Page 1 of 16 123411 ... LastLast
Results 1 to 25 of 388
Thread: HD 5XXX 1Ghz thread
    May 2009
    HD 5XXX 1Ghz thread
    lets see your 1ghz overclocks on core
    My Dirt2 bench 1440 X 900 all maxed 8xaa
    Phenon II x4 955 (3.7ghz)/athlon II x2 245 (3.7ghz), Mugen 2 , gigabyte 790xt ud4p, 5770 1000/1420 , 4GB ddr3
    http://superclock.mysmf.com 5770 1ghz bench
    evga failed
    Quote Originally Posted by Vit^pr0n View Post
    Can we just ban this guy? We don't need people coming in here claiming they know someone that's under NDA. Everything that comes out of this posters posts are nothing but delusions from a fanboy.
    Aug 2009
    Impressive temps with fan on auto???!!!
    CPU:: i7 2600K@5.0Ghz|MB:: Asus Maximus Extreme IV|VGA:: Asus 6970 |Case:: CM Haf 932|Ram:: 8GB G.SKill Ripjaws X@2133 |HDD::WD 1TB, Samsung F3 Spinpoint Raid0 & C300 128GB OS |CPU Fan Noctua NH D14|Audio::-AdamA3x - Sennheiser HD595 & Asus Xonar D1|Mouse: Logitech G5 & Logitech Wave Keyboard|Display::NEC2490-BK-SV|PSU::Cooler Master RP 1000W modular
    Jul 2008
    Germany, Stuttgart
    Is that a 5770?
    Jan 2004
    Sweden
    Heres my 5770 running 1060/1445. Max for the gpu but the memory was not maxed, the sliders was maxed though :P
    http://service.futuremark.com/compare?3dm06=12503209
    May 2009
    Quote Originally Posted by emertX View Post
    Is that a 5770?
    yes this is with a 5770.
    Quote Originally Posted by psyside View Post
    I am using custom fan profiles in after burner.
    Quote Originally Posted by Snowman89 View Post
    I cant get anything passes 1ghz on core
    evga failed
    May 2009
    here is a 1010mhz run not sure how stable it is though
    evga failed
    Jan 2004
    Sweden
    Quote Originally Posted by skugpezz View Post
    Try upping the fan to 100%
    Jun 2007
    EU, BUL
    1112/1285, only GPU under water
    |RIIIE||Xeon W3520#3845A935|EVGA GTX480||PC3 16000 Kingston HyperX 6GB||2x150GB WD VRaptor||WD6401AALS||HAF 932//CM 1250W||LenovoL220x||X-Fi Xtreme Music||Lycosa+Lachesis+Destructor+G27+P880|
    WC-Loop1: CPU |EK-Supreme HF|Magicool Xtreme III||MCP355||MCRES| Loop2: VGA/NB| EK-FC480 GTX-Acetal / MCW30|MCP655|MCR220QP|MCRES|
    May 2009
    Quote Originally Posted by nickless View Post
    Sweet man. do you have an nvidia card running physx?
    I will try that
    evga failed
    Dec 2007
    CR:IA
    Asus EAH5850
    does 1000c/1200m @ 1.315vcore via Afterburner. Memory will not do much over 1200 w/o an FPS loss.
    i'll grab a screen when i can.
    PC-A04 | Z68MA-ED55 | 2500k | 2200+ XPG | 7970 | 180g 520 | 2x1t Black | X3 1000w
    Jul 2007
    Not bad, actually i'm trying 1040 / 1350 ( core - memory ).
    May 2009
    IND
    I'm in
    May 2009
    My stalker run All Maxed
    evga failed
    May 2009
    My new clocks
    evga failed
    Feb 2005
    UK
    I've not tried for higher yet, seems totally stable at this speed/volts so will probably push the core further soon. I'm preparing some heatsinks for the RAM and VRMs and I'll wait until I stick them on before going over 5GHz on the memory.
    Running the fan set to "Smart cooling" default setting in Smartdoctor. If I set it to "auto" instead it runs about 10 degrees warmer and the fan stays totally silent (30-40% iirc).
    Jun 2005
    France
    sapphire V1 @1070/1350:
    Oct 2006
    new jersey
    waaaaa i cant play my 59 is slow only 970..... nice clocks for you guys thuo
    _________________
  18. #18
    May 2009
    Quote Originally Posted by cowie View Post
    lol come in here showing off. I am getting a 5850, then a 5950. Then we will see who is boss then
    evga failed
  19. #19
    Feb 2009
    UK
    My result after putting my trusty old HR-03 on it. I needed a little bump to get to 960, then had to use AMD gpu clock tool to go further. Doesn't like many more volts or MHz, but managed a run at 1010, but didn't save a screenie.
    Gigabyte EX58A-UD3R F6 : i7 920 D0 4.4GHz 1.4v : 4Gb G.Skill ECO 6-8-6-24 1.54v
    Apogee XT & MCW30 : XSPC Dual 750 w/DDC+18W : RX120 & RX240 : Tygon tubing : Corsair HX 850
    2x750Gb 7200.12 RAID0 : 2x500Gb 7200.12 RAID1 : Samsung DVD-RW : LG BD-R
    Antec P182 with 5 x Noctua NF-P12 & 1 x Akasa Apache
    M-Audio Delta 1010 (Rack) : Behringer Truth B2031A
    XFX 5770 + 8600GTS (physx) : 2x Samsung Syncmaster 710n
    Lappy: Asus C90s & E7500 @3.17GHz w/ 4Gb RAM & top scoring 8600m GT DDR2
  20. #20
    Xtreme 3D Team
    Mar 2007
    Rio de Janeiro, Brazil
    Im in.
    5850 stock cooled, ambient air.
    [SIGPIC][/SIGPIC]
  21. #21
    May 2009
    nice very nice man. when I had my 5850 I could only score 15k, I guess because of my cpu.
    evga failed
  22. #22
    May 2009
    IND
    max on air !!
    5870 @ 1025/1350
  23. #23
    May 2009
    wow is your 5870 stable?
    evga failed
  24. #24
    May 2009
    IND
    JUST FOR BENCH.......not 4 daily........
  25. #25
    Nov 2007
    Toronto, Canada
    GB 790XTA UD4
    GSkill Pi Black 2000 Cas9
    ASUS 4870
    Enermax Revolution 1050+
    http://www.heatware.com/eval.php?id=67661
