Results 1 to 25 of 112
Thread: Project Raven ATCS 840
Threaded View
    Ω
    Jun 2009
    Brooklyn, NY
    Welcome to my Worklog
    Red denotes what I have purchased/ordered already.
    Anyway the build is comprised of the following:
    AMD Phenom II X4 965 Black Edition 3.4 GHz
    Asus Crosshair III AMD 790 FX Motherboard
    OCZ 8GB (4x2) AMD Black Edition DDR3-1600
    OCZ Memory Cooler
    Diamond Radeon 5870 Cypress XT 1GB
    Enermax Revolution 85+ 1050 Watt Power Supply
    (2) Seagate Barracuda 7200 RPM 1TB SATA
    Liteon DVD-RW SATA
    Coolermaster ATCS 840 Case
    Intel X-25M 80GB SSD
    Coolermaster V8 Cooler (Just in the meanwhile, until the watercooling starts!)
    Watercooling parts soon to be ordered:
    Alphacool NexXxus X2 Highflow Nickel Plated
    EK Crosshair III chipset full board block
    EK-FC Radeon 5870 reference block - Nickel Plated
    Swiftech MCR-220 QP radiator
    Swiftech MCR-320 QP radiator
    Swiftech MCP-655 pump 12 VDC
    Bitspower D5 MCP655 mod top
    Bitspower Water Tank Z-Multi 150
    Bitspower D5 / MCP655 Mod Kit - Black Sparkle
    (17) Bitspower Compression Fittings
    (10) Bitspower 45 Degree Angle Fitting
    (1) Bitspower Triple Rotary Angle Fitting
    (2) Bitspower Five Rotary Snake-style Fitting
    (3) Bitspower 90 Degree Adapter
    (3) Bitspower Male to Male Connector
    (1) Koolance Ball Valve
    (1) Dangerden Delren Fill Port
    (8) Enermax "Magma" -Twister Bearing SilentExtreme 120mm Fan
    (8) 120mm Black Metal Fan Guard
    15 feet Primochill Primoflex Pro LRT Black Tubing -1/2in. ID X 3/4in. OD
    Koolance TMS-200 and INS-FM17 Flow Meter
    Koolance Coolant Temperature Sensor Plug
    Black Sleeving Kit
    Koolance CPU-360
    EK Dual D5 Top
    Swiftech MCP-655 w/ Tach Sensor
    (2) Bitspower G 3/8 to G 1/4 adapter
    Bitspower G 1/4 male to male adapter
    PT Nuke
    10' Primoflex Pro LRT UV blue tubing
    I'll be swapping out my MCR-220 for my old Thermochill PA160! Going back to old school!
    This is gonna be a long LONG work log as I have to save up each week to order my watercooling parts since my poor dog has to have surgery.
    Last edited by ohms; 02-18-2010 at 10:22 PM. Reason: add to list hardware that needs to be purchased and project logo
    Ω Raven Build Blog
    "The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." - Thomas Jefferson
    " Inter Arma Enim Silent Leges" - In times of war, the law falls silent.
Tags for this Thread
