gigabyte EX58A-UD3R
    Asus Xonar DX
    Corsair AX850W
  25. #25
    Nov 2006
    NY
    STEAM
    Corsair H80
    i5 2500K 4.5Ghz 1.33v
    8GB GSkill Sniper DDR3-1600 1.25v
    Gigabyte Z68XP-UD3P F7 | XFX 6970 2GB
    64GB Adata SSD | 2 x Seagate 7200.12 500GB Raid 0
    Corsair 750TX | Asus Xonar Essence STX
    Sennheiser HD-555 Mod | Asus VH242HL
    Logitech G9x | Logitech G15v2
    Corsair Vengeance C70 | Windows 8 Pro 64-Bit
