Results 1 to 7 of 7
Thread: ASUS Crosshair III Formula
    Nov 2005
    Mansfield TX
    Asus sent over their Crosshair III Formula & OC Station for some overclocking loving. After my intial testing I felt I didn't have the proper graphics hardware to show capability of this very solid board. With the release of AMD's HD5000 line I quickly purchased two Sapphire 5870's so I may complete the task.
    Here's a look of the rich features of this board as copied from Asus website:
    CPU Features
    Phenom™ II/Athlon™ II/ Sempron™ 100 Series Processors (AM3 CPU)
    This motherboard supports AMD® Socket AM3 multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel DDR3 1333 memory support and accelerates data transfer rate up to 5200MT/s via HyperTransport™ 3.0 based system bus. This motherboard also supports AMD® CPUs in the new 45nm manufacturing process.
    Chipset Features
    AMD 790FX Chipset
    AMD 790FX Chipset is designed to support up to 5200MT/s HyperTransport™ 3.0 (HT 3.0) interface speed and quad PCI Express™ 2.0 x16 graphics. It is optimized with AMD latest AM3 and multi-core CPUs to provide excellent system performance and overclocking capabilities.
    Memory Feature
    Native DDR3 1600(O.C.) Support
    This motherboard supports native DDR3 1600(O.C.) that provides faster data transfer rate and more bandwith to increase memory computing efficiency, enhancing system performance in 3D graphics and other memory demanding applications. * DDR3 1600(O.C.) is supported by AM3 CPUs only. Refer to www.asus.com for the supported CPU models.
    Graphics Feature
    PCIe 2.0 support
    This motherboard supports the latest PCIe 2.0 devices for double speed and bandwidth which enhances system performance.
    ATI CrossFireX™ Technology
    ATI’s CrossFireX™ boosts image quality along with rendering speed, eliminating the need to scale down screen resolution to get high quality images. CrossFireX™ allows higher anti-aliasing, anisotropic filtering, shading, and texture settings. Adjust your display configurations, experiment with the advanced 3D settings, and check the effects with a real-time 3D-rendered previews within ATI Catalyst™ Control Center.
    ROG Exclusive Features
    MemOK!
    Any memory is A-OK!
    Memory compatibility is among the top concerns when it comes to computer upgrades. Worry no more, MemOK! is the fastest memory booting solution today. This remarkable memory rescue tool requires nothing but a push of a button to patch memory issues and get your system up and running in no time. The technology is able to determine failsafe settings that can dramatically improve system booting success.
    Pin Fin Thermal Module
    Profession grade OC instantly
    Compare with traditional stacked-fin heatpipe solution, the new generation pin-fin thermal design result in better thermal performance, which enlarges the “heat-exchange” surface area surface and breaks the "Boundary-layer" phenomenon for effective airflow. The Pin-Fin Thermal Module is the most efficient thermal system there is on the motherboard.
    External LCD Poster
    Debug and read system problems with an new external look!
    The new LCD Poster now posts critical POST information in an ever friendly and flexible external display. When system malfunction occurs, the LCD Poster automatically detects device failure and translates the errors on the LCD during POST.
    Voltiminder LED
    Friendly reminder on the intentional madness
    In the pursuit of extreme performance, overvoltage adjustment is critical but risky. Acting as the "red zone" of a tachometer, the Voltiminder LED displays the voltage status for CPU, NB, SB, and Memory in a intuitive color-coded fashion. The voltiminder LED allows quick voltage monitoring for overclockers.
    Loadline Calibration
    Optimal power boost for extreme CPU overclocking!
    Maintaining ample voltage support for the CPU is critical during overclocking. The Loadline Calibration ensures stable and optimal CPU voltage under heavy loading. It helps overclockers enjoy the motherboard´s ultimate OC capabilities and benchmark scores.
    ASUS Q-Connector
    Make connections quick and accurate
    The Q-Connector allows you to connect or disconnect chassis front panel cables in one easy step with one complete module. This unique adapter eliminates the trouble of plugging in one cable at a time, making connection quick and accurate.
    CPU Level Up
    A Simple click for instant upgrade
    Ever wish that you could have a more expansive CPU? Upgrade your CPU at no additional cost with ROG´s CPU Level Up! Simply pick the processor you wanted to OC to, and the motherboard will do the rest!
    See the new CPU speed and enjoy that performance instantly. Overclocking is never as easy as this.
    iROG
    Intelligent multiple control at hand
    The iROG is a special IC which enables several ROG highlitghted functions that gives users full disposal of the motherboard at any stage! This design allows advanced user control and management to be processed purely at a hardware level. iROG greatly increases fun during overclocking for PC enthusiasts and it offers system maintainence and management with more control and efficiency.
    Extreme Tweaker
    One stop performance tuning shop
    Extreme Tweakers is the one stop shop to fine-tune your system to optimal performance. No matter if you´re looking for frequency adjustment, over-voltage options, or memory timing settings, they´re all here!
    COP EX
    Maximum OC with confidence with burn proof protection to chipsets and CPU!
    The COP EX allows overclockers to increase chipset voltages without the worries of overheating. It can also be used to monitor and save an overheating CPU. The COP EX allows more freedom and less constraint for maximum performance achievement.
    Onboard Switch
    No more shorting pins or moving jumpers
    With an easy press during overclock, this exclusive onboard switch allows gamer to effortlessly fine-tune the performance without having to short the pins or moving jumpers!
    Sound with Clarity
    SupremeFX X-Fi
    Listen with Absolute HD
    Play in extreme fidelity !
    SupremeFX X-Fi delivers an excellent high definition audio experience to the gamers of ROG. The SupremeFX X-Fi features unique audio innovations for gamers to spot enemes in 3D environment during game play. SupremeFX X-Fi also provides gamers a special tool to emphasize human voices in games to help make dialogues clearer and more audible.
    Noise Filter
    Eliminate background noise while recording
    This feature detects repetitive and stationary noises like computer fans, air conditioners, and other background noises then eliminates it in the incoming audio stream while recording.
    Rich Software Bundled
    Kaspersky® Anti-Virus
    The best protection from viruses and spyware
    Kaspersky® Anti-Virus Personal offers premium antivirus protection for individual users and home offices. It is based on advanced antivirus technologies. The product incorporates the Kaspersky® Anti-Virus engine, which is renowned for malicious program detection rates that are among the industry´s highest.
    Futuremark® 3DMark®06 (Advanced Edition)
    The Gamers´ Benchmark
    3DMark is the most popular and authoritative 3D benchmark application used by professionals around the world. The 3DMark06 is the latest version in the popular 3DMark series, including advanced SM2.0 and HDR/SM3.0 Shader graphics tests and now including single, multiple core and multiple processor CPU tests as part of the 3DMark score! The accurate performance and image quality diagnostic tool, designed for DirectX®9.0c, provides you with all the information you need to make all other competitors look bad.
    Other features
    Q- Shield
    Easy and Comfortable Installations
    The specially designed ASUS Q-Shield does without the usual "fingers" - making it convenient and easy to install. With better electric conductivity, it ideally protects your motherboard against static electricity and shields it against Electronic Magnetic Interference (EMI).
    C.P.R.(CPU Parameter Recall)
    When the system hangs due to overclocking failure, there is no need to open the case to clear CMOS data. Just simply restart the system, the BIOS would show the previous setting and then users can amend the CPU setting again.
    MyLogo3
    Personalize your system with customizable boot logo
    The ASUS MyLogo 3 is the new feature present in the motherboard that allows you to personalize and add style to your system with customizable and animated boot logos.
    SATA on the Go
    The motherboard supports the next-generation hard drives based on the Serial ATA (SATA) 3Gb/s storage specification, delivering enhanced scalability and doubling the bus bandwidth for high-speed data retrieval and saves. The external SATA port located at the back I/O provides smart setup and hot-plug functions. Easily backup photos, videos and other entertainment contents on external devices.
    O.C. Profile
    Conveniently store or load multiple BIOS settings
    Freely share and distribute favorite overclocking settings
    The motherboard features the ASUS O.C. Profile that allows users to conveniently store or load multiple BIOS settings. The BIOS settings can be stored in the CMOS or a separate file, giving users freedom to share and distribute their favorite overclocking settings.
    EZ-Flash 2
    Simply update BIOS from a USB flash disk before entering the OS
    EZ Flash 2 is a user-friendly BIOS update utility. Simply launch this tool and update BIOS from a USB flash disk before entering the OS. You can update your BIOS only in a few clicks without preparing an additional floppy diskette or using an OS-based flash utility.
    Stack Cool 2
    Effective and zero-noise heat dissipation
    Stack Cool 2 is a fan-less and zero-noise cooling solution offered exclusively by ASUS. It effectively transfers heat generated by the critical components to the other side of the specially designed PCB (printed circuit board) for effective heat dissipation.
    IEEE 1394a interface
    IEEE 1394a interface provides high speed digital interface for audio/video appliances such as digital television, digital video camcorders, storage peripherals & other PC portable devices.
    Quite the long list of features I'd say. Surpisingly I use everyone of them in some form or fashion. I even tried the virus protection for a day or two. No on to some pictures and benchmark reults.
    Test Setup
    AMD Phenom II X4 965 Black Edition w/TRUE 120
    Asus Crosshair III Formula
    2 X Sapphire 5870's CF @ Stock
    2GB Kit Corsair DDR3 1800 @ DDR3-1600 7-7-7-20 1T
    Microcool Banchetto 101
    Corsair 850HX 850W PSU
    Asus OC Station
    All overclocking was done using the OC Station panel which actually was more reliable than AMD Overdrive once things got extreme.
    Pic of Air Test Bed
    Air Results
    Everest Stock
    Max stable OC Default volts was 3.8GHz on air so this was used for benchmarks.
    Max Prime stable overclock was 3.9GHz 1.45v
    Mounted The Dragon F1 and Tried some LN2 Action
    I spent too much time trying to find Max 3DMark Stable cpu clock and well things got a little cold and wet with this already humid rainy day.
    The system is now crashing as soon as vantage loads so I'm gonna let things dry out overnight and then complete the extreme benchmarks.
    In conclusion Asus has a real winner here. The board is very solid overclocks smoothly especially under extreme cold. It does not exhibit any of the clock generator cold bug behavior the ASUS M4A79T Deluxe suffers from. This will be the AMD board of choice once 5870X2's are released. The OC Station is a nice add on. It even acts as a fan controller capable of controlling 4 fans. For an extreme overclocker it's a very useful tool as it allows overclock on the fly while benching.
    here's a shot of what I'm also working on Asus is keeping me busy and I love it
    Praetor
    » Intel i7 2600K 3103B306 » Asus Maximus IV Extreme-Z » Asus GTX 470's TRi-SLI » Corsair Dominator GT CMT4GX3M2A2000C8 » Corsair Force F180 SSD » Corsair AX1200 PSU » Corsair 800D
    » Cooling : Swiftec Apogee XT » Swiftec MCP350-DDC1 w/XSPC Dual DDC Bay Reservoir » Swiftech MCR320-QP w/Scythe SlipStreams 110CFM
    The Yamato
    » Intel i7 920 3849B028 or i7 980X » Asus Rampage III Extreme Black Edition » Asus HD6970's QuadFireX or Asus GTX 570's 4way SLI » 6GB Corsair Dominator GT TR3X6G1866C7GTF » Corsair Force F180 SSD » Corsair AX1200 PSU » Microcool Banchetto 101
    » Cooling : Dragon F1 Extreme Edition(LN2) » Custom SS by RunMc »
    Nov 2005
    Mansfield TX
    ***Reserved for more extreme overclocking tests and results***
    Praetor
    The Yamato
    I am Xtreme
    Sep 2006
    Would love to know the max bus speed you can push, we tried the MSI GD70 yesterday and had some weird issue at 370Mhz. CPU was 100% stable during benching at 368-369Mhz, yet 370 was almost instant freeze. I think I'm pretty board limited there...
    Jun 2004
    USA, Vermont
    What bios where u on? and also why 11-11-11 timings on vantage?
    http://smbach.com/mad.gif
    Opty 175 Rig
    Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
    AM3 Rig
    Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
    DFI NF4 BIOS Guide
    Dec 2007
    Thailand
    Great
    • i7 920 D0
    • Gigabyte X58A-UD3R
    • Corsair Dominator 12GB
    • MSI GTX 660 Ti Power Edition OC 2GB
    • OCZ Vertex 4 128GB
    • WD1002FAEX 1TB
    • Corsair HX850W
    • CaseLabs Magnum TH10
    • Dell UltraSharp U2410
    • Logitech G500
    • SteelSeries QcK Mass
    • Klipsch ProMedia 2.1 THX
    Dec 2009
    Yes looks cool to me keep up the Great work.
    I am Xtreme
    Feb 2003
    Netherlands
    Any particular reason to keep the CPU-NB at stock?
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
