Performance
. NVIDIA GTX 275+GTS 250
.633+738 MHz GPU
.240+128 Processing Cores
.400 MHz RAMDAC
Memory
. 1280 MB, 448+192 bit DDR3
. 2268+2200 MHz (effective)
. 127.0+52.8 GB/s Memory Bandwidth
Interface
.PCI-E 2.0 16x
.DVI-I, DVI-I
.SLI Capable
Resolution & Refresh
.240Hz Max Refresh Rate
.2048x1536 Max Analog
.2560x1600 Max Digital
Requirements
Minimum of a 680 power supply.
(Minimum recommended power supply with +12 Volt current rating of 46 Amps.)
An available 6-pin PCI-E power connector and an available 8 pin PCI-E power connector
MSRP: $349.99 USD
