10-24-2009, 09:12 AM
#1
Unlocked Asus 5770 bios for you
just downloaded it from my card last night. enjoy
__________________
Processor: AMD Athlon II X2 240 Regor 3.9GHz 2 x 1MB L2 Cache Socket AM3 65W Dual-Core Processor
Motherboard: GIGABYTE GA-MA790XT-UD4P AM3 DDR3 AMD 790X ATX AMD Motherboard
Cooling: Prolimatech Megahalem 5x120mm fans 2x Icages, 2x92 mm fans, 140mm PSU fan
Memory: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
Video Card: SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR5
Harddisk: Wester Digital Black Edition 32MB 7200 RPM 1TB SATA 3.0 ,CAVALIER SE 16MB 640GB SATA 3.0 DRIVE
CD/DVD Drive: 2 BLACK LG DVD BURNERS
CRT/LCD Model: BLACK LG FLATRON 23 INCH MONITOR 3000 TO 1 RATIO 1650X1080
Case: Thermaltake Armor Series VA8003BWS Black Full Tower Case solid side panel.
Sound Card: Gigabyte 7.1 onboard sound.
PSU: Thermaltake Xt 850 watt SLI 140mm silent fan
Software: Windows Vista Ultimate 64
10-24-2009, 01:58 PM
#2
How is it unlocked?
__________________
The man with the littel Barebone!
And proud Crew of!!!
Octeamdenmark.com
Shuttle SX38P2Pro Barebone E8600cpu and HD4870X2 gfx and 2gig Crusial Ballistix PC8500 Cl5 and 2x150gig Raptor in raid 0 and 1x750 gig seagate
Msi 790FX-GD70 Mobo Amd 955-965 PHII cpus and 2gig Crucial value PC10600@800mhz 7-5-5-15 1T
And 4x500GB Seagate 7200.12 in raid0
4xHD5770 in CFQ.
10-24-2009, 02:22 PM
#3
I'd like to know as well...
EDIT: Unless it has something like 3870's did.
__________________
For all of your Watercooling needs, head over to Petra's Tech Shop.
"Never skimp on the Power Supply" -Me ( HEAT)
Do your senses a favor, get the Klipsch ProMedia 2.1 sound system.
Build
E8400 @4.0(for now) | DFI LT X38-T2R | 4x1GB Ballistix PC8500 @Stock(for now) | HD3870 | PCP&C 610 | Creative X-Fi | NEC 1970GX LCD | Heavily modded Aspire X-Cruiser
Watercooling
MCP655 -> Swiftech MicroRes v1 -> Dtek FuZion v1 -> BIP 2X120 [suspended off case DIY] ->MCW-60 -> PA160 w/shroud [Inside of case  ] ->MCP655 Tygon 5/16, PT_Nuke + Pentosin, Yate Loon D12SM-12's for rad's.
10-24-2009, 02:59 PM
#4
Originally Posted by Riska
How is it unlocked?
Like most Asus cards it has higher core and memory clock limits, allowing you to overclock further.
__________________
EP45-UD3P f8
Q9650 (510x8.5=4335) Q845B522
Swiftech 355 w/ ek X-Top v2
XSPC RX360 w/ (3) Scythe Gentle Typhoon AP-15 (1850 RPM)
Heatkiller LT 3.0
Swiftech Micro res v2
Swiftech Radbox v2
Mips NB block
Bitspower compression fittings
PC P&C 750 silencer
(2) 2GB G.skill F2-9600CL5D-4GBPI
(3) Vertex 30GB RAID 0
(2) WD Black 1TB
10-24-2009, 05:22 PM
#5
U can just use the amd gpuclock tool it have unlimmited clocks
And i am waiting for the Msi unlocked bios it wil have something like 1800/2600mhz clocks limit in ccc
__________________
Octeamdenmark.com
4xHD5770 in CFQ.
10-25-2009, 03:24 PM
#6
Well with this bios my card does ddr5 5780 and well over 1000 core and the voltage and bios settings work for after burner. However if you want to wait that up to you. Basically this bios allow for software voltage control and clock speeds well in access of what you can reach stable on a 5770.
__________________
10-25-2009, 03:26 PM
#7
Indeed.
ik can run my 2 Asus HD5770 @ 1050/1200 @ 1.27v( if i bump the memory higher then i'am getting lower score's on benchmarks)
But i think cause its the referance design everbody can get the clocks en voltage control by using Afterburner 1.3
If not flash the Asus bios
10-25-2009, 03:32 PM
#8
Originally Posted by High.K
Indeed.
Nope you need a unlocked bios to use one tool, voltage you can control but unless you have this bios the clocks are locked on the core at 960 you can subvert that with amd gpu tool but it's a pain in the ass. Also the ram on your cards must be bad because these cards use better ram than the 5870/5850 and should go allot higher than 1200.
__________________
10-25-2009, 04:18 PM
#9
I can go to 1110/1475 on my master card at 1.35v with Afterburner and amdclocktool and my cards are saphire
__________________
Octeamdenmark.com
4xHD5770 in CFQ.
10-25-2009, 06:34 PM
#10
Thats great but I can do it without using two different tools, and it loads automatically. If you don't want the bios don't use it no one said you had to. However, someone else might want to. Also at 1.35v that not a stable clock with the stock cooler so you must be on water? The clocks I posted are occt stress test stable. At those clocks with the stock cooler your gpu will error out the azz at a heavy load.
__________________
10-26-2009, 02:06 AM
#11
I need a SURE answer.I am waiting my 5770 tomorrow morning and i am looking forward to flashing it with the asus bios posted above.So is it SURE i wont turn out with a dead card and having to force flash it with the original bios or using DOA RMA ??I mean it will be reference CONNECT3D card so it wont have any problems right?
__________________
8400@4,5GHz 9*500@1,506volts
DFi X48 T2RS
BALLISTIX 6400@1200mhz 6-5-6-15@2,1volts
XFIRED 4850s 1GB 820/1150
Thermaltake 600rx (aging  )
10-26-2009, 02:10 AM
#12
And another question!After having found the OC limits of my card,can i flash it with OCed clocks or is it not yet compatible with RBE???
__________________
DFi X48 T2RS
10-26-2009, 07:01 AM
#13
Well all the 5770 cards are reference and that bios is from my reference asus card so since your new card and mine would be physically identical there should be no problem.
On this I'm not sure but as of now I believe RBE is not compatible. Also there is no need to do anything with the clock speeds since afterburner will save and preload any over clocking clocks and voltage you use.
__________________
10-26-2009, 09:00 AM
#14
The 1.35v are with the stock cooler at 100% and vantage stable for many times occt is not at tool i use and with the asus bios i cant set the voltage with afterburner or smartdoctor on all 4 cards but i can do that with stock bios thats wy i am not using the asus bios.
__________________
Octeamdenmark.com
4xHD5770 in CFQ.
10-26-2009, 01:37 PM
#15
Somes screens of gpu temperature with this voltage & speeds would be interesting to see if it's on stock air cooling!
10-26-2009, 01:43 PM
#16
Thanks dude!
About my 2nd question i get that i ll be able to load the clocks each time i play a game but i think that having set the values to the bios would be the best way to go since u avoid any program bug or something...that might happen!
I hope RBE will support these soon!
When i get my card tomorrow i ll run some benches on stock cooler and then i put the musashi on and see what it can do!
__________________
DFi X48 T2RS
10-26-2009, 02:30 PM
#17
Vantage stable means zero. Thats not a accurate tool to test stability. Most of the time vantage stability doesn't translate at all to in game stability. Still nice benching clock.
__________________
10-26-2009, 03:03 PM
#18
I dont have a singel game in my house or on my pc i only use this pc for benching and the barebone for inet and news and pics will come later i am not at home right now
__________________
Octeamdenmark.com
4xHD5770 in CFQ.
10-26-2009, 04:26 PM
#19
So are 2 of these in Xfire going to beat a single HD5850? I'm talking about over clocked for both configurations of course.
10-26-2009, 06:53 PM
#20
Can I ask really what is the point of your posts. This thread is to allow people who want a unlocked 5770 bios the opportunity to download it . If you don't want the bios that fine but please stop with this debate it irrelevant to this topic. I was trying to be helpful and post a unlocked bios. What is your deal? Most people actually use their computer to play games with this card and would like to get the most out of their card and need this bios to help get them there. Bottom line if you don't want the bios don't use it. Take your debate to the 5xxx series card discussion thread where it belongs.  Here is the thread you want http://www.xtremesystems.org/forums/...d.php?t=233621. However, this is a unlocked bios thread , where you guessed it!!!!! you can download the one and only unlocked 5770 series bios. I realize Msi is going to be releasing one soon but until then that is what this thread is for.
__________________
10-28-2009, 04:46 AM
#21
Thanks. Just flashed mine and I now have 1200 Mhz as the upper GPU limit in CCC.
This method is better then using AMD GPU tool, as it doesnt deactivate powerplay when overclocking above the default CCC limit, and AMD GPU tool isnt even working yet on these cards either.
10-28-2009, 05:00 AM
#22
You need the newest version:
0.9.26.0
http://downloads.guru3d.com/AMD-GPU-...load-2383.html
THX for posting the Asus BIOS
10-28-2009, 05:09 AM
#23
Does atiflash 3,75 support flashing 5770?
__________________
DFi X48 T2RS
10-28-2009, 05:11 AM
#24
Whichever one I just used worked, dont know which version as I have a dedicated ATIflash USB stick that I just stuck in, copied the bios onto and flashed
I had to do each one seperately though, and am uninstalling / reinstalling the drivers now.
10-28-2009, 07:32 AM
#25
Cool thanks!I know it exist somewhere but can u point me in the article about creating a bootable USB STICK?
Thanks!
__________________
DFi X48 T2RS
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
