Results 1 to 25 of 138
Thread: Hack gets PhysX and Radeon working again
Threaded View
    Jun 2007
    above USA...below USSR
    With the latest Nvidia drivers, users with both ATI (primary) and Nvidia graphic cards were unable to turn on PhysX. But as the author of this mod said: "You cant stop the community, Nvidia." With this mod/patch, you will be able to turn on PhysX again. And yes, installation is just about three steps!
    source;http://vr-zone.com/forums/491380/tur...ds--again.html
    source of patch;http://translate.google.com/translat...istory_state0=
    EDIT: here's the patch for 64bit win 7/vista wouldn't get the 32bit http://rapidshare.com/files/28877554...-1.01.rar.html
    from the read me
    NVIDIA GeForce driver 19x.xx PhysX mod [x86/x64] v1.01
    by Liandri / THETA
    * DESCRIPTION:
    This mod will enable hardware PhysX support for NVIDIA GPU, when non-NVIDIA GPU
    is used as a primary display device.
    - intended only for WDDM 1.1 OS (Windows 7).
    - only for multi-vendor multi-GPU configurations.
    * INSTALLATION:
    1. Install the needed GeForce driver package. Do not reboot when asked.
    2. Use the mod (x86/x64) to patch all needed driver files.
    3. Reboot.
    * NOTES:
    1. If you are unable to patch the files due to "file in use" error, you may try one of the following solutions:
    - Terminate all NVIDIA runtimes (nv***.exe) and Windows Explorer shell (explorer.exe) manually before patching.
    - Try using the mod under Safe Mode.
    2. It is safe to apply the patch several times - the needed files will be patched only once.
    3. After reboot you may find "*.tmp" files in system directories left after patching. You can safely delete or leave them.
    * Thanks to beta testers:
    ghost_zero5, Pat, Skyfallkavu, Decebal, darthcyclonis, Kinnyo
    * Do not let proprietary closed standards choose a hardware for you! When they die, the hardware will be useless.
    vendetta anyone?
    Hakorz fTw1!
    Case-Coolermaster Cosmos S
    MoBo- ASUS Crosshair IV
    Graphics Card-XFX R9 280X [out for RMA] using HD5870
    Hard Drive-Kingston 240Gig V300 master Seagate 160Gb slave Seagate 250Gb slave Seagate 500Gb slave Western Digital 500Gb
    CPU-AMD FX-8320 5Ghz
    RAM 8Gig Corshair c8
    Logitech 5.1 Z5500 BOOST22
    300Gb of MUSICA!!
    Steam ID: alphamonkeywoman
    http://www.techpowerup.com/gpuz/933ab/
