I've got myself a single loop installed in an HAF-932.
DD-CPX PRO>DTEK Fuzion V2>MCP320QP
I am using a T-Line. Installed inside the DD Delrin T is a silver KillCoil, and I only run distilled water. I am using 100% DD G1/4 Fat Boy fittings.
Here is a Google Album if you would like to see pics. BTW, I no longer have those Sapphire HD 4770's, rather a single GTX 285 that is awaiting it's SLI mate.
http://picasaweb.google.com/cestiii/...eat=directlink
I have really enjoyed this setup, it has kept my Q9550, and now my i7 860, comfortably cool in my overclocking adventures.
I have a small problem though. It seems that I have developed some seapage around the inlet fitting going into the V2. It's not enough that I have had to top-off the distilled water, but enough to make me worry about moisture around my CPU and possibly settling onto my GPU.
I am not sure if it is one of the following problems, and I ask for your experiences or suggestions in helping me solve this problem.
1. Could this leak be from the Fat Boy's threads not going as deep into the top of my waterblock? See how the threads engage further on the stock 1/2" fittings that came from D'Tek. (the top fitting is the DD, bottom is the stock D’Tek)
2. Could it be that the zip-ties are not tight enough? I haven't got any leaks anywhere else, but maybe that's where this small amount of leakage is coming from?
3. If I have disconnected the hose from a fitting, will it seal as well as it did the first time if I re-assemble it without snipping off a bit where the barb has made its impression?
I am going to reassemble this loop with some spring type clamps (shown in pic of fittings above) in hopes that it will fix my situation.
Well, if there isn't enough information let me know. I really appreciate any help or guidance you have to offer! Thanks!
