ATI Radeon HD 5870 model has the industry's fastest single GPU solution, AMD ATI Radeon HD 5890 has a higher operating frequency model can be introduced. Firma cephesinden konuyla ilgili resmi herhangi bir açıklama yapılmasa da, ATi Radeon HD 5000 serisi için GPU'larındaki hız aşırtma başarımını sık sık gündeme taşıyan AMD özel seçim GPU'ların kullanıldığı, standart çalışma frekansı arttırılmış ATi Radeon HD 5890 modelini Nvidia'nın olası bir GeFoce GTX 360 / 380 atağına karşılık olarak, Ocak veya Şubat ayları içerisinde kullanıcıların beğenisine sunabilir. Company in front of any relevant official statement will not be, ATI Radeon HD 5000 series for GPU'larındaki overclocking performance often move to the agenda GPUs, AMD used a special election, the standard operating frequency for increased ATI Radeon HD 5890 model, a possible Nvidia GeFoce GTX 360 / 380 in response to attacks, during the months of January or February may offer users to the taste.
Can we just ban this guy? We don't need people coming in here claiming they know someone that's under NDA. Everything that comes out of this posters posts are nothing but delusions from a fanboy.
__________________
Work Rig: Asus x58 P6T Deluxe, i7 920 20x200 1.425v HT on, BIX2/GTZ/D5
3x2048 GSkill pi Black DDR3 1600, ECS 9600GT
PCPower & Cooling Silencer 750, CM Stacker 810
Game Rig: Asus x58 P6T, i7 920 20x180 1.275v HT on, TRU120
3x2048 GSkill DDR3 1333 7-7-7-18, MSI GTX260 OCv2
PCPower & Cooling Silencer 750, CM Stacker 830
Somehow I find it hard to believe they're going to move to a 28nm process when they're having problems with the 40nm process. I'd surely like to see it, but I'm not holding my breathe.
Yeah, 28nm would be a joke right now unless someone is hiding something. Whole image looks like a wishful fake thing.
well the time frame looks fishy , but Gf is skipping 32nm and going straight to 28nm. I think this is the same move as they did with the 4770 to test the process.
QFT!
__________________ Adobe is working on Flash Player support for 64-bit platforms as part of our ongoing commitment to the cross-platform compatibility of Flash Player. We expect to provide native support for 64-bit platforms in an upcoming release of Flash Player following the release of Flash Player 10.1.
there are quite a few flaws in that spec sheet. first is the bus width(384), which ATI will not shift to anytime soon since GDDR5 speeds are on the rise
Secondly, even if the 384bit bus is true, those memory capacities are impossible. 1024/2048 on a 384bit bus? Zz
Third, with the current 40nm process, and the performance scaling of more shaders in this architecture, a change in clockspeed will have much more of an effect than adding 320 shaders. So, they will not try to widen the architecture to accomodate more shaders, achieve not that much more performance, and lower the yields even further. Also 28nm in Q1? ROFL
I bet the 5890 will be a 5870 with boosted clocks. And that will own. End of
there are more flaws too, take a look at the 5860,
__________________
Watercooling parts:
Pa120.3 rad (CPU)|PA120.3 (for video card)|GTZ on CPU
|stock cooling on chipset|Laing DDC w/ Petra'sTech DDCT-01s Top on cpu loop|aqua extreme 50z pump on gpu l
cpu i7 960 @ 4.2Ghz Evga x58 E760
Gigabyte EX58-UD5 F9e bios 12GB of G.skill (6 x 2GB)DDR3 perfect storm F3-16000CL8-2GBPS 7-7-7-21 ATI 5970 new Dell 30"LCD 3008wfp oh the colors!
LG GGW-H20L
COOLER MASTER Real Power Pro RS-C50-EMBA-D2 1250watt for the cpu/mobo & video
OCZ600MXSP 600W for the hard drives
areca 1280ML with 2GB ecc of cache running in other 16x pci-e slot with battery backup running two raid 10 arrays 2TB boot array 7TB storage
sound card: Auzentech Forte 7.1 | Gigaworks S750 7.1 speakers
OSes: debian Linux unstable, and Windows XP pro x64 w/sp2| testing windows 7 x64 ultimate
This is fake. 28nm before, at the earliest, 2H10 is just not happening
__________________
Seems we made our greatest error when we named it at the start
for though we called it "Human Nature" - it was Cancer of the heart CPU: AMD X3 720BE@ 3,4Ghz Cooler: Xigmatek S1283(Terrible mounting system for AM2/3) Motherboard: Gigabyte 790FXT-UD5P(F4) RAM: 2x 2GB OCZ DDR3 1600Mhz Gold 8-8-8-24 GPU: Connect3D HD3870 512MB Cooler: Zalman VF1000-cu PSU: Seasonic M12D 750W Case: Coolermaster HAF932(aka Dusty )
well they still could bump clocks, add more ram, and two 8 pin to the 5990 and still do it on the 40nm process. As for the other stuff I doubt that.
__________________
Watercooling parts:
LG GGW-H20L
