Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: new CPU-Z wont validate?
    Oct 2004
    UK, Westbromwich
    hey guys sorry if this is the wrong section!
    having a really strange problem since updating to the newest cpuz.
    It seems to be detecting my 955 wrong and invalidating my Overclocks
    Here is before i updated cpu-z (1.52.2)
    Here is the messed up one (1.53). Notice the package name is now coming up as socket 939? it wont validate even at stock.
    CPU: Phenom II X4 955 @ 4800Mhz
    Mobo: Gigabyte GA-MA790FXT-UD5P < Died
    GFX: Asus ATI HD6970
    Ram: OCZ 2x8gb corsair vengeance 1600
    PSU: Corsair HX650w
    HDD Crucial M4 SSD 128gb, 1tb spinpoin and WD green 1TB
    Xtreme 3D Team
    Jan 2009
    Ohio
    Great CPU you have there BTW...
    1.53: (100% stable, 24/7 settings)
    http://valid.canardpc.com/show_oc.php?id=905672
    And my sig is the "suicide" valid....(1.52.2)
    Package name however is changed for a reason, pinout number is wrong...(should be 938 for AM3) but it's correcting AM3 vs. AM2+.
    Smile
    Oct 2004
    UK, Westbromwich
    Quote Originally Posted by BeepBeep2 View Post
    aint a bad 955 is it.
    yeah, i understand the AM3, part, just not the socket pin reading haha.
    Guess we will have to sit tight for an update.
    PSU: Corsair HX650w
    I am Xtreme
    Feb 2003
    Netherlands
    I've seen a number of rejected validations around with 1.53.
    What cooling did you use for that 4.8GHz?
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Sep 2009
    Aubrey, Texas
    Mine too. I thought something was wrong at first but I started looking at everyone who has posted with theirs in the last week or so.
    i5 2500K@ 4.5ghz turbo
    TT Spin-Q
    ASUS P8P67 EVOs
    4GB (2 x 2) Ocz Platinums @ 1600mhz
    Diamond 6970 2gb Catalyst 11.1
    2 X 1.5tb WD Drives
    LG DVD burner
    Win7 64 bit Home Premium
    Corsair HX 850w
    In a slightly modified Antec 1200
    Nov 2006
    Poland
    we have also problems with validating e.g.
    http://valid.canardpc.com/show_oc.php?id=901147
    even stock won't validate :/
    http://valid.canardpc.com/show_oc.php?id=905930
    does anyone have any solution?
    Phenom 9850 @ 3927 MHz
    Phenom 8750 @ 3844 MHz
    Xtreme Cruncher
    Apr 2008
    Ohio
    I haven't had any issues. I use the stand alone for 32bit and 64bit. I haven't tried the install version. Not sure if it is issue with both methods or not.
    Direct link
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
    Oct 2004
    UK, Westbromwich
    Quote Originally Posted by Zeus View Post
    Mach 2 GT but it cant handle the load though, soon as any load hits the temps start to rocket.
    PSU: Corsair HX650w
    Sep 2009
    Aubrey, Texas
    Quote Originally Posted by charged3800z24 View Post
    I tried both stand alone and the install versions here. My laptop won't even validate successfully and I promise you it is as stock as it gets.
    TT Spin-Q
    ASUS P8P67 EVOs
    2 X 1.5tb WD Drives
    LG DVD burner
    Corsair HX 850w
    Aug 2008
    Maine
    Im having a problem to i cant validate mine also
    So i tryed to uninstalll it and reinstall and still nothing
    anyone find out whats doing on?
    Case: Cooler Master 1000
    MB: Gigabytes GA-990FXA-UD3
    CPU: AMD FX-6300 3.5Ghz Stock
    RAM: Ocz 4GB(2x2GB) DDR3
    GPU: Nvidia EVGA GeForce GTX 560 Ti FPB
    PSU: Corsair RM1000
    CPU: Stock for now
    My Heat
    Mar 2006
    Central VA, USA
    Glad to it isn't me!! Did my first attempt at validation today in a while and had to down load 1.53 before it would let do any thing. Wasn't paying attention so this is the only copy as I was "suiciding".
    As of 04/29/11
    Celtic Spirit >> (Under Construction / WC’ed) >> Antec SX1200, MSI 890GXM-E65, PII X6 1055T, 2 x GTX 285s, HDDs (TBD), 2 x G.S. F3-12800CL7D-2GBPI, OCZ 700W Modular, XP Pro SP2
    KestrelFlight v1.0 >> (To Be WC’ed v2.0) Zalman Z7+, MSI NF980-G65, PII X4 1055T, 2 x Galaxy 580GTXs, Zalman 32GB SSD, WD V'Raptor 300GB, G.S. F3-16000CL9D-4GBTD, Zalman ZM1000-HP Plus , Win7
    Oz1a v2.0 >> XFX MDA72P7509 750a, PI X2 8870BE, 2 x XFX GTS250, WD 250GB, F2-8500CL5D-2GBPK, Tt TR2 600W, XP Pro SP3
    Jun 2007
    Quote Originally Posted by MaRtIe View Post
    lol ... i had mine showing wrong vcore .. i used the stock vcore at 1.475v .. it's showing here 1.152v
    Attached Images Attached Images
    Xtreme Mentor
    Dec 2007
    State of Confusion, USA
    Honestly, some of you guys crack me up...
    "Oh, something is wrong with CPU-Z 1.53... It won't validate my 4.8Ghz run!!"
    Not trying to be a jerk here, but did you ever think it's because your 4.8 run isn't really VALID?
    In all reality, CPU-Z has been a little loose in the last couple years.
    It's validated alot of things that aren't stable at all.
    I had no problem getting a good validation with 1.53 (see Sig).
    Then again, my rig actually is stable...
    Personally, I'm thinking they finally fixed it.
    AMD FX-8350 (1237 PGN) | Asus Crosshair V Formula (bios 1703) | G.Skill 2133 CL9 @ 2230 9-11-10 | Sapphire HD 6870 | Samsung 830 128Gb SSD / 2 WD 1Tb Black SATA3 storage | Corsair TX750 PSU
    Watercooled ST 120.3 & TC 120.1 / MCP35X XSPC Top / Apogee HD Block | WIN7 64 Bit HP | Corsair 800D Obsidian Case
    First Computer: Commodore Vic 20 (circa 1981).
    uncore challenged...
    Feb 2006
    ontari-ho (canada)
    Quote Originally Posted by Daveburt714 View Post
    CPU-Z is not suppose to validate stability, it is for validating a clock was actually achieved...period. drop the 'more stable than art thou' speech. there is clearly an issue with the latest CPU-Z and some CPU's/MB's or some other unknown variable apparently.
    i only run Intel and 1.53 has been validating everything i have tried the last couple days, i would suggest contacting Franck with details as it may be something that came up with specific processors/boards. is there any rhyme to the pattern on invalid's showing up in this thread?
    i don't quote in my signature, but best WR ever...
    Quote Originally Posted by Jor3lBR View Post
    It holds the current WR for the least vcore required to run 4500Mhz stable (1.32vcore)
    i can't even make that shyt up ^^^
    Xtreme Mentor
    Dec 2007
    Quote Originally Posted by 3oh6 View Post
    I'm not trying to claim that "I'm Holier than thou", and I don't doubt that there are some problems with the newest version of CPU-Z.
    It wouldn't really be anything new, now would it?
    That being said, here is a WIKI definition of Valid:
    Quote Originally Posted by WIKI
    In common usage, validation is the process of checking if something satisfies a certain criterion. Examples would include checking if a statement is true (validity), if an appliance works as intended, if a computer system is secure, or if computer data are compliant with an open standard. Validation implies one is able to document that a solution or process is correct or is suited for its intended use.
    Source: http://en.wikipedia.org/wiki/Validation
    I seriously doubt 4.8Ghz will meet that criteria on anything less than extreme cold, and certainly not on Ambient Air or Water....
    Jan 2008
    milwaukee
    1.53 was giving me problems when i was trying last week, it was not validating, showing wrong speeds, i would submit one score & it would output another, etc... i will also be waiting for an update i guess.
    daveburt maybe you missed it but it wasnt validating one persons laptop @ 100% stock so i dont think its fair blame it on the people trying to validate high clocks
    LEO!!!!
    amd phenom II x6 1100T | gigabyte 990fxa-ud3 . .
    2x2gb g.skill 2133c8 | 128gb g.skill falcon ssd
    sapphire ati 5850 | x-fi xtrememusic. . .
    samsung f4 2tb | samsung dvdrw . .
    corsair tx850w | windows 7 64-bit.
    ddc3.25 xspc restop | ek ltx | mc-tdx | BIP . .
    lycosa-g9-z2300 | 26" 1920x1200 lcd .
    Oct 2004
    UK, Westbromwich
    Daveburt714, the current version doesnt validate my CPU at stock, or any of my overclocks.
    i Emailed CPU-Z earlier today reguarding this, i just had an email back from Franck Delattre, saying there is infact a Fault with 1.53 and K10 processor's. He has been looking into it today and i just tested out a fix and its validated my cpu and i think hes releasing it.
    So sit tight guys!
    PSU: Corsair HX650w
  18. #18
    Oct 2004
    UK, Westbromwich
    Looks like he has released the fix (1.53.1)
    PSU: Corsair HX650w
  19. #19
    Jun 2009
    Budapest, Hungary
    where can we find it? the cpu-z homepage still has the old version..
    1090T | CH4F | HIS HD5850 | TT EvoBlue 750W | TT Spedo Advance | CM Aquagate Max | Samsung S27A350
  20. #20
    Oct 2004
    UK, Westbromwich
    Quote Originally Posted by beta View Post
    My bad beta, i thought it was released. i must not have copyed over the version he emailed me.
    PSU: Corsair HX650w
  21. #21
    Oct 2004
    UK, Westbromwich
    Here is the link to the fix from Franck.
    http://www.cpuid.com/download/cpuz/cpuz_153_1.zip
    PSU: Corsair HX650w
  22. #22
    Jun 2009
    Budapest, Hungary
    thanks for the link man!
    problem fixed:
  23. #23
    Feb 2006
    ontari-ho (canada)
    So sit tight guys!
    figured as much, Franck is the man and usually way ahead of the game
  24. #24
    Mar 2006
    Central VA, USA
    As of 04/29/11
  25. #25
    Nov 2006
    Poland
    new version of CPUz (1.53.1) doesn't help at all. Still there are problems with high frequences
    http://valid.canardpc.com/show_oc.php?id=909882
    http://valid.canardpc.com/show_oc.php?id=909854
