Page 1 of 2 12 LastLast
Results 1 to 25 of 46
Thread: Looking at watercooling
    Dec 2009
    Pretoria, South Africa
    I am looking at water cooling my rather hot computer.
    My hardware that I want to watercool:
    * AMD Phenom II x4 940BE
    * ATI HD5850
    My CPU easily hits 60C at load (Stock speeds - summer) - I have a Cool-it Domino ALC cooler ATM (Stock cooler ran hotter)
    I'm still waiting for my HD5850, but my current HD3850 hits 95C at load (Stock speeds).
    I have a Coolermaster HAF922 case.
    What do the experts think about the following gear?
    * Swiftech H20-220 Apex Ultima kit (Apogee GTZ, MCR220 radiator, MCP655-B pump, MCRES-Micro Revision 2 reservoir)
    * Swiftech Komodo 5800
    * Swiftech MCR120 Rad
    * PrimoFlex Pro LRT tubing
    * Bitspower compression fittings
    My planned loop will be:
    Res -> Pump -> 2x120mm Rad -> Cpu -> 1x120mm Rad -> GPU -> Res
    Any thoughts, comments and suggestions are welcome.
    Xtreme Mentor
    Feb 2007
    Oxford, England
    cant you fit a tripple and a dual in that case, i'd do that, and that water block tbh is pretty old tech now, but the main question is...
    how much money do you have to spend, and what are YOUR "ideal" temps for them both?
    "Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
    //James
    Dec 2009
    Budget is about USD 550 (Plus about USD 120 for shipping - from perfomance-pcs.com).
    Works out $6 cheaper to get a Apogee XT (plus all the other bits from the kit separate)
    I don't know about the GPU because I don't actually have it yet. But the CPU I'd be happy to be in the low to mid 50s @ 3.6 - 3.8Ghz.
    Can't fit a triple in the case without modding unfortunately. Any form of case modifications are out of the question, and I want everything to be internal.
    It has a mount for a double and two 120mm fan mounts (Back and on the bottom). I could get a second single if that will help.
    Xtreme Mentor
    Oct 2007
    USA
    Your up against Physics. You might be fine with a 120x2 and a seperate 120x1. If it's enough depending on your CPU, your ambient room temps, aversion to louder rad fans is an individual thing. Give it a try, and if not enough add the second 120x1. Try to use room air through the rads, not warm case air.
    $120 shipping? wow!
    All stock for now, no need for more, but it's gonna be soon methinks.
    Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
    SLI GTX470 EVGA
    EK HF nickle blue top CPU block (free from Eddie)
    Koolance 470 waterblocks
    One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
    Banchetto Tech Station
    120 GB SSD, and a few other drives.
    1000W UltraX3 PSU, 900 watt (1500VA UPS
    23.999" Acer GD235hz and 24" Acer H243H
    Dec 2009
    Quote Originally Posted by Conumdrum View Post
    [snip]
    $120 shipping? wow!
    The joys of living in South Africa. Super expensive shipping out this way.
    Xtreme Mentor
    Feb 2007
    Oxford, England
    Quote Originally Posted by irenedakota View Post
    imo xt will be better, gpu get the mcw60 and use stock heatsink plate thing (like on 4870/90's ..
    yes you can, look here http://i727.photobucket.com/albums/w...c/DSC_0978.jpg there's the third just under the vent =) get a trip + a single and you'll be good to go
    oh and for ideas look at http://i727.photobucket.com/albums/w...leteLoop-1.jpg
    //James
    Xtreme Guru
    May 2009
    Southfield, MI
    What are your room temps? The other issue you will be facing is that the rads still have to disapate the heat into the air. If your room stays around 32 degree C during the day, a typical watercooling setup still won't net you LOW temps. Your biggest improvement that you could make to your temps is lower your room temp.
    Project Millertime: The Core I5 build
    Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
    Dec 2009
    Quote Originally Posted by Jamesrt2004 View Post
    That's the HAF932 which is a bit bigger the HAF922. I have seen triple setups in a HAF922, but they all involve making new holes into the case.
    Quote Originally Posted by millertime359 View Post
    On a hot day room temp is about 28C. A typical watercooling setup should get me ok temps @ sound levels that are not approaching that of a jet.
    Xtreme Guru
    May 2009
    Southfield, MI
    It will help, but you may want to look into a 3x120 for your CPU and 2x120 for your GPU. That way you have plenty of surface area seeing you seem to be battling against some pretty high ambients.
    Dec 2009
    Nowhere to mount a 3x120, and or an extra 2x120. The best I can do is a 2x120 and 2 1x120s (Which, according to other South Africans I've spoken too should be enough).
    Xtreme Mentor
    Feb 2007
    Oxford, England
    ah sorry my friend i got muddles up with the cases humm double plus 2 singles then maybe
    //James
    Dec 2009
    Here is a simple mockup of my planned loop:
    Any thoughts?
    Xtreme Guru
    May 2009
    Southfield, MI
    I would make some measurements of that bottom section. You might not have room for the second 120x1 with the PSU and wires coming out. I don't know though.
    If you don't mind doing some modding and using an external DVD drive, you probably could get a 120x2 in the front drive bays.
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    wait isnt every other person a princess of a rich super billionare over there?
    i get email from all your princesses asking me to help them move money in to the US.
    (just kidding) :P
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Dec 2009
    I'd rather not do any modding (But if it is a tiny bit I might be persuaded).
    Don't really need an internal DVD drive, and I already have an external one taking up space on my desk. Thanks for the tip - I'll certainly look into putting a 2x120 in front, then I won't need the 1x120s right? Or would you still suggest putting in a extra 1x120?
    Quote Originally Posted by NaeKuh View Post
    (just kidding) :P
    That's Nigeria, not South Africa
    Xtreme Guru
    May 2009
    Southfield, MI
    I'm just worried about your high ambients with your wish to overclock.
    2 mcr220-qp with so 1450-1850 RPM Gentle Typhoons or S-flexs would probably be ok. Seeing that shipping is expensive and if there is enough room for a mcr120-qp and another fan, it might not be a bad idea to add it.
    Dec 2009
    Thanks a bunch.
    Once I've finalised my shopping list, I'll post here again to make sure I haven't missed anything.
  18. #18
    Dec 2009
    Here is my shopping list
    Anything that I should change/add or that I have forgotten? I'm going to be buying the fans from a local retailer (Works out cheaper).
    One slight problem that I have found is that the Apogee XT have a AM2 hold down plate (yet). Any suggestions for an alternative water block?
  19. #19
    Xtreme Guru
    May 2009
    Southfield, MI
    Alright, not certain why you have 5 barbs, 10 clamps, and 8 comp fittings. You will either use the barbs or the comp fittings, but not both. If you want the comp fittings, drop the barbs and clamps.
    The AM2 backplate is out now, you will have to contact Michelle at Swiftech to get it though. IIRC, they ship it out for free on request. You might want to e-mail her to be certain. Michelle@swiftech.com I think.
    I would get this pump: http://www.performance-pcs.com/catal...oducts_id=2539 and this res: http://www.performance-pcs.com/catal...ducts_id=23357
    Damn, that res is OOS. That combo would have probably been a bit easier for you to mount. If you are going to get the D5 though, I would recommend getting the speed control version. You have the ability to turn the pump down if you find it too loud for you.
  20. #20
    Dec 2009
    Those barbs are 2packs (So 10 barbs). My thoughts are that since comp fittings are quite a bit more expensive then barbs, but they look much nicer then barbs, I will use the comp fittings on the things that will be visible from outside.
    I did look at that pump, but it has 3/8" barbs (And I'm using 7/16" tubing) - can you change the barbs on the pump?
    As for the OOS res, it will probably be in stock again when I actually buy the stuff. First need to get paid
  21. #21
    Xtreme Guru
    May 2009
    Southfield, MI
    You will take the top off that pump and then attach that res to the pump. It has G 1/4" threads, so no issues there. It is a nice neat little package and seeing you are tight on space, it should fit better than the D5 and Swiftech res.
    Honestly, I wouldn't mix and match them. You have some nice looking clamps there, I would just choice either one. You have only need like 12-14 comp fittings anyways, and you already have 10 on order. Just trying to save you a couple bucks here.
  22. #22
    Dec 2009
    Thanks for the help!
    I didn't realize that the res sits on top of the pump. That will make things easier.
    For cost reasons I think I'll rather go with the barbs with clamps.
    I've found this very nice water cooling setup in the HAF 922:
    From: http://www.overclock.net/case-mod-wo...ooled-haf.html
    That case has been modded quite a bit (For one the hdd bays have been removed). But it does show me that I will be able to easily fit a 1x120 rad in the bottom (I have the same psu)
    And I heard very good news today. My GFX is finally on its way to me. Might be here tomorrow (But I don't think so since tomorrow is a public holiday here)
  23. #23
    Xtreme Guru
    May 2009
    Southfield, MI
    Nice, seems as long as you don't have a 1000 watt PSU, that rad will fit on the bottom.
  24. #24
    Muslim Overclocker
    May 2005
    Canada
    I have got a question, will the MCP655 be able to give you reasonable flowrates with that many rads?
    I am also surprised at your current setup because your res is going to carry the really hot water coming from the GPU. That also means your pump will be running hot water as well. It would make more sense to me to have the water out of a rad and into the pump but I don't know anything about water cooling just looking at it logically.
    My watercooling experience
    Water
    Scythe Gentle Typhoons 120mm 1850RPM
    Thermochill PA120.3 Radiator
    Enzotech Sapphire Rev.A CPU Block
    Laing DDC 3.2
    XSPC Dual Pump Reservoir
    Primochill Pro LRT Red 1/2"
    Bitspower fittings + water temp sensor
    Rig
    E8400 | 4GB HyperX PC8500 | Corsair HX620W | ATI HD4870 512MB
    I see what I see, and you see what you see. I can't make you see what I see, but I can tell you what I see is not what you see. Truth is, we see what we want to see, and what we want to see is what those around us see. And what we don't see is... well, conspiracies.
  25. #25
    Xtreme Guru
    May 2009
    Southfield, MI
    Quote Originally Posted by ahmad View Post
    You always do res before pump. It is for bleeding and filling purposes. If you have the res below the pump, you will take the chance of running your pump dry.
    Tests have been done and loop order doesn't matter outside of res before pump.
