Results 1 to 11 of 11
Thread: Where do I add the washer to increase mounting pressure?
    May 2008
    Ontario, Canada
    I feel stupid but.. I've got my computer in parts and am trying to use Vapor's advice to get the Fusion v2 to get better mounting pressure...
    One suggestion is to add washers but.. where? Between backplate and mobo or between screw and block?
    Computer: i7 2600k @ 4.7Ghz | Asus P8P67 Evo | Corsair LP 16gb 1600CL9 | Silver Arrow | Essence STX | Crucial m4 128gb | Silverstone Raven 3|
    Video: 2x Sapphire 6950 Toxic 2gb @ 6970 Switch @ 880 / 1350 | Asus VG248QE |
    Audio: ODAC+O2 => JH|13 Pro | STX => ATH-AD700X / Audioengine A5
    Jul 2006
    Quote Originally Posted by Bojamijams View Post
    My guess is you would want it to be between the topplate and the head of the screw, touching one side of the spring. You want the distance where the spring is under compression to be shorter.
    Admin
    Feb 2005
    Ann Arbor, MI
    Two places will work:
    1) Above the spring, below the head of the thumbscrew.
    2) Below the spring, above the mounting plate.
    May 2008
    Ontario, Canada
    Thank you!
    May 2008
    Ontario, Canada
    Okay a followup
    How do I get a washer in there? I can't actually pull the screw out of the plate to add the washer in there
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    Okay a followup
    You need to pop the clip off that's holding in that's under the bracket.
    Circles SucQ!
    May 2008
    Ontario, Canada
    Any suggestions. I've tried but cannot and am afraid to break it
    Mar 2008
    Minnesota
    Needle nose pliers.
    Just close the pliers, stick it in the opening of the little clamp, and open the pliers
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
    I am Xtreme
    Jun 2007
    I prefer a screw driver.
    Bojam, this should ease your worries.
    http://www.youtube.com/watch?v=itv0-jIP20o
    Circles SucQ!
    May 2008
    Ontario, Canada
    Well I decided to try and do it and it was the screwdriver that did it. Otoh, compression fittings are a paint and all mi fingers are shredded.
    Feb 2008
    Bulgaria
    What size should be the washers? Is there any chance to bend the motherboard?
    ASUS P5E Deluxe X48 | C2Q Q9550@testing[Fuzion v2+MCR320+MCP655] | G.Skill 4x2GB F2-8800CL5D-4GBPQ@testing | Sapphire 4870X2@ testing | 150GB WD VelociRaptor + 2xWD6400AAKS | Chieftec CFT-850-14C | Iiyama E2403WS | Razer DeathAdder | CM CosmosS Black
