Results 1 to 16 of 16
Thread: "TONY-TRIM" - what say you?
    Xtreme Supporter
    Jan 2008
    USA
    As we all know there currently is no way to pass TRIM to a RAID array. I've tried to get some information about this out of Intel, Areca and Adaptec but each time I don't make it very far. While searching on the subject I came across the following:
    For those in raid, or those who just want a drive with consolidated free space and clean Nand...bring on TONY-TRIM
    I was wondering what the XS community though about "TONY-TRIM." Has anyone from XS used it? Thoughts?
    Worlds Fastest F5
    Aug 2006
    Room 101, Ministry of Truth
    Personally I am running my Raid 0 setup with SLC SSD's and "Garbage Collection" Firmware and I am so far very happy with the performance.
    I think that TRIM is 99% for MLC drives to combat their increased internal write latency when compared to SLC drives.
    Since I have not migrated to W7 yet not having TRIM is a non issue to me....
    Short Answer = no
    X5670 B1 @175x24=4.2GHz @1.24v LLC on
    Rampage III Extreme Bios 0003
    G.skill Eco @1600 (7-7-7-20 1T) @1.4v
    EVGA GTX 580 1.5GB
    Auzen X-FI Prelude
    Seasonic X-650 PSU
    Intel X25-E SLC RAID 0
    Samsung F3 1TB
    Corsair H70 with dual 1600 rpm fan
    Corsair 800D
    3008WFP A00
    Jul 2007
    ARIZONA
    It works
    [SIGPIC][/SIGPIC]
    PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
    FOXCONN MARS
    COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
    BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
    OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
    Quattro 1000W
    Radeon 2-4850's in crossfire
    OCZ Vertex SSD thanks Tony!
    ALL PIPED INTO HOUSE AIRCOND ;}
    *QUANTUM FORCE* saaya & sham rocks !
    *REAL TEMP*
    At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
    *MEMSET* Felix rocks !
    *SUPER TEC MAN* UncleJimbo rocks !
    OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
    Xtreme Mentor
    Feb 2009
    Tony actually describes it as manual garbage collection. Maybe Tony Manual Garbage Collection did not have the same ring to it.
    Jun 2006
    Interesting fact that writing FF (all ones instead of zeroes) is doing a block erase really. I wonder if that's NAND fact or just for OCZ SSDs?
    But really, consolidating free space and writing data? Nice way to shorten the life-time of SSDs (not lashing at Tony/OCZ this time, kudus for even coming up with this for us RAID folks - I am just not happy that at least Intel didn't put TRIM support in RAID drivers)
    P5E64_Evo/QX9650, 4x X25-E SSD - gimme speed..
    Quote Originally Posted by MR_SmartAss View Post
    Lately there has been a lot of BS(Dave_Graham where are you?)
    Xtreme Supporter
    Jan 2008
    USA
    When I finally get around to setting up my 2x80G G2 RAID 0 setup I plan to break the array, secure erase the drives, rebuild and restore an image when write performance goes down the toilet. Hopefully this won't be a monthly thing. But options are always nice to have.
    Xtreme Cruncher
    Nov 2002
    Belgium
    tony-trim is not a driver , but just a guide on how to setup perfectdisk 10 to clean up free space ? And perfectdisk 10 works with raid 0 . Is this correct ?
    So in fact it's not windows7 TRIM , but just a wipe of free space .
    Has anyone tried this with windows 7 , RAID 0 and intel drives ?
    Main rig 1: Corsair Carbide 400R 4x120mm Papst 4412GL - 1x120mm Noctua NF-12P -!- PC Power&Cooling Silencer MK III 750W Semi-Passive PSU -!- Gigabyte Z97X-UD5H -!- Intel i7 4790K -!- Swiftech H220 pull 2x Papst 4412 F/2GP -!- 4x4gb Crucial Ballistix Tactical 1866Mhz CAS9 1.5V (D9PFJ) -!- 1Tb Samsung 840 EVO SSD -!- AMD RX 480 to come -!- Windows 10 pro x64 -!- Samsung S27A850D 27" + Samsung 2443BW 24" -!- Sennheiser HD590 -!- Logitech G19 -!- Microsoft Sidewinder Mouse -!- Fragpedal -!- Eaton Ellipse MAX 1500 UPS .
    Xtreme Cruncher
    Nov 2002
    Belgium
    Update : i tried it , i don't get 95% of the speed back . but it's hard to compare since i did a firmware upgrade of both my drives and they have different write speeds now .
    I can tell you my read speeds are definately lower than 95% compared to my first benches . More like 88-90% .
    Feb 2006
    Potosi, Missouri
    The Trim part of the name is because of what AS-Clean is doing. Although the drive may have plenty of free space if it is in a used state an erase-before-write has to be performed to store data. Cleaning the free space using FFh sends the 2 byte value of 1111 1111. The cells that make up the free space are left at the bit value of "1". As this is also the value the cell represents when in an erased state a write can now be performed without the need for an erase. Combine this process with free space consolidation and it becomes very similar to what Trim is doing.
    May 2007
    This might work as they advertice on OCZ drives, but screwes up performance on Intel drives. Every cell is seen as written to after this, so stear clear of this one if you are on Intel Gen. 1 drives. Besides, HDDErase+True Image takes 1/4 of the time this one takes anyway...
    | Ci7 2600k@4.6ghz | Asus SaberTooth P67 | Sapphire HD7970 | Samsung B555 32" | Samsung 840 PRO 128gb + 2xIntel SSD 520 120GB Raid0 + 2xC300 64GB Raid0 | Corsair Vengeance 16GB DDR3-1600 8-8-8-24 | Vantage GPU=40250 |
    Feb 2006
    Potosi, Missouri
    Quote Originally Posted by Ourasi View Post
    Something else is going on. AS-Clean doesn't write anything to the drive. This is a free space equivalent of Secure Erase.
    May 2007
    Quote Originally Posted by Praz View Post
    AS-Clean might try to do the same as HDDErase secure erase, but it does not work, atleast not within the OS and on Intel Gen. 1 drives, without a valid purge of LBA, and we all know that purging LBA can not be done in OS without TRIM. The Intel Gen. 1 SSD sees every cell as used after AS-Clean, on all 3 of my Intel G1 SSD's, and the cause is probably that every "write" by AS-Clean get a page in the LBA, and as I said, clearing LBA will not happen unless you do a full HDDErase, or have TRIM.
    I knew even before I tried AS-Clean, that this would not work, but I had to be sure, so I wasted an hour or so to confirm this. I guarantie you this, this will happen on all Intel Gen. 1 drives, no matter how one theorize or speculate, every "write" by AS-Clean is seen as a write by the SSD, period..
    If the fact that some OCZ drives have a manual TRIM tool possebility, and a firmware that support this, "let" AS-Clean do this without touching LBA, I can only speculate, as I currently do not have a OCZ drive to test this on...
    The Fastest and easiest way to see the result of an AS-Clean on an Intel Gen. 1 drive, is to do a HDTune Pro 3.5+ Random Access before and after, beware that this might give you a bad evening
    All benches take an significant drop, including IOMeter Random Write, Random Read and Workstation. My adwise, stay away from this if the above conditions are in place..
    Aug 2009
    AS-Cleaner/FreeSpaceCleaner.exe absolutely DOES write to the SSD. (If you're not talking the same app I am, nevermind! )
    Jun 2006
    According to Tony writing FF byte (all 1s binary) it is the same as doing a block erase. Now whether that is true, and whether that is true for non-OCZ SSDs is the question.
    Aug 2009
    Quote Originally Posted by alfaunits View Post
    On my X25 gen 1's, I wrote zeros to one drive, and FF's to the other. The zeros benched faster. I then wrote zeros to the 'FF' drive, and it got slightly faster.
    Aug 2009
    Here's my last test results, using AS SSD bench. These are two Gen 1 80 MB X25's. The first 4 -gaps- in data lines indicate where I ran PD10 consolidate, and Ccleaner wipe free space. The last gap is where I ran ONLY AS-cleaner. On the C drive on right, I ran AS-cleaner first with FF's, then with zeros. The F drive was only zeros.
