Antec was nice enough to send me out a sample of their newest PSU that is built to take on the most power hungry setups available.
Here are some teaser pics for everybody
BIG Thanks to NickShih for Support
Time to open this bad boy up and see whats inside
Fan adjustment and well look at this.....adjustments for the 12v rail too.
24pin & dual 8in connectors
Also comes with two cables running directly from the PSU
3x Molex/3x Sata
4 PCI-E cables that come directly from the PSU with each cable having a 8 pin & 6 in connector on it....
and if that was not enough PCI-E cables for ya here are two more 6+2 pins in case you decide that the first four cables weren't enough.
Then a plentiful amount of molex/sata connectors X6 each if needed.
Thanks for looking![]()
