XtremeSystems Forums
Reply
Old 12-08-2009, 12:50 AM   #1
bundymania
bundymania's Avatar
Lightbulb SIZE MATTERS: Radiators for 140mm Fans - Big Roundup
(translated by Google, so beware of some errors )
Hello friends of the wet element,
in fact, one could advance already come to the following conclusion: The size is still important!
Now, however, the technique is essential, otherwise all the radiators of this test would be on a level of performance.
But first things first: As the reader has already been easily noticed, is what this review to the new
Power superclass of the heat exchanger, namely internally for sheeting radiators, for the increasingly popular 140mm fan! This fact is in a relatively quieter background noise while maintaining good cooling performance as the previously
so popular for 120mm fan radiators founded. As a rough rule of thumb one can say: A rad fitted with 3 x 140mm radiator fans of the new generation is about the power of a Quadradiator, which is designed for 4 x 120mm fans. Since many case manufacturers have already for some time for 140mm fan designed models in the portfolio,
It was only a matter of time, until you can buy suitable heat exchanger for this increase in performance.
As the demands and desires of the users are very diverse, I have decided to not only one size in
take my test box, but take into account almost all available Radiators for the big fan of!
Speaking test field, the ranks of the radiator to be tested are joined by the following models:
Hardware Labs Black Ice SR1 280
Technical details:
Dimensions: 315 x 54 x 153 mm (WxHxD)
Material: Copper, brass
Color: Black
Weight: 1.09 kilograms
Connections: 2x G1 / 4 inches
Fan Compatibility: 2x 140 mm
Fan Mounting: M4 threaded (both ends)
Price: about EUR 105
HW Labs Black Ice SR1 420
Technical details:
Dimensions: 459 x 54 x 153 mm (WxHxD)
Color: Black
Weight: 1.5 kilograms
Fan Compatibility: 3x 140 mm
Price: about EUR 135
HW Labs Black Ice SR1 560
Technical details:
Dimensions: 604 x 54 x 153 mm (WxHxD)
Color: Black
Weight: 1.94 kilograms
Fan Compatibility: 4x 140 mm
Price: about EUR 180
The company's hardware labs for many years successfully established and offers a wide selection of high quality radiators
in many sizes and variations. One feature distinguishes this from all the models: The workmanship is first class!
The new SR1 Radis are, fortunately for both 120mm and 140mm fan available from single-to Quadradiator.
So far, Black Ice Radiators have been due to their dense fin density rather rapidly rotating fan beyond 800 rpm. optimized and were able to heat from other manufacturers in Europe, especially in the popular low revs hard to argue in comparative tests. This event can now be safely placed with the SR1 series on the file, because with this new radiator series hardware labs now promising products brought to market, which were also optimized, especially for less air flow! A peculiarity is the different distance from the fan blades: On the side without
The two threaded connection is down this much larger, which represents a kind of shroud, ie the dead center under the
Fan hub is significantly reduced, which leads to better overall performance! Of course I have the fans on both sides
assembled to determine the differences. On the page with "Shroud" stood a better fan speed according to the Delta-T
Value of max. 0.7-up! In my results tables, I have both the best value, ie, with assembly on the "Shroudside" is used.
Like the 480s SR1 Radi, can convince even the models for 140mm. The performance is very good and are processed by the
there is currently nothing better on the radiator market.
The SR-1 series white at first glance like: the matte black finish is flawless, all threads have been immaculately produced, and the fins have turned out very coarse meshed, so as mentioned below is ideal for slow-spinning fans and accordingly noise! For this test, I was kindly of SR1 560 and SR1 280 of the company www.caseking.de sent. The SR1 420 Model I got from www.ac-shop.de provided.
My thanks goes also to Mr. Wilbert Yuque from hardware labs.
Thermochill PA 140.3 Triple Radiator
Specifications:
- Color: matte black
- G 3 / 8 "connectors
- Tank: brass; fins: copper
- Weight: about 1.82 kilograms
- Dimensions (LxWxH): 480 x 142 x 62mm
- Price: about EUR 110
Almost as a living legend, one could describe the radiators in the UK-based company Thermo Chill.
In the past, many test victories worldwide have been retracted, but there were also some points for improvement.
The finish was sometimes left to be desired at times and some users reported by impurities in the interior, which
during flushing of new Rads came to light. Other features of the thermal radiators TC are the two connecting thread,
which runs in more exotic G 3 / 8 "thread adapter, and can therefore be in most cases a necessity.
Furthermore, the so-called hole size for the fan was slightly larger than that of heat exchangers of the competitors, so that one normal
Not able to use radiator panels for the Case integration and was dependent on specific panels.
The finish is with my pattern out to be much better than it used to in the TC Rads was the case and offers
no reason for complaint.
At the held in the English language leaflets to rinse with warm water before first use is recommended to
to liberate the Rad of any production residues. It was struck directly at the first flush or almost clear water
from 140.3 to appear, even at this point was thus improved compared to older models of anything!
The 420s Rad from the house can convince Thermochill completely in this test of the performance and can be the first place in
This radiator size to win for themselves! The only downer at the moment poor availability in Germany was
mentioned but in neighboring countries, fortunately, these models during www.highflow.nl and www.it-service.be available!
Magicool Slim Dual 280 MC
Specifications:
Material: Copper, brass auricles
Dimensions: (L x W x H): 323x142x29mm
Connections: G1 / 4 "
Weight: about 646g
Mountability: from both sides for fan or as a holder
Airtight: 8 bar
Connection: 2x thread G 1 / 4 inch
Fan connecting thread: M3
Price: about EUR 42
Magicool Slim Triple 420 MC
Specifications:
Dimensions: (L x W x H): 465x142x29mm
Weight: about 860g
Airtight: 8 bar
Price: about EUR 58
The Magicool radiators out of the house are known for their good performance at a relatively low price. Here and there
may miss a thread not be ok, but this one takes as preisleistungsbewusster buyers like to purchase. Also in
This test can convince the models of Magicool. From the performance for many applications and has sufficient
3 sizes available. Due to the low mounting depth can the Radis platsparend and unobtrusively in many housing
. integrate On the housing market have been some housing available in the Model 280s without the modifications
to assemble, more will surely follow soon.
TFC Monsta Lite 420/360 Radiator
From TFC - The Feser Company reached me the prototype of a Monsta Lite radiator.
Prototype because of possible changes to the final retail version, which is positive for
can affect the performance! The radiator should be out in spring of 2010 with a retail price of approximately EUR 150
in the trade as already come and get the big brother with a comprehensive package accordingly.
Thanks to a clever craftmanship there can be mounted both 120mm and 140mm fan, this option so far is unique
on the radiator market! Furthermore, the usual 2 G 1 / 4" threaded 2 additional threads on the front
the TFC Monsta Lite available, which one at about 10 liters of increased flow and a greater variety
The tubing of the heat exchanger brings with it!
Even though the "little monster" of the performance is not quite the best in this test field radiators
could catch up, so the whole concept could convince yet and is already as large Monsta
Radiator will find its fans worldwide!
you can extract the technical data from this PDF File:
http://www.tfc-xchanger.com/pdf/TFC-X420L.pdf
Last but not least, and virtually not competing, I have one as a comparison Dualradiator included in the test with
Specifications:
Dimensions: (L x W x H): 273x121x30mm
Weight: about 680g
Mountability: 8x M3 threaded top (for 2x 120mm fan), 8x M3 threaded bottom (for 2x120mm fan)
Airtight: 8 bar
Hole distance: 6 cm
Price: about EUR 29
Testsystem / Process:
Case: Banchetto 101 Bench Table
Board: Gigabyte GA-EX58-Extreme
CPU: Intel Core i7-920 @4.2Ghz - 1,40V (Bios Setting) - Bios: F4
RAM: Patriot Viper DIMM Kit 6GB PC3-12800U CL8-8-8-24
Gfx card: EVGA GTX 295 (not included for this comparison!)
Netzteil / PSU: Xilence SPS-XP850.XQ.R2
CPU Waterblock: Watercool Heatkiller 3.0 Nickel Edition
NB Waterblock: Mips Fusionblock
Control Unit: Aquaero VFD
Flow Sensor: Aqua Computer Highflow
Thermal Compound: Gelid Extreme
Pump: Laing Ultra (Koolance PMP400 Deckel)
Pump Noise Absorber: Noise Destructor V1.1
Tubing: Feser/DD 16/10mm
2x CPC 9,5mm Metal
Ausgleichsbehälter: Alphacool Cyclone 250
Tempsensors: 3x Inline +1x in Res.
Wasserzusatz: Feser One Fertigmischung UV Clear/Blue
Fittings: Perfect Seal + Bitspower
Fans used: Noiseblocker Black Silent Pro PK2 + PK3 (PL2 on Magicool Slim 240)
To fill the CPU is Prime95 (small FFT's) used in the latest version, to measure the
Temperatures / record came aquasuite used. The temperature measurements were made after the earliest
60 min and then in 5 intervals, a 5 minutes.
In my testing, the most interesting value of the difference (delta T) is the temperature of water at the outlet of the radiator. This figure shows the cooling capacity of the radiator, into which you can see, can take advantage of how well the radiator to cool the inside temperature of the water. The smaller this difference turns out, the stronger the performance of the radiator. The results will be visible to the interested user at a glance, so I will confine myself in addition to the flow of that value in the different fan speeds.
Difference (delta T) from room temperature to water temperature)
(a low score is better)
Flowrate
Liter / hour
Conclusion:
80mm fan in the case sector were until a few years, Standard, this was followed by the hitherto popular 120mm fans
and so it is really just a matter of time until those from the 140mm previously rather rarer still used by representatives of its
Species to be replaced. More and more manufacturers are adopting this fan size and rightly so. In this test, the radiators
has been shown that the development goes on, fortunately more power and less noise. During
all sorts of annoying noises of everyday life, this is very commendable, they nevertheless give latest processors and graphics cards quietly
and cool more effectively. A clear recommendation for a radiator model could be due to different needs and requirements
not naturally inclined to express the water cooler. In the upper performance range Thermo Chill and Hardwarelabs have
impressively demonstrated, where the bar is located at radiator of this size at this time. The heat exchanger can be of Feser
equip themselves with fans conveniently in 2 sizes, advantageous for many around and intermediates, which are the costs of
Save the purchase of new 140mm fans want first. Are a good idea at this point, the additional threads
called at the front of the radiator. As might be expected to have the Magicool Rads again as price-performance
assert winner in this test. Here and there a thread was not cut 100% and the build quality is noticeably
behind the Black Ice SR1 series, but due to the comparatively low price and the offered services, these radiators
definitely worth a recommendation for the budget-conscious users. Who the best synthesis of performance and outstanding
Processing is looking, just come by to SR1 radiators manufacturer Hardwarelabs not. Very impressive is especially
Proved 560s exchanger, which means pure performance. High-end PC systems with 2 video cards can be with this model
cool very well - the performance has to be even before that of a Mora 2 Pro's Monsterradis not hide!
One can only wonder what will bring us this 140mm radiators and other manufacturers in the future,
a very good beginning has been made! Hardwarelabs was sort of a pioneer, as far as radiators in this size, so
the GT and GTX versions available for some time. As these models, primarily for high-speed and high Fans
Air flow shall be designed, I did not apply to voting in this test.
If available, I will review these with other radiators for complementary 140mm fan!
Many Thanks for supporting my Review goes to the following companies:
www.a-c-shop.de , www.alphacool.com , www.mips-computer.de , www.caseking.de , www.magicool.biz, www.feser-one.com , www.gelidsolutions.com , www.laing.de , www.hardwarelabs.com , www.watercool.de , www.thermochill.com , www.highflow.nl , www.it-service.be , www.xilence.de , www.noiseblocker.de
__________________
Roundup: 22 CPU Waterblocks
Quad Radiator Roundup - 11 Rads tested
Alphacool Cape Cyclone 38 HF 150 Reservoir Review
Black Bullet: Corsair Obsidian 800D Intel Core i7 920@4Ghz EVGA X58 SLI LE @MIPS Waterblock Crucial RealSSD C300 128GB Mushkin 6GB DDR3-2000 Kit EVGA GTX 480 Samsung 3 x 1 TB F1 HDD Creative X-Fi Xtreme Music Cougar S700 PSU HP w2408h // Watercool Mora 2 Pro Rad. Laing DDC Ultra @Zern P12 Top Watercool Heatkiller 3.0 Chrome Edition Aqua Computer Aquaero VFD Alphacool Cyclone 200 Res.
Testmachine: Banchetto 101 Gigabyte GA-EX58 Extreme Intel Core i7 920 Sapphire Radeon HD 5850 Corsair 6GB DDR3 1600Mhz Samsung 2TB SATA F1 HDD Seasonic M12D-850 PSU
HTPC: Antec Fusion Remote Max Gigabyte GA-MA69GM-S2H AMD BE-2350 Noiseblocker Twintec Aeneon 2GB DDR2-800 Asus Radeon HD 4350 WD 2TB HDD Xilence XQ LinearPower 850W PSU Samsung LE-40M86BD Onkyo TX-NR807
Server: Lian Li A05 -modded- Intel E5200 @3.2Ghz ASUS P5KPL-AM Patriot DIMM Kit 2GB ATI Radeon HD 4670 @ Alphacool Waterblock Western Digital 1.5GB HDD Magicool Slim Triple Rad. XSPC 450 Pump Corsair HX 450W PSU
Notebook 1: Samsung 17" SE11 Aura P8400 Donato - NB2: Samsung 17" E272 Aura Erohl // XBOX 360 Elite // Nintendo WII // Motorola Droid
bundymania is offline   Reply With Quote
Old 12-08-2009, 01:13 AM   #2
Jamesrt2004
Xtreme Mentor
Jamesrt2004's Avatar
Send a message via MSN to Jamesrt2004
imo i'd go for thermochill out of that review,
nice one easy to read and understand
__________________
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
Jamesrt2004 is online now   Reply With Quote
Old 12-08-2009, 01:44 AM   #3
PiLsY
Technician
PiLsY's Avatar
Depends on the price we can find those magicool slims for though James. If theyre around the £30-£40 mark you could get 2 for the price of a single thermochill.
Thermochill definitely win on the performance front though. Discounting that huge 560 anyway .
Monsta Lite = Phobya G-Changer?
PiLsY is offline   Reply With Quote
Old 12-08-2009, 02:10 AM   #4
bundymania
bundymania's Avatar
nope, G-Changer Rads are available only for 120mm fans
__________________
Old 12-08-2009, 02:31 AM   #5
Anemic
Anemic's Avatar
Very good review! Very usefull information. Thanks for your hard work!
__________________
Loonym...You are missed.
The element of one
Breathe me in
Breathe me in
I disbelieve in separation. I close my eyes to see you.
This is for you, everything I am. This is for you, take it from me.
I, I disbelieve separation. I close my eyes
there's no escaping me
In your heart in your soul. I perceive rejuvenation
Breathe me in. I am forever. Deep within I am eternal.
I will return to you. I am with you always. I will never turn away from you.
Anemic is offline   Reply With Quote
Old 12-08-2009, 02:41 AM   #6
bundymania
bundymania's Avatar
Thanks mate ! I´m already working on more reviews. There are 5 or 6 Reviews on my to-do-list Stay tuned.
__________________
Old 12-08-2009, 02:48 AM   #7
Fearlessleader
Fearlessleader's Avatar
Ya that was some helpful info I was just thinking on using a 280 instead of a 240 or a 360 myself.
Thanks for the post
__________________
Motherboard Asus P6T deluxe V1 1303 bios
CPU I7 920 CO 1.35 volts 4.0 GHZ
Memory 6GB CORSAIR TR3X6G1600C8D
Video Card Asus Hd 4870x2 Swiftech Caldera 4870X2 block
Hard drive Velociraptor 300gb
PSU COOLER MASTER Real Power Pro RS-C50-EMBA-D2 1250W
DVD TSSTcorp CDDVDW SH-S203B
Case CM Stacker Aluminum
Water cooling custom Dual loop
Primochill Typhoon III, Feser 360 Black Ice 240,Laing D5 Pump and Swiftech Mcw30 north bridge block
Monitor Samsung Syncmaster T240 Touch of Color
OS Win 7 Ultimate Retail
My Latest clock of the E8700
http://valid.canardpc.com/show_oc.php?id=892338
Fearlessleader is offline   Reply With Quote
Old 12-08-2009, 03:15 AM   #8
WeeMaan
WeeMaan's Avatar
You should have put som 120.x in there, so we with 120.4 / 120.3 now if we need to upgrade.
__________________
Project TJ07 WeeMaan edition in progress...
i7 920 @ 4,4ghz, P6T Deluxe, Corsair Dominator 6Gb, HD5870, OCZ Vertex 60gb + Samsung F1 1tb
Heatkiller copper, EK 5870, Thermochill 120.4, DDC 3.2
WeeMaan is offline   Reply With Quote
Old 12-08-2009, 03:44 AM   #9
bundymania
bundymania's Avatar
Yeah, I've thought about it, but then decided to involve almost exclusively 140mm Radiators with, because otherwise it becomes a bit confusing, and if I have quad radiators in the test, the next user would like to see triple rads for comparison, next guy wants mora in it, and so on
I will release an upgrade of my quad radiator review soon (maybe in english too) with up to 10 models and very simliar hw config, so the interested users can check this review for comparison.
http://www.highflow.nl/forum/f18-hig...oduct-reviews/
__________________
Old 12-08-2009, 04:29 AM   #10
gmat
Automatic translator produces some unreadable stuff:
...or sometimes very funny quotes:
the thermal radiators Churchill
Nice test
If i have time i'll try several 140mm fans on my 280 SR1. At least comparing between the Nanoxia and Thermalright 140mm offerings (i'll be using the TR fans first for my setup).
gmat is online now   Reply With Quote
Old 12-08-2009, 04:36 AM   #11
bundymania
bundymania's Avatar
hehe, yeah that´s funny - i already fixed some other passages, for example: when i wrote radi (german shortcut for "radiator") it was translated in CAR !
__________________
Old 12-08-2009, 05:38 AM   #12
Kozato
It looks a 420 SR1 is on my list of upgrades in the near future.
__________________
Click for worklog: Project BlackSquare
Kozato is offline   Reply With Quote
Old 12-08-2009, 05:56 AM   #13
Boulard83
Boulard83's Avatar
very good review !
__________________
• Le Québécois •
Asus P6TD Deluxe ** tweeking OC **
920 D0 @ 4.0ghz (21x191) @ 1.2815v bios
3x2gb Gskill Trident @ 1528mhz 7-7-7-21 1.54v
Asus HD5870 @ 950/1300 1.175v
2xMCP655 / TFC360 / GTZ / Komodo
TPQ-1200 OC • X25-M OS/Apps • WD VR Games
Boulard83 is offline   Reply With Quote
Old 12-08-2009, 06:48 AM   #14
SimpleTECH
SimpleTECH's Avatar
Hopefully that SR1 560 comes available soon cause I want one!
__________________
Rig:
Intel Xeon W3520 @ 4.2GHz (1.20V) | Gigabyte GA-X58A-UD5 | OCZ Platinum 6GB PC3-12800 (7-7-7-24) | XFX HD 5870 | 2x Intel 80GB G2 SSD RAID 0 | X-Fi Titanium Fatality | Corsair HX850 | CoolerMaster ATCS 840 (Black) | Westinghouse L2410NM / LG L246WP-BN | HP 2335 → Nintendo Wii
Cooling:
HEATKILLER LT CPU Waterblock | Laing DDC-3.2 w/ XSPC Reservoir Top | XSPC RX 480 w/ Scythe Gentle Typhoons
Backup Rig:
Intel i7 875K @ 3.94GHz (1.30V) | no motherboard (7-10-10-28) | Gigabyte HD 5770 | Corsair HX650 | Thermaltake Element G | IBM 21" CRT (1600x1200 @ 100 Hz)
SimpleTECH is offline   Reply With Quote
Old 12-08-2009, 07:44 AM   #15
aka_GK
aka_GK's Avatar
Send a message via ICQ to aka_GK
that is exactly what I wanted to read - I purchased PA140.3, but haven't tested it yet
thanks for the review bundymania!
What can you say about those NB PK fans? I've just ordered a bunch of them
__________________
Worklog: Project Black Copper
Lian Li PC-P80 | Thermochill PA140.3 | Noiseblocker fans | mdpc-x stuff
aka_GK is offline   Reply With Quote
Old 12-08-2009, 10:19 AM   #16
Ketzer7
Ketzer7's Avatar
Well, they definitely exist, but it's strange that no US shops have any of the 140mm based SR-1 rads yet. Guess HW Labs sent them all to the EU channels heh
Ketzer7 is offline   Reply With Quote
Old 12-08-2009, 10:29 AM   #17
DeathWalking
And it'll stay unique, because you lose massive amounts of static pressure when mounting a 120mm fan with gaps around it.
DeathWalking is offline   Reply With Quote
Old 12-08-2009, 10:40 AM   #18
WaterFlex
WaterFlex's Avatar
Big thanks for it! Very interesting
__________________
Intel E8400 500x9MHz@1,37V LinX 64bit mode stable
Asus Maximus II Formula 2302 Bios
OCZ OCZ2B1200LV4GK 4GB 1200MHz/5-5-5-15/PL8/1,8V
Seagate RAID0 2x Barracuda 7200.12 500Gb
XFX HD5870 1GB 1000/5000 MHz
LG W2486L + Iiyama ProLite E1902S
Thermaltake Xaser VI BWS
Seasonic M12-700 Watts
M-Audio Audiophile 192
Liquid Cooling System :
Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
EK Water Blocks EK-FC5870 Acetal+Nickel with EK-FC5850/5870 RAM Backplate
ThermoChill PA120.3, Laing 12V DDC-1Plus, XSPC Laing DDC Reservoir Top, Scythe Kaze Master Ace 5,25''
Arctic Cooling MX-3, 3x Scythe S-FLEX "F", 3x Scythe Gentle Typhoon "15", 2x 140mm Noiseblocker NB-BlackSilentPRO PK3
WaterFlex is offline   Reply With Quote
Old 12-08-2009, 11:10 AM   #19
Mech0z
Mech0z's Avatar
Send a message via MSN to Mech0z
Seems wierd there is such a big difference between flow on the MagiCool SLIM duel and triple this is not an error?
Nice test though!
__________________
i7 D0 3849A993 4606Mhz, 3 x 2GB G.Skill PI Black 877MHz 8-8-8-21, Asus Rampage II Gene, HD 5870
Highest PVantage clock:
I7: 4606 MHz HT:ON
HD5870: 1045 / 1342
Score: 23096
Cooling: EK Sumpreme LT, XSPC RX360, Swiftech 220, Laing DDC 18W. Cooled by 5 x GT15 1850RPM
Mech0z is online now   Reply With Quote
Old 12-08-2009, 11:52 AM   #20
Xandrus
huge?! it is just 7l/h!
Xandrus is offline   Reply With Quote
Old 12-08-2009, 12:04 PM   #21
Mech0z
Mech0z's Avatar
Well if you compare it to the other rads
The SR1 280 is 156, 420 is 154, 560 is 154
Magicool duel is 157 (Better than the SR1 duel) and the triple is 149 which is worse than the 560 SR1. Just seems strange abit strange to me.
__________________
I7: 4606 MHz HT:ON
HD5870: 1045 / 1342
Score: 23096
Old 12-08-2009, 01:46 PM   #22
bundymania
bundymania's Avatar
The NB´s are very quiet and the included accessories are great !
__________________
Old 12-08-2009, 01:51 PM   #23
JoeBar
Xtreme Guru
JoeBar's Avatar
Nice read. Thanks bundymania!
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.42GHz (21 X 210mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1683MHz (6-8-6-20-1N)
Asus 4870 X2 @ 850/950MHz WC'ed
150GB Western Digital Velociraptor | 2 x 320GB Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC-2 with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC-3.1 with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
JoeBar is offline   Reply With Quote
Old 12-08-2009, 11:26 PM   #24
mjtir
Many many thanks.
I was looking for that info a long time now.
mjtir is offline   Reply With Quote
Old 12-08-2009, 11:36 PM   #25
Fitseries3
Xtreme PITA to MM
Fitseries3's Avatar
Send a message via MSN to Fitseries3 Send a message via Yahoo to Fitseries3
im still using my 2 GTX560's i got a year ago
i love them
__________________
My Heatware
2x Xeon X5677 w/ EK Supreme LT Acetal
6x2gb Mushkin Redline Ascent DDR3
EVGA Classified SR-2
4x GTX480s
2x Enermax Revolution 1050watt
SST Ultradrive GX 64gb
MountainMods Ascension Crystal Ship CYO
2 HWlabs 560GTX's + HWlabs 280GTX + Iwaki rd30 + 10 Delta FFB1424SHG's
Fitseries3 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
