Phenom II Air/Water CPU-Z Validation Thread:
Rules:
1. Asking for normal 24/7 water or 24/7 air, nothing chilled...unless you chill your water everyday.
2. Anything under a 16-17c+ ambient will not be added, if it looks suspiciously high I'm gonna ask about it. (PLEASE POST YOUR AMBIENT TEMP!)
3. All two/four cores!!!!!
4. Follow the format I have below, if you want, copy and paste and make your changes.
Thanks,
Beeps.
I will update this thread list no less than every two days.
To start off: (Follow this format!)
Validation:
Mad222 - 0942DPMW - Phenom II X4 955 BE C3 @ 4773.4 Mhz 1.568v XXc Air: http://valid.canardpc.com/show_oc.php?id=866961
Moonman - 0946MPMW - Phenom II X4 955 BE C3 @ 4754 Mhz 1.55v 19c water : http://valid.canardpc.com/show_oc.php?id=906016
NCspecV81 - 09?????? - Phenom II X4 965 BE C3 @ 4715 Mhz 1.65v XXc Air: http://valid.canardpc.com/show_oc.php?id=900672
chew* - ???????? - Phenom II X4 965 BE C3 @ 4680 Mhz 1.462v XXc Air: http://www.xtremesystems.org/forums/...1&postcount=16
Charged3800z24 - 09?????? - Phenom II X4 BE C3 @ 4621 Mhz 1.55v XXc Air: http://valid.canardpc.com/show_oc.php?id=90587
theoldtimer - 09?????? - Phenom II X4 955 BE C3 @ 4613 Mhz 1.50v XXc Air : http://valid.canardpc.com/show_oc.php?id=905898
Flank3r - 09?????? - Phenom II X4 965 BE C3 @ 4570 Mhz 1.55v 11c Ambient AIR http://valid.canardpc.com/show_oc.php?id=888341
mav2000 - 09?????? - Phenom II X4 965 BE C3 @ 4400 Mhz 1.55v XXc AIR http://valid.canardpc.com/show_oc.php?id=907125
BeepBeep2 - 0945DPEW - Phenom II X4 965 BE C3 @ 4368 Mhz 1.585v 20c AIR http://valid.canardpc.com/show_oc.php?id=890870
Raiderman - 0941CPMW - Phenom II X4 965 BE C3 @ 4200 mhz 1.52v 23c water - http://valid.canardpc.com/show_oc.php?id=900094
Mav2000 - 0932DPMW - Phenom II X4 965 BE C2 @ 4200 Mhz 1.525v 25c AIR: http://www.xtremesystems.org/forums/...7&postcount=13
RhoXeD - 0851APCW - Phenom II x4 940BE C2 @ 4120 Mhz 1.56V 19c AIR: http://valid.canardpc.com/show_oc.php?id=941020
RhoXeD - 09?????? - Phenom II X3 720 BE C2 @ X4 4040 Mhz NB 2825Mhz 1.56V 22c AIR http://valid.canardpc.com/show_oc.php?id=901970
Stable:
Hedghawg71- 09?????? - Phenom II X4 955 BE C2 @ 3920 Mhz 1.475v XXc AIR: http://valid.canardpc.com/show_oc.php?id=883631
Smile
- You may not post replies
- You may not edit your posts
Forum Rules
