Case upgrade recommandations for my watercooling build
Hello gentlemen,
Some of you react on some photo I've published here in the Liquid cooling forum, and I they are right. My current Lian Li X500 chassis is really too ''small'' to really host all the components I've build into my system.
The choice of the Lian Li X500 was done 4 monthes ago... when I was using Air Cooling but today.... it's my 4th watercooling build into this chassis (3 upgrades) and there is lack of space...
I need your expertise to select the appropriate case that will replace my Lian Li X500.
Here bellow here are some photo of my build today. When I was ''Air cooled'' that was not a problem but today...
So can you please make some recommandations to help me choosing the right model of case, where I can build both 480 and 240mm radiators with 6x 120mm fans? everything internally.. this time ^^
Thank you very much for your help!
- You may not post replies
- You may not edit your posts
Forum Rules
