[Review] Round 2: Swiftech Apogee GTZ and GTZ SE Tested
Preface
This is a quick version of my Apogee GTZ and GTZ SE Testing....it's part three of my Roundup #2 of waterblock testing. I have some cool things in store for testing (including ways to significantly improve the performance of some blocks) and will be testing a lot of blocks. Anyway, I'll cut the boring parts out of the test logs and post up the Apogee GTZ results in this thread
If you have any questions, check out the full review (link above)...if they're not answered, ask away here
Test Results
First up, comparing the two blocks over 5 mounts...there's no need to do orientation testing (the best orientation is already told to use by Swiftech and there are no known mounting issues with some boards):
The first odd result I've ever had with my testing. For the record, the exact same base, mounting plate, bowing plate, o-ring, distribution insert, and mounting screws were used. The only thing changed was the top. The tops are, aside from material, identical as far as I can tell. Furthermore, the airflow over the socket I provide for MOSFET cooling is, at best, water temperature (it's usually .3C higher than water temps). So the "radiator effect" of a metal top is totally non-existent here. That really leaves one option--it's a structural advantage. The GTZ uses a very deliberate bow in its design and it seems the stronger metal top is more effective at implementing the bow. In turn, the GTZ SE does noticeably outperform the GTZ.
I do have a spare base here that's seen a lot of mileage (and isn't looking so good), but I'll use it to see if I can unlock some more performance, akin to what I did with the Heatkillers (the mods I have in mind require physical modification to the base). I'll report back if it's a fruitful venture.
- Very High Pumping Power: All three MCP355 pumps and the D5 are on at full speed--this has a very similar PQ curve to a pair of RD-30s at 20V.
- High Pumping Power: Two MCP355s with EK V2 tops are on at full speed. The other two pumps are off.
- Medium High Pumping Power: A single MCP355 with XSPC V3 top is on at full speed. The other three pumps are off.
- Medium Pumping Power: The stock D5 is on at full speed and setting 5. The other three pumps are off.
- Low Pumping Power: A single MCP355 with XSPC V3 top is on at minimum speed (~7.7V, ~2450RPM). The other three pumps are off.
- Very Low Pumping Power: The stock D5 is on at minimum speed--setting 1. The other three pumps are off.
Note: I do 5 mounts at "Medium High" then take the best config of a block and test the whole flow spectrum (after a TIM curing session) then realign that curve with average of the 3 median mounts to give you the "Adjusted" data.
Many More Graphs
I've included the core graphs and data here...but there's more in the full review, which is here. Conclusion + thoughts are also in there...I suggest checking it out if you want more info, thanks for reading!
Overall comparison write-up and charts are in progress...I need sleep first
Testing the Sapphire Rev.A right now, fwiw.
- You may not post replies
- You may not edit your posts
Forum Rules
