Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: Ati 5970 Water Chilling
    Oct 2009
    East Coast
    1st. I got to thank Jeremy At DangerDen !!
    Just got my New ATI 5970 Waterblock in from DangerDen. going to be putting this in my Dual Boreas Waterchilling Rig Tonight!
    Full Results tonight!
    Core I5 750 4Ghz
    4Gig Ram
    Koolance 360 CPU BLOCK
    Exos 2.5 1/2 Tubing
    EVGA GTX 480
    Danger Den GTX 480
    Oct 2009
    East Coast
    Reserved For Results
    Core I5 750 4Ghz
    4Gig Ram
    Exos 2.5 1/2 Tubing
    EVGA GTX 480
    Danger Den GTX 480
    Oct 2009
    East Coast
    HEre is some quick results.. Temps are very good.. Going to OVerclock it now!..
    Core I5 750 4Ghz
    4Gig Ram
    Exos 2.5 1/2 Tubing
    EVGA GTX 480
    Danger Den GTX 480
    Nov 2004
    Europe/Austria
    Looking forward to your results
    System #1:
    i7 975 for bench, W3540 @ 4,4 Ghz HT On, Asus P6X58 Premium, 3x2048 Corsair Dominator 2000CL7, Sapphire 5970 @ stock, Corsair HX1000, 1xOCZ Vertex2 120GB, 3x1TB WD Green
    Cooled by:
    Loop 1: Watercool HK rev 3.0, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
    Loop 2: EK 5970 Nickle, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
    Loop 3: EK Asus NB/SB, Mips Asus Mosfet 1 + 2, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.2 /w Phobya Fans @ 5V Pull
    4,6Ghz (21x220) 1,42Vcore with Single Stage (HT enabled)
    http://img402.imageshack.us/img402/1251/83962063.jpg
    AMD @ testing
    X4 955, Asus Crosshair III, same Rams as on Intel Setup, Sapphire 4870X2 @ Stock, PC Power&Cooling 910W
    Oct 2009
    East Coast
    Quick Update.. I Overclocked it to 850 Core / 1200 Ram.. Furmark 1hr. Temps 43c Core 1 Core 2 45c
    Core I5 750 4Ghz
    4Gig Ram
    Exos 2.5 1/2 Tubing
    EVGA GTX 480
    Danger Den GTX 480
    Nov 2007
    Varna, Bulgaria
    Quote Originally Posted by EvilClocker View Post
    Stock voltage or ...?
    Core i7 3930K|EK Supreme HF 2 x PA120.3 1x TFC Feser 240 DDC3.25 XSPC ResTop 3x SUNON Maglev 6xPanaflo FBA12G12H 2xSanAce 9G1212H1011 4xEK-FC R9-290X|RIVE|4XR9 290X|Corsair 4x2GB GTX2|Corsair AX1500i|WD1001FALS + SSDNOW V300|HP LP2475w|Luxeon 5.1WH|Logitech G500|Lian Li A70B
    Oct 2009
    East Coast
    The block I have is 1st rev.. The VRM are getting little Warm.. I have the final rev tuesday..
    to answer some question
    I put the voltage to 1.25 Vcore and it runs 1000mhz No issues.. GPu core where 45/ 49C running Furmark for 2hrs.
    The Card overclocks nicely but when you turn up the juice on Vcore the VRM Get HOT!!!! The Final REV of the block going to have cool water going over the VRM..
    Screen shots to follow.. sorry for delay been busy getting ready for holiday
    Core I5 750 4Ghz
    4Gig Ram
    Exos 2.5 1/2 Tubing
    EVGA GTX 480
    Danger Den GTX 480
    Mar 2005
    Slovenia - EU
    The VRM cannot get cooler with this block as the water is so far away from them... Think about it
    Quote Originally Posted by creidiki
    EKs are like waterblock pr0n
    Oct 2009
    East Coast
    ed,
    you are right.. DD is making a new Version this week. where the waters going to pass over the VRM
    Core I5 750 4Ghz
    4Gig Ram
    Exos 2.5 1/2 Tubing
    EVGA GTX 480
    Danger Den GTX 480
    Oct 2009
    The max stable overclock i've been able to get with the 5970 is 955 on the core, 5270 on the memory. I've only got an Air cooler at the moment though, expecting my waterblock any day now Impressive results there Evilclocker! Are you finding the limits or just playing it safe?
    Oct 2009
    Quote Originally Posted by Mr. Morello View Post
    I've noticed that most graphics card overclocking on ATI cards, people are more worried about VRM than cores temps..... LOL
    Its because manufacturers focus more on the core temps, as they are the most critical part of the card, so they (nearly) always have better cooling than the VRM's for the same water block. My temps sit under 50 at full load (same card and waterblock but a Koolance ERM K2U 5 loop watercooling setup)
    Sep 2009
    Santa Cruz, Ca
    I wish Danger Den would stop using the roughed up finish on their water blocks, I've got Tietons on my 280's and every place I've ever touched with my finger has left a permanent print, I can't find anything that will shine them up again. In hindsight, I wish I would have used rubber gloves to install them.
    Oct 2009
    East Coast
    What I have Found out is the VRM Get HOT Fast When you Overclock! My Card Runs 1000Mhz on the Core 1250 on The Ram.. but when you fireup Furmark.. The VRM Gets 85C Which is Way cooler then Aircooled.. DangerDen has a new Rev of the Block I will have next week to have water cooling the VRM Also.
    I found that 1.25 Vcore is need to get 1000mhz. Keep in mind I Running a Dual Boreas WaterChiller.. My Water Stays at 20C
    My Card Idles at 22C
    Core I5 750 4Ghz
    4Gig Ram
    Exos 2.5 1/2 Tubing
    EVGA GTX 480
    Danger Den GTX 480
    Jun 2009
    Australia
    What kind of rad/pump do you think would be best suited for this waterblock? I'm thinking about a XSPC RX120 http://www.pccasegear.com/UserFiles/xspcrx120_2.jpg radiator on a single loop dedicated just for the GPU. Something like the BFG did with the GTX295 H20C. What do you think?
    CPU i7 920 D0 @ 4.2GHz
    Motherboard ASUS R2G
    RAM Corsair XMS3 3x2GB CL7 1600MHz
    GPU ATI 4870x2
    Sound Card Auzentech Prelude 7.1
    PSU Corsair HX1000W
    Cooling Mega Shadow + Noctua NC-U6
    Case Antec P180 Mini Picture
    Xtreme Member JaD's Avatar
    Oct 2002
    Quote Originally Posted by Eddy_EK View Post
    Huge change of mind from the guy who used to screw aluminum plates on his blocks to cool VRMs
    Mar 2005
    Slovenia - EU
    Quote Originally Posted by JaD View Post
    You got me
    Oct 2009
    East Coast
    More results
    GPU staying at 40/40 I am running it at 5870 Speeds .. needs 1.2v on GPU .. VRM are not the bad either.. I have new Version of block 1st of next week
    Core I5 750 4Ghz
    4Gig Ram
    Exos 2.5 1/2 Tubing
    EVGA GTX 480
    Danger Den GTX 480
  18. #18
    Jun 2009
    Australia
    Any update on the new revision of the block which runs water over the VRMs?
    GPU ATI 4870x2
    PSU Corsair HX1000W
  19. #19
    Oct 2009
    East Coast
    Yep.. have it friday
    Core I5 750 4Ghz
    4Gig Ram
    Exos 2.5 1/2 Tubing
    EVGA GTX 480
    Danger Den GTX 480
  20. #20
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    Except then that was enough. Now with the 58/59 cards the VRMs are really a limiting factor. It wont be the gpu temp thats holding you back, its the VRMs
    So the one with the best VRM cooling will be the winner(unless the internals look like Bitspower FC blocks)
    Quote Originally Posted by iddqd View Post
    Not to be outdone by rival ATi, nVidia's going to offer its own drivers on EA Download Manager.
    X2 555 @ B55 @ 4050 1.4v, NB @ 2700 1.35v Fuzion V1
    Gigabyte 890gpa-ud3h v2.1
    HD6950 2GB swiftech MCW60 @ 1000mhz, 1.168v 1515mhz memory
    Corsair Vengeance 2x4GB 1866 cas 9 @ 1800 8.9.8.27.41 1T 110ns 1.605v
    C300 64GB, 2X Seagate barracuda green LP 2TB, Essence STX, Zalman ZM750-HP
    DDC 3.2/petras, PA120.3 ek-res400, Stackers STC-01,
    Dell U2412m, G110, G9x, Razer Scarab
  21. #21
    Apr 2005
    Regina, SK. Canada
    I'm running two MCW-60 with a pentium II heatsink that I took a hack saw to cooling my VRMs. They are definately the limiting factor. I have 950/1250 @ 1.225v (can maybe go lower) and my VRMs hit 90c in Unigine Heaven. I can't run Furmark for more than 20 seconds or they pass 110c. Don't know how high they will go because I'm not willing to test. Not sure I want to cough up the money for a full cover, but I need to do something better than this. The GPU cores don't hit 50c though.
  22. #22
    Apr 2005
    Regina, SK. Canada
    I'm thinking I may get some copper tubing and sand one side flat, and hook it up to my loop. Should at least be better than air. Any opinions? Suggestions?
  23. #23
    I am Xtreme
    Dec 2007
    Quote Originally Posted by Dude_Person View Post
    i was thinking a while back about using copper pipe to make a loop that goes over the RAM/VRMs. not sure how bad it would be to solder a copper pipe to copper heatsinks. give that the whole project could be done for under 20$ it wouldnt be a waste at all if you had to do it for each new gpu you buy.
    the only thing stopping me is that i have no idea how well the heat would transfer from the source to the sinks through the solder and into the copper pipe.
    but hey, if someone wasnt to do a cheap mod for their 700$ video card, i sure wont stop them.
    i also wonder if the UNISink that swifty makes will even work well enough for a 5970. i havnt paid too much attention, but im pretty sure they didnt release it yet, or if they even can.
  24. #24
    Jan 2008
    I like these two blocks the best (for vrm cooling)
    I think they just need to widen the block to the right a little more and stretch it out slightly past the VRMS on the right edge. That way they can get some water flowing directly over the top of them. As it stands right now, the flow is close, but not directly over the top. I still dont know how flush the contact is on the bottom, but I'm assuming it's the same on both of them.
    Bring... bring the amber lamps.
    [SIGPIC][/SIGPIC]
  25. #25
    Apr 2005
    Regina, SK. Canada
    Ya, the heat transfer is my main concern. I don't think solder should be an issue. AFAIK it transfers heat very well. What i'm not sure about is the heat transfer from the copper tube into the water. I'm also not sure how I'll do the three VRMs between the two cores. My mounting plates leave little space so I would have to have the flow perpendicular to the VRMs.
