Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Reduce your 5770 temps by 5 deg idle, & 10 deg load with stock cooler
    Xtreme Mentor
    Feb 2008
    You will need:
    - A decent precision screwdriver
    - A reference ATI 5770
    - A *THIN* layer of good quality thermal paste (MX-3 would be best)
    - A pack of 8 VERY THIN low profile ramsinks, These Akasa ones will be the right size.
    - TIM cleaner
    I didnt take pictures of removing the cooler or applying the thermal paste, as this is easy to do.
    The first step is to remove the ATI 5770 stock cooler and clean off the excessively thick layer of stock thermal crap :p
    Secondly, you need to unscrew the GPU cooling block, and modify it with your 8 thin ramsinks exactly as shown in the pictures below (The ramsinks go on the top side furthest away from the fan):
    The first 6 ramsinks:
    And the last two fit on the outermost edge:
    The ramsinks need to go on like this as further towards the fan side of the GPU block, there is a ridge along the bottom of the block so they wont fit any further down.
    Finally, you need your good quality thermal paste like MX-3, and apply a very thin layer to the GPU and reapply the heatsink. I actually used leftover Asus thermal paste from my CPU cooler which I think looks like MX2, but MX3 will be a lot better.
    Results:
    Before the mod:
    And after:
    P.S. My idle / load temps were reduced by 4 / 9 degrees, but using MX-3 should get you better results.
    Oct 2009
    Sweet simple mod.
    I wonder if the thermal grease alone helped lower the temps as well. Looks like the ram sinks may imped air flow on that side of the stock heat sink fins.
    Mar 2009
    WOW MAN!!!Excellent work!!!Will try it in my card too!
    Can i add my cooling additions to this card too???I did some cooling with the stock cooler on too!!!
    It will make your work more complete!!SO???
    8400@4,5GHz 9*500@1,506volts
    DFi X48 T2RS
    BALLISTIX 6400@1200mhz 6-5-6-15@2,1volts
    XFIRED 4850s 1GB 820/1150
    Thermaltake 600rx (aging)
    Mar 2009
    Quote Originally Posted by SonDa5 View Post
    Sweet simple mod.
    Nah i dont think they will restrict airflow cos the air they use is almost useless cos it only cools the exterior of the out fin ALONE and then gets exhausted out of the card so this way it will be of some more use!!!
    DFi X48 T2RS
    Oct 2009
    Quote Originally Posted by Theorw View Post
    I hear ya. So by pinching the sides shut it is forcing all of the air to take the path right where most of the stock heat sink fins are located.
    Very nice. I wonder if the fan will make more noise?
    Xtreme Mentor
    Feb 2008
    There really isnt much space inside the shroud for anything else, unless you cut away the annoying plastic ridges inside it. The GPU block is also annoyingly small, they could have made it a little better.
    I had a nightmare trying to improve the cooling with these cards. First I thought I would use my previous thermaltake S orbs as they are compatible with the pin layout, and even ordered some VRM heatsinks, only to find out that the S orb was too wide to fit on this card and was obstructed by the IO panel.
    Next, I desperately ordered a pair of Arctic L2 Pros, then realised after they dispatched that they were too high to use in Crossfire mode
    So now I have two packs of VRM heatsinks, and two L2 pro coolers to return, and I just sat there fumbling around with the removed stock cooler, thinking what I could possibly do to reduce the temps ... So I stuck some ramsinks onto the GPU block
    The thermal paste will be doing most of the work here, but I have never seen temps reduced this much before from just a thermal past change, so the ram sinks seem to be helping. They are placed right below the top vent of the cards exhaust, so air is blowing through the fins on the ramsinks all the time, which may be improving their performance a little.
    Xtreme Mentor
    Feb 2007
    West hartford, CT
    what about cutting out the back I/O panel more?
    FX-8350(1249PGT) @ 4.7ghz 1.452v, Swiftech H220x
    Asus Crosshair Formula 5 Am3+ bios v1703
    G.skill Trident X (2x4gb) ~1200mhz @ 10-12-12-31-46-2T @ 1.66v
    MSI 7950 TwinFrozr *1100/1500* Cat.14.9
    OCZ ZX 850w psu
    Lian-Li Lancool K62
    Samsung 830 128g
    2 x 1TB Samsung SpinpointF3, 2T Samsung
    Win7 Home 64bit
    My Rig
    Xtreme Mentor
    Feb 2008
    A second run after my graphics cards had been left to heat up some more, 76 degrees this time:
    Basically, you can see that the GPU is running a lot cooler, and took a very long time to increase from 57 to 76 degrees, whereas before it went up from 50 to 81 degres in no time.
    Obviously this is because of the thermal paste change, gooooo Asus CPU paste
    Quote Originally Posted by tbone8ty View Post
    Its the top DVI connector that is the obstruction, I dont want to be cutting that out :p
    Mar 2009
    Well as i think of it,teh mreo i think that it is the paste that does most of the job and not the sinks...That because the are in contact only with ONE FIN and what amount of heat would a FIN ALONE transfer???So they wont be helpinh that much but the TIM did most of the job!
    U shoulda first put the sinks on and measure then put the TIM and compare
    DFi X48 T2RS
    Oct 2008
    Should of used tx-3. That stuff is amazing. I dropped my load temps by almost 10 degree's and idle is about a degree or 2.
    Intel I7 920 (4.2ghz)
    EVGA x58 Classified 760
    Asus 580 DC2
    Corsair Dominator GT 6gb
    256gb SSD
    Mar 2009
    I did this for the vrms.It wight add to the stability of the card @ load but no way to measure any temps...The sinks all fit under the stock cooler!!!
    DFi X48 T2RS
    Xtreme Mentor
    Feb 2008
    Yea, i'll try sinking up the VRMs like that.
    Correct about the ramsinks only connecting to one fin, I noticed that but thought it might do something. i'll try sinking everything up next time I have a tinker.
    Mar 2009
    Definitely sink up the MEM chips too!!!
    DFi X48 T2RS
    Jun 2005
    France
    i put some thermalright heatsinks (i had in stock) on the vrm & zalman heatsinks on the memory modules too...
    Xtreme Mentor
    Feb 2008
    I have 16 aluminium ramsinks and 20 copper ones, but need to give away two sets of 8 if my S orbs sell.
    I have lots of stuff to post, 2 4870s, the cooling RMAs, and the S orbs once I find a buyer.
    I just want to get these darn cards silent.
    I didnt bother with ramsinks on the rear chips because the memory overclocks fine, but I find it wierd how the front chips have such extravagant cooling when the back ones dont need it.
    Mar 2009
    Quote Originally Posted by bhavv View Post
    Of course they need cooling!Its just that ATI considers good airflow a standar nowdays so they didnt bother to cool those ram chips too cos theyd be cooled by the airflow.But in OC u MUST put a sink on them!!!
    DFi X48 T2RS
    Oct 2007
    Theorw,
    What brand are the tiny heatsinks you used for the VRMs? They look like ones I got with my old Accelero S1 & S2 but I don't have any spare right now
  18. #18
    Jan 2008
    i wonder how much of the temperature drop is from the added sinks and how much is from forcing more air through the fins of the main gpu sink (by blocking that space).
  19. #19
    Xtreme Mentor
    Feb 2008
    I wouldnt think it is tht much, but even if it only sheds 1 or 2 degrees, that is still something.
    With the Vapor X chamber, heat is equally distributed to all of the fins, so even sticking the heatsinks onto just one fin would allow it to draw out a little extra heat.
    I were going to mod my second one, but I've gone and misplaced my Akasa thermal tape so will wait untill I find it so I can sink up those VRM modules
    I need to buy more ramsinks too since I'm trying to sell a whole lot, so I'll wait untill my Sorbs sell then buy some fresh ransinks (Going to stick my copper sinks in with the Sorbs and keep the thinner aluminium ones).
    The only annoying thing with the stock cooler is how stupidly tiny that GPU block is. Seriously there was enough space for one at least 33% larger .
    My Arctic L2's arrived today, and I just held one over the cards to double check that it definately wont fit, then packed it back up and requested an RMA
    Also, the copper base of the GPU block is horribly unpolished and uneven, its the tackiest thing i've ever seen lol.
  20. #20
    Mar 2009
    Quote Originally Posted by b3ta View Post
    Theorw,
    They are from my MUSASHI!!!
    DFi X48 T2RS
  21. #21
    Mar 2009
    Does it really have VAPOR CHAMBER???
    I wondering about it too cos i thought of this too while i took it apart the other day!!!
    DFi X48 T2RS
  22. #22
    Xtreme Mentor
    Feb 2008
    Yup.
    The base of the 5770 reference cooler is a 'flattened heatsink' will cooling fluid inside to distribute the heat to all the fins. Otherwise it would be heating up like crazy lol.
    today during gaming, I noticed that the modified card in my first slot was only 2 or 3 degrees higher then the one in the second slot, usually it creeps up to around 10 degrees higher, so it is working good .
  23. #23
    Xtreme Mentor
    Feb 2008
    Ok, so this is the second card with just Asus thermal paste and no ramsinks on its second test after after already heating it up:
    On the first run from boot it went up to 74 degrees, the second test went up to 78, so the ramsinks are making a difference, but I removed them off the first card for now.
    On the second card I couldnt fit the GPU block back into the shroud with the heatsinks on exactly as I did them on the first, so I took them all off and will just leave them like this now.
    I just found myself a pairof Zerotherm GX820 Overclocker editions at £25 each, plus two packs of green Zerotherm heatsinks .
    Cost me quite a bit, but I can sell of all my copper ones that I currently have to get some of it back.
  24. #24
    Xtreme Mentor
    Feb 2008
    Bah! The zerotherms werent in stock and the order got auto cancelled.
    But I also found the Zalman VF950 that should fit .
  25. #25
    PI in the face
    Nov 2008
    cool what was ambient pre and post mod?
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
