by team hong kong centralfield
AMD NEW 45nm Athlon x2 5000+ UNLOCK QUAD-CORE + L3
DDR2 only![]()
DDR2 only![]()
"F10 + A" all ammo?
Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
32 GB Patriot Viper Steel 3733 CL14 (1.51v)
RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
Tons of NVMe & SATA SSDs
LG 27GL850 + Asus MG279Q
Meshify C white
omg ! this cpu its only for china ? i don't hear of it release
http://www.newegg.com/Product/Produc...82E16819103716
should be this 45nm 5000x2...58usd
A gift from gad...........
un freekin believable....
might get some ddr2 just to give it a try
HTPC - Antec NSK2480 case
Asus M4A785TD-M-EVO, Win7-UEx64
Athlon2 X4 620 - AC Alpine 7
at 3.25GHz, 250*13, 1.4125v
2*2GB Crucial PC-10600 CL9-533-bios/667-actual
Samsung F3 103SJ 1-TB
LG-BD Combo, Zonet wireless, remote
Insane! $50 dollar Quad core with L3.
Particle's First Rule of Online Technical Discussion:
As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
Rule 1A:
Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
Rule 2:
When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
Rule 2A:
When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
Nice! I think I might get one and push it.
Does cpuz report it as a fx-5000 quad core?...lol
What motherboard are you using?
PII X6 1055T 14x272
Gigabyte 890GX
2x4 GB Gskill DDR3@4890
XFX 7870
Gigabyte GA-MA790GP-UD4H, it's on the ss
Everything is on the SS!
fake?
There's already a thread on it. The difference here is that he got a respectable 940 BE level overclock out of it.
Rule 1A:
Rule 2:
Rule 2A:
What ACC value are you guys using?
My Tforce 790GX A2+ wont boot with ACC set to auto
PII X6 1055T 14x272
Gigabyte 890GX
XFX 7870
Which BIOS settings do you use to beat 3.85GHz? O_o Any MoBo mods?
damn thats really cheap for a quad![]()
e8500 c0 - 4275MHz - 1,344 vCore
DFI UT P45-T2RS
4x1gb D9GMH
Ati HD4870
Modded HAF 932
Watercooled:
Heatkiller v3.0 cu - D-tek Fuzion GFX 2 - PA120.1 - PA120.2 - PA120.4
