Results 1 to 12 of 12
Thread: Vmod for NCP 5395 Graphics (Giga GTX 260 SOC - 55nm)
    Banned
    Dec 2005
    Everywhere
    Vmod for NCP 5395 Graphics (Giga GTX 260 SOC - 55nm) - UPDATED!
    Hi, maybe it is not so smart move now ... because "Beat Me If You Dare" competition. But i dont keep this mod only for myself and here is ... working Mod for Gigabyte GTX 260/275 Super Overclock Graphics ... maybe helps you..
    This mod is applicable on every GFX with ON Semiconductor regulator NCP 5395. First one is vGPU mod, with 470kOhm (or lesser, i had this one) trimmer soldered on pin 18 and ground. You can see it on pic 1. Next here is theoretical OCP mod, but i dont needed it for good results ...
    For example, 1,3V on GPU needs 8,5 kOhms on trimmer ...
    Gigabyte GeForce GTX 260 SOC version ...
    vGPU measuring point + ground (PCI connector from PSU)
    Easy to install ...
    Perfectly working ... tested
    ------------------------- This mod is for ***, look at new version ... fully working, without OCP/OVP trigger -------------------------------
    Pls exchange A (R1025) and B (R1022). A->B; B->A
    And you can use the adjustable resistance on C (C157). I tryed resistors from 100 Ohms - 470k Ohms, best results i have with 10 kOhms trimmer. Card works perfectly with 1,52V on GPU and was fully stable in 3DMark Vantage ... at 1098 MHz ... no OVP/OCP triggering ... tested on GTX 260 and GTX 275, working really great!
    I am Xtreme
    Jan 2005
    You do have OVP at 1.3V-ish, right?
    Where courage, motivation and ignorance meet, a persistent idiot awakens.
    Jan 2007
    Coeur d' Alene, Idaho, USA
    Massman, I am getting OVP @ 1.275V 900MHz Core....
    anyone seen a OVP mod for the Gigabyte SOC card?
    "If It Doesn't Overclock Its Broken"
    "NexGen Overclocking"
    "Overclocking, its a life style"
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Quote Originally Posted by V2-V3 View Post
    Card has OVP around .1v above VID voltage. OCP appears to trip around 1000/2000 Core/Shader regardless of voltage.
    k|ngp|n/Sham my brothers
    Aug 2002
    Athens---Hellas
    Some of them will shut down at 1.270V and some at 1.31V max...
    Also there is NO WAY to avoid this OVP due to the design of this chip....
    TIP: A way to avoid OVP on this VGA is ONLY if you play with it's VIDs...
    NO OTHER WAY....
    PLUS that afterwards you NEED to "seperate" the IMAX pin of the chip from the switching frequenccy pin of it because IF you JUST solder a trimmer to ground, when you trim it you may change the IMAX limit of it BUT you - at the SAME TIME - change the frequency of the switching power circuit...
    So you HAVE to seperate those two and have one trimmer for the swiching frequency and one trimmer for the IMAX......
    PLUS that you want another one for the VTT of the core....
    INTEL PWA FOR EVER
    Dr. Who my arss...
    One-Eyed Killing Machine
    Sep 2006
    Inside a pot
    Pure ownage
    El cheapo PWM controller had some hipro5 lovin'
    Coding 24/7... Limited forums/PMs time.
    -Justice isn't blind, Justice is ashamed.
    Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P. ), Juan J. Guerrero
    Banned
    Dec 2005
    Everywhere
    this card is totaly c*ap, on 1,28V GPU deeply under 1000 MHz, my old good 65nm GTX 260 does 1000+ at 1,2V , really great GAUNTLET GPUS ...
    i think last G200 in storage must be sold, here are ...
    Sep 2006
    Inside a pot
    This card is an absolute monster!
    We're benching Vantage at 1224MHz GPU!!!
    Nov 2006
    Poland / Rypin
    yo BenchZowner
    did ya guys use hipro's mods or those from OBR ?
    Schedule of Live Extreme Overclocking - info Thread
    Quote Originally Posted by K404 View Post
    "My Backup is bigger than Your Backup"
    Sep 2006
    Inside a pot
    I was just kidding about the clocks
    We have a GTX 260 Super Overclock card on the way.
    I'm gonna visit Crio tomorrow and LN2 it for the gigabyte contest.
    Depending on our time I'll either go via firmware modding or full hardware mod ( VID ) + PWM reinforcement + Vdroop mod
    Oct 2002
    London
    Could someone please post a picture of the whole PCB front side ?
    Banned
    Dec 2005
    Everywhere
    Next, more better voltmod ... updated first post
