Page 1 of 4 1234 LastLast
Results 1 to 25 of 91
Thread: AMD Scorpius desktop platfrom and 32 nm Zambezi in 2011
    Xtreme Legend
    Sep 2002
    Finland
    Hi,
    I got this interesting slide from AMD which shows their current roadmap for Desktop Platform 2009 - 2011.
    Next year AMD is planning to bring Leo-platform with 45 nm six-core Thuban CPU and RD890+SB850 chipset for enthusiasts and Dorado platform with Athlon II and RS880P+SB810 for mainstream.
    In 2011 AMD is planning to launch new Scorpius-platform with AM3r2 Socket and 32 nm Zambezi CPU with 4 and more cores. For mainstream users AMD is planning Lynx-platform with Llano APU (up to 4 cores + 1 GPU).
    Source: Finnish hardware site Muropaketti.com
    Favourite game: 3DMark
    Work: Muropaketti.com - Finnish hardware site
    Views and opinions about IT industry: Twitter: sampsa_kurri
    Xtreme Enthusiast TheBlueChanell's Avatar
    Dec 2006
    Interesting. So is the Scorpius platform going to be a Phenom 2 derivative or Bulldozer? It seems to fall into place between the two.
    Main: 900D - Prime 1000T - Asus Crosshair VI Extreme - R7 1700X @ 4.0ghz - RX Vega 64? - 32GB DDR4 3466 - 1TB 960 Pro -
    --- XSPC AX360 x3 - HK IV Pro - HK RX480 - HK 200 D5 - BP Compression ---
    HTPC: 250D - Prime 850T - Gigabyte G1 ITX - i7 6700K @ 4.5ghz - GTX 1080 Ti - 16GB 3200 - 1TB 960 Pro -
    --- ST30 x UT60 - Kyros HF - KryoGraphics 1080 - HK100 DDC - Monsoon Compression ---
    HV01: Define XL R2 - Prime 1200P - Asus Zenith Extreme - TR 1950X - RX580CF - 128GB DDR4 ECC - 512GB 960P - 4x 2TB RE
    HV02: Node 804 - Prime 850T - SuperMicro X1SSH - E3-1230 v6 - Vega FE - 64GB ECC - 512GB 960 Pro - 4x 6TB Gold -
    Apr 2007
    R900 before "Scorpius", it seems. Aren't these platforms defined quite early, like Q1? That would mean that R900 should be ready by then and would go on-par with the current "Q3/Q4" rumours. Other than that, Lynx seems somewhat strange. Up to 4 CPU cores and one GPU core, in same package? That would mean that GF would manufacture at least some of ATI parts, even if only for the CPU. Wasn't the first GPU to be embedded in a CPU to be from HD3k series?
    What exactly is the Llano APU? What's the purpose of APU?
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    Barcelona (city), Deneb (star), Thuban (star), Zambezi (city)...
    Uh-oh. Ominous.
    And I wonder if AM3 rev2 will be a PGA or LGA...
    And why they didn't go LGA with AM2.
    *shrug*
    But I hereby demand they go 192bit memory on Bulldozer - I want my 6 DIMM slots on desktop boards.
    Quote Originally Posted by Calmatory
    APU, as in "accelerated processing unit". GPU-on-CPU. Few Bulldozer cores with a low end GPU on-die.
    You were not supposed to see this.
    Apr 2008
    Zambezi=river actually
    Xtreme Guru
    Dec 2002
    spirit actually.. this spirit brings them water to grow crops and fish to eat..
    i guess amds waiting on a big harvest..
    Nov 2005
    Cape Town - South Africa
    Quote Originally Posted by AKM View Post
    Yup a river, but you also get the beer....that national beer of Zimbabwe.
    Apr 2007
    Quote Originally Posted by largon View Post
    Now that gets strange. How does the CPU utilize the APU? If there's a sequence of certain instructions, they are executed by APU, just like floating point operations are executed by FPU? If so, great. Now we just need compiler support.
    Xtreme Mentor
    Aug 2006
    HD0
    Quote Originally Posted by Calmatory View Post
    this will likely end up similarly to how x86 CPUs handled x87 co processors.
    Sep 2009
    Philippines
    I hope they keep the prices reasonable like they always do.
    Aug 2004
    Sweden
    The AM3r2 must be related to AM3, otherwise they'd get a different name. Should have been AM4 IMO, less confusion.
    Either way, it doesn't sound like Bulldozer to me. I thought it would need a completely new socket?
    Oct 2009
    Egypt
    Uh-oh. Ominous.
    actualy it is Agena not barcelona if you're talking about desktop , and it is also declared as Stars in earlier AMD slides
    on server side we got barcelona , shanghai, istanbul , etc ...
    Oct 2008
    The Curragh.
    Am3r2 is probably like AM2+.
    So hopefully it'll work in AM3 also.
    Jan 2007
    Oak Ridge, TN
    AM3r2 socket
    Quote Originally Posted by Mats View Post
    Someone over at AMDZone has speculated that it is AM3+, i.e. Zambezi would work in existing AM3 sockets and in AM3+ sockets, but there would be perhaps be a minor loss of performance in regular AM3. Regular AM3 processors would not work in AM3+, ie downward compatibility but not upward compatible. Of course Zambezi would not work in AM2+ either.
    The AM3 socket has 940 pins, but I think the AM3 cpus only use 939 pins. Maybe the extra pin is reserved for something. There are some really good threads on AMDZone about the technical justifications for and against this compatibility.
    ASUS M5A88-M
    FX-8320 cpu
    Thermalright XP-90 cooler
    12 GB 1333 MHz ECC RAM
    Antec Solo Case
    Dec 2008
    Sweden, Linköping
    AM2+ was also named AM2r2 internallt so my guess is that it's AM3.
    Zambezi will be based on the Bulldozer architecture, and most likely only support DDR3, so it will be socket compatible with AM3 and AM3+. Wonder when AMD will finally change socket?
    SweClockers.com
    CPU: Phenom II X4 955BE
    Clock: 4200MHz 1.4375v
    Memory: Dominator GT 2x2GB 1600MHz 6-6-6-20 1.65v
    Motherboard: ASUS Crosshair IV Formula
    GPU: HD 5770
    I am Xtreme
    Dec 2008
    France
    I personally like the easy upgrade path. Why change socket if it gives no benefit?
    Donate to XS forums
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    Eh, it's not any stranger than Intel Clarkdale, CPU with an integrated GPU.
    There's a also a city by that name.
    Quote Originally Posted by Abu Assar View Post
    Oh, completely forgot about that, you're right.
  18. #18
    Apr 2007
    Of course not, I am more interested in how exactly does the APU utilize the ISA. For example, does the OS see it as a GPU? Does it need drivers? Could it be possible to run GPU physics on it? GPGPU? What kind of API support?
  19. #19
    Nov 2008
    Sweden
    That is a very interesting question, imo.
    Main Rig: Phenom II X6 1055T 95W @3562 (285x12.5) MHz, Corsair XMS2 DDR2 (2x2GB), Gigabyte HD7970 OC (1000 MHz) 3GB, ASUS M3A78-EM,
    Corsair F60 60 GB SSD + various HDDs, Corsair HX650 (3.3V/20A, 5V/20A, 12V/54A), Antec P180 Mini
    Notebook: HP ProBook 6465b w/ A6-3410MX and 8GB DDR3 1600
  20. #20
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    That would certainly be my guess--that the APU will show up as a regular GPU to the system. Historically, as new technologies have been introduced to the PC platform, it very rarely took the form of an abrupt change if it was to be successful. Some things can't be done in that way but are major value adders, such as sound cards. Either you've got sound or you don't. Other technologies like 64-bit, SATA, and such are packed full of compatibility modes and such. Looking at that history, it won't surprise me if the APU shows up as a GPU and the term APU just becomes AMD marketingese for "GPU on CPU".
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
  21. #21
    Xtreme X.I.P.
    Nov 2002
    Shipai
    2011 and new socket and cgpu, if THIS isnt bulldozer then my guess is bulldozer is actually dead
    thuban is 6 cores, and they mention above 4cores for zambezi, so that sounds a lot like up to 8 cores to me...
    which is what bulldozer was supposed to be, native octa core...
    apu, you guys are reading too much into it i think...
    i highly doubt that itll be integrated into the cpu silicon, and even if thats the case, itll be, guess what, a gpu and itll be recongized as such... this is the same intel is doing with 1156 igp, the same thing...
    the sad thing is... bulldozer 8 cores were supposed to be out... earlier this year...
    and now something that looks like a bulldozer/shanghai crossing is scheduled for 2011... so looking at amds cpu track record itll arrive in 2012+
    and until then its going to be the same architecture... from now until at least 2011... so 2-3 years without anything new? ouch :S
  22. #22
    Xtreme Cruncher
    Jun 2006
    Basically ,on desktop we will have:
    2010-QC Athlon IIs for mainstream(renamed Phenom IIs?) and a new desktop hex core high end 45nm MPU based on Lisbon design(modified Istanbul),presumably at higher clocks/lower TDP
    2011-a mix of new design on the high end (Zambezi-Bulldozer for desktop in AM3+ socket,backward compatible) and a 10h design(Shanghai QC) done @ 32nm and integrated along side the new GPU part on the same die. The last part about Llano being a 10h derivative done @ 32nm was already confirmed by design team member at AMD @ work blog,so it's official. This practically means AMD will not risk to introduce the BD design first on the brand new node,but instead they will "practice" the node on the Shanghai shrink and then move on the brand new design.
  23. #23
    Xtreme X.I.P.
    Nov 2002
    Shipai
    so this is still not bulldozer?
    then bulldozer IS dead... what a shame... if theyd at least have something else to refresh the platforms, but they dont...
    so they will continue to just stuff more cores down our throats until 32nm, where they will finally introduce a new architecture?
    or at least thats what they plan NOW... not really exciting is it? :/
    and having igp on the cpu package... i still dont get it, they could have done that years ago...
    as soon as they introduced the athlon 64 and hyper transport to the desktop, it was possible to move the igp chipset onto the cpu or do a cpu/cpu mcm...
    they sat on their hands for 8 years now... intel had to do both first for them to really work on this seriously...
  24. #24
    Xtreme Cruncher
    Jun 2006
    Zambezi IS bulldozer,and it was always scheduled for 2011,keep up Saaya .
  25. #25
    Apr 2008
    Texas
    FYI folks, AM2+ was once codenamed AM2r2. AM3r2 will likely be known as AM3+. We'll probably see a little backwards compatibility.
    Core i7 2600K@4.6Ghz| 16GB G.Skill@2133Mhz 9-11-10-28-38 1.65v| ASUS P8Z77-V PRO | Corsair 750i PSU | ASUS GTX 980 OC | Xonar DSX | Samsung 840 Pro 128GB |A bunch of HDDs and terabytes | Oculus Rift w/ touch | ASUS 24" 144Hz G-sync monitor
    Quote Originally Posted by phelan1777 View Post
    Hail fellow warrior albeit a surat Mercenary. I Hail to you from the Clans, Ghost Bear that is (Yes freebirth we still do and shall always view mercenaries with great disdain!) I have long been an honorable warrior of the mighty Warden Clan Ghost Bear the honorable Bekker surname. I salute your tenacity to show your freebirth sibkin their ignorance!
