XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 10-29-2009, 02:04 PM   #1
drfedja
drfedja's Avatar
Athlon II X4 620 unlocked & overclocked....
verification
and here is a CPU-z screenshot:
Thanks to AMD for supply that great CPU. L
P.S. This baby is aircooled....
__________________
"That which does not kill you only makes you stronger." ---Friedrich Nietzsche
PCAXE
drfedja is offline   Reply With Quote
Old 10-29-2009, 02:41 PM   #2
demonkevy666
demonkevy666's Avatar
Send a message via MSN to demonkevy666 Send a message via Yahoo to demonkevy666
that's just pure luck man a deneb die and it got 4.1ghz, sweet.
__________________
http://www.youtube.com/user/golem720.../0/GKiZtsEVb8I
^ EVIL BUNNY
HTPC coolermaster 690 sempron 140, Gigabyte UD3H, ddr3 1600mhz, 650 ps, 160gb hard drive currently running windows vista 64 bit (30 days)
AMD Green & black dragon GODZILLA get it it's now classic XD
foxconn destroyer revived Thermaltake Xaser IV case (bought)
285gtx 2gbs need to save cash now
demonkevy666 is offline   Reply With Quote
Old 10-29-2009, 03:06 PM   #3
drfedja
drfedja's Avatar
Here is some results...
Look at that 3D Mark score with stock aircooled 4850 @715/1150:
CPU score @3830 MHz:
__________________
PCAXE
Old 10-29-2009, 03:21 PM   #4
DedEmbryonicCe1
That sure is a nice spare Deneb. My 940 can't even open Notepad at 4.1GHz.
DedEmbryonicCe1 is offline   Reply With Quote
Old 10-29-2009, 03:52 PM   #5
Titan7171
sweet cpu.......but your benches clocks went lower as you continued. Is it capable of benching at 4ghz at all? did you try?? Im thinking of one of these for a second system. or just use this one and get myself the newer 965 c3.
__________________
Phenom 965 BE@4.2ghz
Enzotech sapphire/Mo-Ra extreme rad
Asus M3A79-T Deluxe
ht 2200mhz / nb 2800mhz
2x2gb Gskill ddr1066 5,5,5,15,24,2T
Sapphire 4850x2
Enermax Infinity 650 crossfire
case: XCLIO A380PLUS-BK
4.61ghz water
4.5ghz superpi 1M 15.585
http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
23,942 06 Phenom 965@ 4.5ghz Sapphire 4850X2@700/1150
13,954 Vantage, Phenom 940 4.1ghz Sapphire 4850X2@700/1180
If I dont get every single drop out of my cpu I feel like someone is stealing from me
Titan7171 is offline   Reply With Quote
Old 10-29-2009, 03:59 PM   #6
drfedja
drfedja's Avatar
It's particularly stable at 3.83 GHz, but @3.7 GHz it is LinX stable.
That sample can run few singlethraded benchmarks @4 GHz. Overclock stability is slightly lower than good Phenom II X4 sample, but
unlocked L3 cache is absolutely stable. With, or without L3 cache, that Phenom II err. Athlon II overclocks equally.
__________________
PCAXE
Old 10-29-2009, 04:04 PM   #7
Titan7171
I like it, $99 bucks at newegg. Are you sure you need that much voltage for 3.8ghz? Usually 1.47-1.5v is good for that speed.
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.61ghz water
Old 10-29-2009, 04:10 PM   #8
drfedja
drfedja's Avatar
Yeaah, I know that, but that baby is pretty power hungry..... With lower voltage it's unstable....
__________________
PCAXE
Old 10-29-2009, 04:21 PM   #9
Titan7171
Im curious? Did you try 3.8 ghz at 1.5v with NB and HT at stock? (around 2.2-2.4ghz)
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.61ghz water
Old 10-29-2009, 04:51 PM   #10
richierich
richierich's Avatar
Wow very nice!!!
__________________
Phenom II 550 unlocked 3.3GHz @ 1.26v / Scythe Mugen 2 + Gentle Typhoon Push Pull
Gigabyte MA790XT-UD4P / OCZ Gold PC3-8500 @ 1333MHz 6-6-6-17-11 1.75v
SuperTalent UltraDrive ME 64GB SSD / Seagate 1.5TB / 8800GT 512MB
Antec NeoPower HE 550w / Antec 300 / Win 7 HP 64-bit
richierich is offline   Reply With Quote
Old 10-29-2009, 05:10 PM   #11
drfedja
drfedja's Avatar
I will try tomorrow. You will see the difference between L3 on and L3 off, and also power dissipation and stability.
__________________
PCAXE
Old 10-29-2009, 05:52 PM   #12
Titan7171
cool, try it out, see what happens? Its just bothering me you need to use so much voltage Id like to see you hitting 4ghz-4.1ghz at those voltages.
Unless this is just the way it works with these cpu's they are just not as efficient as they could have been as Phenoms so they just used for lower speeds?
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.61ghz water
Old 10-29-2009, 07:26 PM   #13
Firewalker81
Can you give a guy a little advice as to make the 6mb usable. I turned on ACC and set HT to 1.6. The system will boot and show the 6mb L3 in the bios, but when it goes to the screen where it should load windows I get nothing. Raising CPU voltage does nothing. Any advice would be great.
__________________
Firewalker81 is offline   Reply With Quote
Old 10-30-2009, 12:44 AM   #14
Behemot
Behemot's Avatar
Try for example Hiren's boot CD and use some staility check tools, but I think the L3 is bad and for that reason it was disabled. Bad luck...
Behemot is offline   Reply With Quote
Old 10-30-2009, 03:43 AM   #15
drfedja
drfedja's Avatar
You may have luck to successifully unlock L3. But there is some tricks to make it usable. Raise voltage @ NB/L3, and lower the speed of NB/L3. Also try to manually set up ACC.
__________________
PCAXE
Old 10-30-2009, 06:16 AM   #16
drfedja
drfedja's Avatar
It is a low leakage CPU.... TDP @2.6 GHz with cool'n'quiet enabled - idle:
cool'n'quiet disabled:
max load is lower than claimed 95W:
with unlocked L3 it has slightly higher TDP
idle with cool'n'quiet disabled, and L3 unlocked:
load with L3 unlocked:
__________________
PCAXE
Old 10-30-2009, 06:28 AM   #17
drfedja
drfedja's Avatar
@3.6 GHz CPU power is little bit higher than 140W:
if only one thread is loaded CPU power isn't higher than 70W:
__________________
PCAXE
Old 10-30-2009, 08:00 AM   #18
Corsa
Corsa's Avatar
Great thread drfedja ...can u please give us ur system spec, cooler and such...thx
__________________
Asus A8N-E, x2 3800+ 2.7Ghz@1.488v, TT Big Typhoon lapped, Zalman NB-47J, XFX 9500gt, Corsair 2Gb, LiteOn DVD, SG 200Gb, WD 120Gb, Coolermaster Cavalier, Enermax 620w, Benq G2400WD, Logitech X-230, SRS™, XpSP3.
There is a cure.... it's called Prevention. .. And remember - the story being told is not always the one that best reflects reality….
Corsa is offline   Reply With Quote
Old 10-30-2009, 08:19 AM   #19
msgclb
msgclb's Avatar
From the CPU-Z Validation I see you're doing this with a Gigabyte GA-MA770T-UD3P and in a previous post you said it's on air.
What I'd like you to explain is how this is done or is there a howto somewhere. This is my first foray back into the AMD world. I've got an AMD Athlon II X4 630 Processor but not my motherboard. My current plan is to get a Gigabyte GA-MA790XT-UD4P. I didn't get my 630 in the hope of unlocking it so this would be an extra bonus if it happens.
__________________
| ASUS P6T Deluxe | Intel Core i7 965 3838A610 | Swiftech Apogee GTZ – Swiftech MCP655-B Pump – Thermochill P120.3 Radiator - XSPC Bay Reservoir |
| Corsair Dominator GT 6GB (3 x 2GB) DDR3 2000 | EVGA GTX 260 Core 216 | Corsair 850W PSU |
| Windows 7 64-bit |
msgclb is offline   Reply With Quote
Old 10-30-2009, 09:39 AM   #20
felix_w
felix_w's Avatar
What is the batch of this cpu?
felix_w is offline   Reply With Quote
Old 10-30-2009, 09:48 AM   #21
msgclb
msgclb's Avatar
I just came across this article...
Some Athlon II X4 are ''Deneb'' based, unlockable
and it refers to this article on how to unlock ...
AMD Phenom II X2 550 Black Edition unlocking & overclocking
I still need to put my system together so I haven't tried it yet.
And I'll second felix and ask can we tell if the cpu we have can be unlocked before trying to unlock it?
__________________
| Windows 7 64-bit |
Old 10-30-2009, 01:40 PM   #22
drfedja
drfedja's Avatar
PSU: OCZ 500W
Cooler Master Hyper 212 - push pull 12cm dual fan
RAM: GEiL Ultra DDR3 1600 2x1GB CL7
__________________
PCAXE
Old 10-30-2009, 03:33 PM   #23
Cele303
Cele303's Avatar
Send a message via MSN to Cele303 Send a message via Skype™ to Cele303
Nice 620 chip you got there drfedja , what is the batch if it's not a secret? It really outperforms Propus core without L3 cache, in overclocking and in clock per clock comparison
msgclb, unfortunately Deneb based Athlon X4 cpu's are very rare , better chance in finding 550 X2@X4 for the same money and they are BE with unlocked multiplier, but since you already bought 630, good luck with L3 unlocking
__________________
AMD Phenom II 965 C3 0933FPMW
Gigabyte 790FXT-UD5P
Corsair Dominator GT DDR3 2x2GB 1866 C7
XFX 5870 XXX
2X Seagate 1TB 7200.12
Corsair TX 850W
EK Supreme + Laing DDC 1T + EK X-TOP + Magicool Pro II + EK Multioption 250
Cele303 is offline   Reply With Quote
Old 10-30-2009, 06:16 PM   #24
drfedja
drfedja's Avatar
I can't tell you now about the batch, but this is the AACYC mask and it is 23 week 2009.
That sample is slightly better overclocker than standard cacheless Propus core.
It is LinX stable with VCORE @1.488V and NB Voltage @1.34V
Validation
__________________
PCAXE
Old 10-30-2009, 06:36 PM   #25
daellum67
I would think that these would overclock to higher clocks if you got the cacheless core: The deneb ones are out of a really low bin and the propus-cored examples are the highest bin for their die. The only way I can think that that wouldn't be true is if the propus dies are tuned slightly different than the denebs, which may or may not be true. The propus chips also generally tend to be later production batches and would benefit from 10 or so additional weeks of process tuning at AMD.
A deneb running at 3.6 would definately be faster than a propus at 3.7-3.8 though, so I doubt the propus chips could compete with the deneb ones, higher clocks and all.
daellum67 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
