Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 114
Thread: AMD Phenom II X4 965 - Revision C2 vs C3 comparison
    Champion
    Jan 2007
    Hy guys,
    I just finished a head-to-head comparison of the new Deneb C3 revision against the old one (C2). I compared overall system power draw, max. CPu frequency, max. memory frequency, max. NB frequency and efficiency at a fixed frequency in SuperPI 8M.
    The new revision looks quite good: less power and more overclocking headroom .
    You can check it here (Romanian language | Google Translate may be necessary)
    best regards,
    matose
    Born to lose, live to win!
    Apr 2006
    City of Lights, The Netherlands
    What OS was used for the tests and overclocks? 32 or 64 bit?
    Pretty decent idle power draw I must say.
    "When in doubt, C-4!" -- Jamie Hyneman
    Silverstone TJ-09 Case | Seasonic X-750 PSU | Intel Core i5 750 CPU | ASUS P7P55D PRO Mobo | OCZ 4GB DDR3 RAM | ATI Radeon 5850 GPU | Intel X-25M 80GB SSD | WD 2TB HDD | Windows 7 x64 | NEC EA23WMi 23" Monitor |Auzentech X-Fi Forte Soundcard | Creative T3 2.1 Speakers | AudioTechnica AD900 Headphone |
    Champion
    Jan 2007
    Sorry but I forgot to say: Windows Vista Ultimate 32bit !
    Aug 2006
    Should test with 64 bit too :P that's what I'm interested in.
    phenom 2 940 stock
    gskill 4gb 1066 ddr2
    2 1.5Tb seagate hds in raid 0
    30gb ocz core series hd for os
    8800gts 640
    xigamatek 850w ps
    water cooling cpu: dtek fuzion 2, swiftech 320, 3 ultra kazes, d5 with detroit top
    custom acrylic case in progress :P
    Dec 2007
    Hungary (EU)
    Quote Originally Posted by matose View Post
    Hy guys,
    best regards,
    matose
    Thanks! Can you show a photo about the C3 CPU?
    Apr 2008
    Texas
    Were these tests done with C1E enabled? Also, can you confirm that the Northbridge now has multiple P-states and clocks down at idle too?
    Overall, C3 looks like a good chip. I may ditch this Phenom II 940 in a couple of months for one.
    Core i7 2600K@4.6Ghz| 16GB G.Skill@2133Mhz 9-11-10-28-38 1.65v| ASUS P8Z77-V PRO | Corsair 750i PSU | ASUS GTX 980 OC | Xonar DSX | Samsung 840 Pro 128GB |A bunch of HDDs and terabytes | Oculus Rift w/ touch | ASUS 24" 144Hz G-sync monitor
    Quote Originally Posted by phelan1777 View Post
    Hail fellow warrior albeit a surat Mercenary. I Hail to you from the Clans, Ghost Bear that is (Yes freebirth we still do and shall always view mercenaries with great disdain!) I have long been an honorable warrior of the mighty Warden Clan Ghost Bear the honorable Bekker surname. I salute your tenacity to show your freebirth sibkin their ignorance!
    Apr 2004
    Quote Originally Posted by jakefalcons View Post
    Agreed, that puts more strain on OCs.
    DFI LANParty DK 790FX-B
    Phenom II X4 955 BE (1003GPMW) @ 3.8GHz (19x200) w/1.36v
    -cooling: Scythe Mugen 2 + AC MX-2
    XFX ATI Radeon HD 5870 1024MB
    8GB PC2-6400 G.Skill @ 800MHz (1:2) 5-5-5-15 w/1.8v
    Seagate 1TB 7200.11 Barracuda
    Corsair HX620W
    Support PC gaming. Don't pirate games.
    Xtreme Guru
    Aug 2007
    How many processors were tested? Without a huge sample size, there is no way to know if "C3" indeed overclocks better or even has that much better power consumption. We all know that both of those factors can change from chip to chip even within the same revision. ESPECIALLY when the power consumption figure is well within the margin of error (2W).
    Xtreme Mentor
    May 2008
    cleveland ohio
    past 1800mhz memory that's great.
    HAVE NO FEAR!
    "AMD fallen angel"
    Quote Originally Posted by Gamekiller View Post
    You didn't get the memo? 1 hour 'Fugger time' is equal to 12 hours of regular time.
    Sep 2009
    Nice review! The C3's numbers look good.
    Jun 2009
    Estonia, Tallinn
    Very good!
    Banned
    May 2006
    Skopje, Macedonia
    Great! So we should wait for a PII X4 975. I just hope it will have a higher clocked NB/L3.
    Dec 2005
    Northern Virginia
    i'd like to see both chips overclocked at the same voltage. the C3 overclocked to 4.2 uses less power than C2 at 4...
    Computer:
    Case: Corsair 750D Airflow Edition
    Mobo: Gigabyte Aorus X570 Ultra
    RAM: Team TForce Xtreem ARGB 3600C14 2x16gb XMP
    CPU: AMD Ryzen 5900x
    Graphics: EVGA (rip) RTX 3080 FTW3
    PSU: Seasonic Focus GX 850w
    Cooling: Arctic Liquid Freezer II 360mm
    NVMe: SKHynix P41 Platinum, Samsung 980 Pro 2tb
    SSD: Micron 1100 2TB, Samsung 860 Evo 1tb
    HDD: WD SE 2TB, WD Black 1tb 3 platter with over 10 years of power-on time
    Banned
    May 2006
    Skopje, Macedonia
    If you red the article, it says MAX OC. With other words, the C3 will do 4.2 even with higher (reasonable) voltage. Maybe it's the ODMCS limitation or MB...
    Oct 2004
    Thank you for the comparison sir!
    It's good to see PHII continuing to improve, even if slowly.
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    whau, thanks, great OC with C3
    ROG Power PCs - Intel and AMD
    Champion
    Jan 2007
    Thx guys!
    The C3 doesn't scale beyond 1.55v, so I couldn't get higher with 1.575v or 1.6v.
    SKYMTL, the difference is 2W in IDLE... in LOAD is about 15W which is nice.
    Yes, I used C1E and Cool&Quiet activated and from what I saw the NB doesn't slow down.
    I will put pics with the CPU later today !
    Regards,
    matose
  18. #18
    Aug 2006
    thank you much
    phenom 2 940 stock
    8800gts 640
    xigamatek 850w ps
  19. #19
    Dec 2008
    Sweden, Linköping
    Quote Originally Posted by Mechromancer View Post
    Looking at hes graphs I'd say no, atleast not now. Idle should be much lower.
    I still believe that the NB has multiple P-States but I suppose that hes BIOS doesn't support such features yet?
    Nice preview, keep the results rolling!
    SweClockers.com
    CPU: Phenom II X4 955BE
    Clock: 4200MHz 1.4375v
    Memory: Dominator GT 2x2GB 1600MHz 6-6-6-20 1.65v
    Motherboard: ASUS Crosshair IV Formula
    GPU: HD 5770
  20. #20
    Champion
    Jan 2007
    Yes, you are maybe right but 2002 was the latest official ASUS BIOS. I don't care so much about IDLE power, overclocking is all that matters . Can't wait to put it under LN2....
  21. #21
    May 2008
    Czech republic
    Thx guys!
    Regards,
    matose
    can u test, please, stability with max AIR OC? I think, 1h prime or LinX at 14-16 000 with 15 rounds is OK.
    And Cinebench (4100 MHz+2800 at NB, it will cool)
  22. #22
    Jan 2006
    Stockholm, Sweden
    You may call it "exclusive" since there's an NDA on the C3 stepping 965's.
    I KNOW MASSMAN DISLIKES YOU.
    Quote Originally Posted by saaya
    yo yo... man, you gotta lose the beard... you look like a drunk :P
    Competition ranking: Better than the danes in everything I've ever entered.
  23. #23
    I am Xtreme
    Dec 2008
    France
    When are they going to be available? Q1 2010?
    Donate to XS forums
  24. #24
    Apr 2008
    Texas
    Quote Originally Posted by Smartidiot89 View Post
    I read about this over at AMDZone. You are right, the BIOSes do not yet support rev C3 power features! We'll see a lot less power usage when we get C3 capable BIOSes . Cheers!
  25. #25
    Champion
    Jan 2007
    Romania, lab501.ro
    Quote Originally Posted by Mean Machine View Post
    NDA? Is that the No Drugs Association?
    Weissbier - breakfast of champions
