There is nothing wrong with Raven 2 temps
for me.
I own the case for around 2 weeks now, and can give you some input.
First of all, the case is pretty much separated into 2 areas: 1) CPU / NB / RAM / VREG / PSU and 2) VGA / drives.
FUD uses 4 sections, I am just simplifying this a bit.
Talking about the 1st one.
There is only one exhaust for the entire area, and it is a 120 mm fan at the top. Its performance is crucial. The included 120mm fan (1200 RPM, low performance, too) - ditch it.
I can give you some numbers.
Using GT as an exhaust fan.
I have EVGA Classified with a passively cooled NB (I'll get a 40 mm fan in a few days) which responds to the airflow change perfectly.
GT @ 700 RPM, 180 mm fans @ low = 76C, very hot NB temps. Nearly silent.
GT @ 1700 RPM, 180 mm fans @ high = 56C, pretty cool. Yes, here is your huge temp difference. Very low noise at that.
Talking about the 2nd area. I have no idea what's up with your temps.
It's pretty well made, especially for 5870 (I have a single VGA card).
The 180 mm fan in the middle provides airflow for
2 holes at the end of the 5870's heatsink.
The 180 mm fan which is closer to the drive bay provides the cool air for the
turbine cooler intake at the side.
5870 has 2 exhausts,
the one at the output ports obviously works well, and
the one at the side of the card... There is a nice
mesh area at the top of RV02 that helps get rid of the hot air coming from that exhaust.
My VGA fan speed is on auto, in idle it's at 21%, inaudible, in Furmark it goes to 25%, still silent...
I'm not trying to say that
nascasho is not telling the truth or something, but just trying to point out the fact that RV02 can still work out pretty well for some people.
It looks great, cable management is great, too (especially the top area with the motherboard USB / VGA / audio / etc connectors, all cables in one place, sweet!
), plus it's much smaller than regular full towers, like 10 sm less tall.
Sorry for my English, hope I made myself clear.
