Handpicked an CACYC with BPMW0939 stepping
Boring to see, no L3 cache, and no fourth core...
And after ACC activated, still the stock vcore (1.250v)
3.0GHz and 2.4GHz IMC/L3 @ stock vcore
Ivy Bridge 3770K @ ????MHz
6c Intel Xeon X7460 24MB cache 16GB RAM 22TB HDD fileserver
Dual Intel Xeon E5620 workstation
SB 2600K @ 5016MHz 1.37v HT on AIR primestable
AMD Athlon X3 425 @ B25 4GHz+ AIR
AMD Athlon X2 6400+ @ 3811MHz AIR
AMD Athlon X2 3600+ @ 3200MHz AIR
AMD Athlon XP 1700+ @ 2714MHz AIR
Thermalright Ultra-120 Extreme
Corsair 8GB XMS3 2000MHz
ATI Radeon HD5850 @ 1000MHz+/1200MHz+
Windows 7 Enterprise x64
Corsair HX750W
-UPDATE-
Still stock vcore (1.250v) and 3.2GHz with all 4 cores and L3 cache unlocked:
Corsair HX750W
-UPDATE2-
Well, i was quite sure that the CPU would crach, but no... 3.4GHz and still 1.250v, or exact 1.240v:
More to come... Next stage is to see if 3.5 or 3.6GHz @ same vcore is possible. Smells good over 4Ghz![]()
Corsair HX750W
lol it looks like u got yourself a 965 x4 that was re binned to meet demand (i would have to think to get that clock on that voltage), but why the low HT link speed?
Dragon
http://smbach.com/mad.gif
Opty 175 Rig
Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
AM3 Rig
Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
DFI NF4 BIOS Guide
Max stable frequency is 3450MHz in prime on 1.24v (stock vcore) now it's time to see how it scales with higher vcore. I think that is quite impressive for this X3 425
When OC to find max stable frequency it's important to eliminate all other factors so nothing else stops. Hypertransport bus speed is hardly important in a consumer-pc, even under real use.
Corsair HX750W
Excellent, Thank you and Nice Job![]()
I want to see 4ghz
keep pushing![]()
was only referring to his last 2 pics, was just wondering why he dropped it then mostly, and not to begin with
Dragon
Opty 175 Rig
AM3 Rig
DFI NF4 BIOS Guide
I bought one of these, too... AACYC AC 0923EPMW. $68 shippedI wonder if will run as good as the badboy OP got
--->TeamPURE<---
Are these easy to come by? It doesn't look like they are flying off the shelves.
Fast update
Corsair HX750W
Hmm. Seeing what kind of voltage for 4 GHz...it really makes me want to take that Sempron 140 back from my dad. 3.9 GHz stable on the stock Sempron heatsink w/gigabyte 785gm-us2h at 1.4v. New heatsink + better board for tweaking = oh man.
Computer:
Case: Corsair 750D Airflow Edition
Mobo: Gigabyte Aorus X570 Ultra
RAM: Team TForce Xtreem ARGB 3600C14 2x16gb XMP
CPU: AMD Ryzen 5900x
Graphics: EVGA (rip) RTX 3080 FTW3
PSU: Seasonic Focus GX 850w
Cooling: Arctic Liquid Freezer II 360mm
NVMe: SKHynix P41 Platinum, Samsung 980 Pro 2tb
SSD: Micron 1100 2TB, Samsung 860 Evo 1tb
HDD: WD SE 2TB, WD Black 1tb 3 platter with over 10 years of power-on time
The PWM on the MSI 790GX Platinum was now up in smoke, so I throwed in an Gigabyte 790X-UD3P. See how it goes then... maybe higher OC.
Corsair HX750W
Time sucks, but just to test how far I I could lower the vcore with 4GHz freq
Also, this Gigabyte board is not as good as the earlier MSI DKA790GX Platinum I had.
Corsair HX750W
